SOS branchement electrique regulateur de pH petite piscine au sel Résolu
Ce sujet comporte 5 messages et a été affiché 2.839 fois
Bonjour à tous ceux qui pourront m'aider.
J'ai réalisé mon coffret d'alimentation pour piscine au sel. J'avais prévu 4 disjoncteurs (pompe à chaleur, pompe de filtration, régulateur de pH et électrolyseur) et une horloge (avec son fusible 2A) pour alimenter ma pompe de filtration.
Après réception du régulateur de pH, je m'aperçois que celui-ci doit fonctionner en même temps que ma pompe de filtration et ne pas être indépendant comme je l'avais initialement prévu. Que dois-je modifier sachant que je suis novice en la matière??? Merci de votre aide.
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RBmRXhpZgAATU0AKgAAAAgAAwESAAMAAAABAAEAAIdpAAQAAAABAAAIPuocAAcAAAgMAAAAMgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB6hwABwAACAwAAAhQAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/4QjdaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIi8+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cnPz7/2wBDAAIBAQIBAQICAgICAgICAwUDAwMDAwYEBAMFBwYHBwcGBwcICQsJCAgKCAcHCg0KCgsMDAwMBwkODw0MDgsMDAz/2wBDAQICAgMDAwYDAwYMCAcIDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAz/wAARCAJYAyADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwC4kY5JJDAk/XPX/PvUqxKiDlXDD5QeP89KidJVUEoduQc5/wA+tAyy7Rkkcnkn+Y/zmvlz6toc8MZBQj5SRgZ6809rVTtAHJGcgdKfDbADOcn7vIz/AJ6j9KmWPKsQpOMD5h7H8KCCO3UxsR3LZyeP1q0SrsC5yQR1Gf8AP/16jgjVTuySDnHfj/CrFqqB8gckjp3xTuUlcerBlPPBOOD3zSxoFZSFHAySO1SlAik/dyM08xFUO0kZI/8A1UMSQy0iUE7gMA/3cGrsCFBndyOB71Db/KQCc45JH8qnZQ75J4I44GelRdFNXGtH5qMQM5HylTgmlRAqAgZx0z3qaGAb9xXCHIz2zTyo8kgn26AU46AkRNiRCpGAQRj1+tLCpicgENn+9+dSI4fI44/XvUgTaoCkk54xjIqnJjBBvAJAIGcgVJYp5ZGQqkevFJDEyrkjJB6ntmntjG7GcY4HepYCynlgDgg8+9PVGaP5iAV5ORyaYJVCkdewA7mmLqyQAsxAPU4607ATSW6Qw55BY+mcUrRAjqTxx7Vn3fii3t0y7IGUc98n/wDVWVffEe0gXcDuOOMGkkFij8T74wWDRbeJBySRgfn9a8surVWZpAoLtyTjqf69q63xx4rHiBjtG0L0x3rk3B2nAbngEdRRYGQqiuSG4DDGfX/P0rovhpHHB4wtpCMFW4OcbScenviucuZ/LkBJVSOgq74b1X7LqSSkspj5BA/HPp+dFkJ7H1rNoba1pkCMzBNuT6f4V83/ALc3grTvh7oMOsksoC7JSzbucZGP8Pavof4UeNYfEWjQKTlk/vd/bpXzj/wWMF5a/ArTri3VzbHUFS4wMgAq2M9x82B+NFhJn50/Ffx1F4l155YFwO3rjA6/h6VR8A/FC+8Ea3DeWc5jaJslM/Kwwcgjv/TtXIanetuyFIPfPFXfB3hq/wDGGrQW1jBNNPM4RFQZLEkcVSQnufrJ+wb4hi8eW9vrdsF2TxgHawJU5wRn8+vNfR/xP8NL4w8A6vpzgEXcDAZPCsOQfwODXhH7AHwWu/gJ8GbSx1Rw2oTSec6qMCPcB8vXkg9/XNfQmoaiv2CXkkletPZCZ+fXiHR5tA1Oe0lwssLkNgEZOf8AA1nR6h5VyPUnPXg/5/SvW/2pfAzaDro1SONjDeH5tvIDY6n8PTH615BbQma4GFI56e39ay5TQ6/SbpJ7QZKjaBjA7VK7hpCwIKd8n9ap6QA8aqAvPp6+uff/AAq3ErohX9F5B5x2pWAnSNY4wFQDGcY/h9TWJ40+QRTL97PzHrWzDcL0YlZOnTH+f/1VU8TWy3WlT/xMq5GD7e9U43NDw39oeb+3bs3Hd4wpyfvED0/KvK/CjmzuVLb+p4znucV618S7X7Zp7sVJMRICj8a82ttFJI/hJ/PFTygesfDbVzE0e1uPlyP8/jX05+zPrlze+JobeIgiTquc7vb9K+SPAMj2Em4j72BgccjjOa+qv2KpzP8AE+0UBcsu4j2o5R3PX/2gdU1LwboTubaSCIcF2UgDPHH1r5qufFk+o3LNJKzEdOTxivtv9uVFT9nvUpSo3K8RDEAkEuBj9f1r8901YRyYy2f4iMcGk4lRPTvDPipYZBlhhTyeg46fzr1vwl8TrXxBZDTb3LjafJYnlDjivmvS9ZESAb8g9cdc+vrXb+Adb8zWrRwRncMc9OPz61K3B7H238A4dvhTDEHDEe2RXb3UIa2IyenrXMfAm1aHwhsIYjORkevP8q665h2wMFHGM56V0QOOe55/qUZFwQAd2c/SqE6EsfXqT2+lbWqlvOcBSM+1ZciFuCMjHJ9ad7MEjMu495G4E/56VA0exNuCAa0XjxjPGfeo3X7wwOnShO4WKhTdnjnr9TUU0eT83zcenerrW4UEhe34GorlQqg4yfT0qg3KckAccc55INVp4PKt2yM5HPParzx8gDr9Kq3zDyCSRjHT1oQz5u+Os5l8SSKueBtBHAwCeP1ryvWY8HCnAJOR69f6/nXp3xkm+0eK7jJK4O3nv7/jXmmsxbJXIPXOT2rVIzZ5Z8QIyjMpUoN3Q9se1fK/7WN1h7VQcdcAnpyT/Ovq7x+4LSrlU2g8gV8eftVX3n6/HFk/IhXk8+v9a6qO5zTPFZzvk5z1rqPhrai41mLkYByR6iuWk5bNdx8IrXzddTAA2gnp2wa7U9DA91+C1mZfidpaIuQLhOnHcf8A1q/U/wAE2Jh0y2R9zuIlByc9hX5ofsr6aNS+M1hC8eT5wxx1xz2+lfqH4XtdsCKQu0L+dcWN3SN6KOg06DOAuAByOK2LOMwkYyB0OKo6cpLKV5LdiP8APvWlCCzYJx+FcHKdJKYRNJyePp196lSBNucgn1/yKaPmI29MdRU0fLjIxjnB9adgDy/MjwxGBjI61FJaeWmQPxB5qyy7dx5JHGMUMhWTOckdiKLFtFaIZYnkUEMEOBkE9R+NSyYLYIyDTEAOVxkD34NIaQwx5GOMgnqcfhWB40LWOhzsWLFkOQe3+eK6Pb8mSAD+tcb8W7023hyVcbi3y9M4NBV9D588Rr9ovpZs5LnJ9PrisOeIPGQSO5565xWrqbMGZSdobO4kcfWsm6Qxtgckn8hVJGdrFO5ttsBA59MdB7Vzl9HGkrLtJHpjpXVTLsXoBwSM9x71zusBWuZNpKhDxjnPtina+o2ZEalbsMCNqngdhXY6RGLi3R2Kj/PWuWaUySAtllY4I/z3rqtDXZbKBkEj5fQis5RGb2lQh0OOT+B5z/n86v8A2VQ+SQSOvHTrVLTw0aFWJyT1q3DIRgAZx0PQHFSolxNzTvHVh4A0KbUdUgF1Zx8MjY4+mfpiofCX7Wvg7xHrax6ZpkVvdb8Ftg3Z/wA5/KuR+Mg/tD4Z38IIjG3P/wCsV8ueE9Tk0bxGrKxUq+Sc4zj/ACaOVjOj/bil1bxL8U7nUbqRprabHkZzsQH+Ef5/lXH/AARgvPFXiW0sIFM127fKWJOBnlj3xXv2v+Bofif4atft+Y2C5BA6A/8A6v0NcvZafpHwKDPYNFPeZz5xHKjqBnnn+lVYVtbn07oXw08O/DLwbHdeI5La6uTHk+ZyF78d81y+tftWaZYTeRpYVIoxgbQAAfyPrXzZ43+N+q+N7lftd7K8ePlQMAF/AViWuqSXNxkSSNn+IGncZ9WeHvjtZ+IpFTUY4rlJTkg4G3j0/D9aq/Ea+0LQNPn1VLhI7NU3FS2NhJOBz26f/Xrx34e6fLfyxqWYrkAsTyOf8/lXq1v8Ao/itax6Zf6jPFaXC/MI8Hfxxkn06+nX6gFI+Rfjh8cZ/iJqLWtrJMNPjYiNM8NkY5rm/C+kMeWJ9c+vStX4heA08DfEPVNJVWxY3UsIYj7wVyAf0rR8K6V5gRWBG08EjnAFBmzpvCFrHZohJUtjOMY/z0rqLvxE0dkYocq23r/nvWBZo0QyowMfTn1qzO22PnACjoTkGgZVSXO4ZOSTjvn/AD0phDTyKdww3X6dKLxmiKHnn1GP/wBVRorno3I44zzTTsKyJ4X89HTOQOTgcc+9NiZYkbYPLJ6YHOPb/PSmQR7ZQcuOAQTwOn+f0p5YSncPvZyM9QPSi5BYMgkbcwXeTkEDAqdZ2lYqnO0dT34qqPOnwEjcrgc84HGfwra0bRDbS72G5iAMdcdPxqGyki1pNg08ycthRxnj6/59q6mxtPkDcgqSBzx7VmafZkSL5YIL/KctnPauj0rTyke5toB6469KE0NKx9DLK0luN23GPTrRbx7WIGcjqBx+n+etIittx/dwOOasRJzx8rHjHb/P+FQmaiscLwT155p8GGfjIPU/5/Ko3G2U/KzA/ocira/OV+ZQQOMCmKyIjaMjNjbz3K/kKswx4wTluOnpSSjoQSSTxn8KlVNsYYY25xj3zQCQqAu3qwPGO9WCmYgSRkjvxn/P9aRY15K8EjscYp5IjMi7g2B0z0NFhjYiCGHy5747/j+dTQAbBkcEZ5FU2uVt/mLFQCeT0Pt/OoZvEcNvGCXUHHbk81LQGxGQybQcY54+lKzqCBwGxk8Y71ztz42t4TtBwfUcmsnUPiGQ+F5PHbk/5zVAdv8AaIrYclRn9DUL65EiFsjKnI9684uvGstwWcu2GXAI4zVOfxDMyEly4P4c0Aei3Hja3gkfbkgnnj3NUNQ+IgjXKhCBn2IPTPNef3d/JM5AZhu6ryce3tUBmO0HcQF+9xnP+eKTA7C++IM7KXiYJ7Vmv4vuJeZDgHjuB2rn5L4nA3EAe1RPcOFRME4JPTOTTA17zWJbhQ29mBHHPp/n9Kz578yDLNux1IJ+v+fwqhHeyNIVYAckLkg8VBeO0rnD8YxxjP8AnpQS2XLi8CKAGDbsjBqpPeuwx0yMjPTOarPKWIBJxSXEYROqkqOnagOYdOTdMmcZ4IHP40W9x9lnG0BiOQaQMrFTwB2welNZBJIMZGOvPOaAvc7zwL8QrjwjOk9szGNjuZc9OP516R4h8feG/jb4HutB1+O3ms75PLmgnGQRngg9iOoPUV4HBfG1ypJYZxtB4zSyP50/yt5ZOOh4BzQNaHOa5/wSy8F6hrzXVr4muLfT3YsIQgd1HXr06cV6f8Ff2bvh98A3V9Mt/t98CMTzEMyHrx6fjnoKh8O+EpdTjVTexrGOP9YcjPXpXYaHouh+DkL3V+juD8y7s84zj8iPzq4olnqvg/VW1JElcgQ4BUHoP88Vrar4iW42xRNlRjOO5/z/ADryWT4z291H9nscpHjaTt5Na/h/X3uGQlst3/Kl1EavxT8Ip458GXVqyCRwN6f7LDpXyvcaONJvWhxh1JGCeQRx/j+VfYdvdJInLcMOuOleCfHDwb/Y3id7mOHbDcneDjAzzn/PvUlRZw1lCUI+8OPXj/PIq7EC0YwM57dvzplpp7kgEADpjr+dXE052XAIIU4zjn61D0LSK4gZclUUADIxwaVoGmidQACehyM54xVv7A8ibSDkfpThp5iB3ZYexyf89aaZZ5B450UyCeIDI5x33ZH+FcTbeGBGQZEX5fm46f54r23xN4bE9z5gB+b2xisI+GlSTaqqc+pp3QHK6H4ewysQRg9M5r2j9nLxFP4H8dwXMSB5Ixt2E4Dc9K4e30QxMDjp0Ab6V6H8EY7Gy8Y2Z1Jgttk7n6HPGKV0Vynsn7Zn7Qlr4q/Z2u7KaJra/mlhKoTwcMDwfTivhibxeY2b5lOehJr6/wD24vhRNrfwlF1oiG6SJd48pcsOOOByfT8a/PTxFdarps3lT21xC5GSGQg9elJspJnqdl4zQzhC6puIBw3U/wBa9Z+B1y/iLXoYYCxbevHfg187fCr4a+KPiHq8FtZ2FxL5n8e3ag59T7mvvb9mn9ney+FFnDd6nOZdWZB8qkGNOB+v/wBaotqDR9Y/CKPyvCNuDhSygsMda6K8JSFj144rB+Ht6k+noEfJVQTg5xxW9qJ22xBGcCt4s5JrU4W9DPcOMDk9/TNZ8ib2BG09x65rRvCRK+Rxk855qlKQGbGcjpx1ovcSRRmBMmDkAHI4OajYncc+mcnmpZlzOTnI7joc00jBxzj0x9apMCvcsWwF+6eajl3EAbeMdaklGBuGCRjryKgY7n4PHvTF1G7Soxz04qhqpxbtgHkcYrSZCoXnGeMVk+JH8nT5m/iC5A9qEM+YvifO1z4juucASFee/Neea6TErDjpn613XjW4FzqlwQcbpCwzwSMmuG1thtO7oOR7Gt4kSR5d46PlSSBsYOc8etfF/wC0vf8A2nxlPknKjjtgDivsn4j3JbzSfmyTjg9Mevavh/473ovvG942eA2MZz+tddNHNM8+5MvPrzXpvwRshJqRk5G1T/KvN4Y/MmGB0r2L4G6fiynlZRmJcjJ6+1dKOc+iv2IPDzar8cNPmRVYRP8AOTnI56/59a/THSFDFSNpXHY1+eP/AATfsXvfinMSoKQxls+jbgR/L+dforo0bCPHfj8P881w4t3kdNHYwbz9ov4e+GLnUo9Q8deDbGTQ/l1BJ9btomsSJBHiUFx5Z3lV+bHzEDqRnqtU+I/hrw54Kj8R6l4h0TTvDjxxzJql1fxRWTJJt8txMzBNr7l2nODuGM5FfA+o+J/BfgX/AIKy/HnUPHkum23h6PwBElxNfRbogj29gjx5I+9IjGML1cuEGSwBwPg78L/Gfwu+Bf7I+seO7fVNM8F+EPEepX2ureApHoYnkLadc3StxFGh3nzJMCISgEruxUxw6aWu9vxv/l+JMq7TaS2v+Fv8z9Ebj45eCLLwNaeJ5vGPhaLw3fyGG11Z9WgWxuXyw2pNu2M2UfgMfuN6HEVn+0b8Or671OGDx74KludEtft2oxprlqz2FuNuZpgHzHGN6fM2B8y88ivzu8Y/D7xX4i/Yk/a11KwtL7UfDHxA8eLf+Dra2geVtWT+045Jbu2RVJlhliETK6ZBEDkcDJ7jwd4GFl/wUX/Zz1JdDe38O6L8K7W0u7lrBkstPuhb3jLFKxXZFKGZCFbDBmXgEiqjQTTd/wCuW/8AwBOu10/q9v8Agn3Bd/tAeArXwXZeI5PG/hCPw7qsjx2eqPrNstldupYMscxfY5BVgQpJG0+laPhD4qeGPHmt6rpuheItC1q/0GTyNStrHUIbibTpCWASZEYmNsoww2D8p9DX5Pw+FtS8If8ABD/4m6bremahpN5beO4riG1vrV7eaOJ5rIK6o4BCthwCBgkMOxr6DvPDmqfFH/gpbp2pfBye0sNN8O/CmTR9Yu7W38i1067ZLpbSynXbiOeOQ2jmFwHVYcFRswFLDpJu+1/wV/8AgFxxEm0rb2/F2/4J9q+H/jB4R8XeMtR8PaT4q8Oatr2lBvt2mWmpwzXljsYI/mxKxdNrEA7gMEgGrfjbxvonw30CXVvEOsaXoOl27Kkt7qV5HaW8RYhVDSOQoyxAGTySBXwx/wAEr/Avh7xT4d+Gkeva543tPid8G7nWdPu/C0tnFbxaWb7znd7ofZxM0UibHVpJSPOGBnG2u7/4KqvqHhn4jfs+eL7z7UPh94P8bw3niWUFjb6exkgFtdTKucJHicbyuAXC5y4BzlQSqKF9/wCvxLjWbpudtjtv2Pv2tNf/AGgPj38YvCupzeFNQ0bwBcacuj6nokEsa6hDdJPJvctPKj/KiYKYB5PORjqPGfxg8KfFHRr9PDHifw74jbTGCXq6ZqMN4bVm3BVkEbHYTtbAOCdp9DXxx4J0jW/GGvftyjwXp2rWtx4rhibR5V0yaFdRKJd/aEhJQZlkEhCj7zGUMPUdL+yHp/hHxZ4M8HeL7HxF4r1HxjoXgmDwVq2mXNvDDa6J9laMvbyolvG4lWbd5fmOzshY/MASLdFW5ttF+X+ZMar5uXzf5/5HPftZ/tQv8E/HHgrw5YyaJBf+K77bcXWoy/utNtQyqZXQOpG4sQrE7f3cnBxXN2nxp+IekeD/AB7e63e/C+41Dwro0l7FaaRcTXckVxCjNKlxH5isq5QjqCCf4sGm/tw6Xc3v7R3wMvLe2uLi20nWZ576SKJpEs42ltcPKwBCKdrfM2B8rf3TXDeN9GvH+N/7Rswsrww6v4VFtYSLbuY72UWSxmONsYd9527Rzn6VUIp07211/Bk1Jy9o100/E9I8KftfaLH8NfAl/wCKL7SbHXfGkccgto5RDFArFt0zb2JSIbSAWJy2BnrjpNd+KvheCS9aTxNoMa6coe5LajEPswLBQX+b5QSyjnHLAda+cSJPCenfsv6hqVvd2drpctzY3bS2sgNtPJ5SpG425DMVbA7hSegJrbT4aWPjj9u34hrr2im/0LUNEiige5tmNvNKIrVWEbkYEqjzBlSGXD4IwaudGF2/X8GTTqysk/L8Uex6v8R/D3hbV4LXVNe0bTrm5CtDFdXsULyqzEAhWIJBOceprR8U/tC+F/hl438PeHtV1ays9R15nIWe4WNbOFIpH82VmICqzIEXJBZm4zg4+U/2m7621E/GHTNI0m70+a2t9Ke+IimmOo+W8ZSRQB5cEMUavk/x/KQQAVPaarqH9i/tLfAnxHf/AGpdLbQJrc3PkyPvmazlxGAAWaRi6gKBklhgVCoRaT7/AOVyp4iSuktv87H0p8IvH2qeKPH3jCG81TwdfaLpckSacNJvPOvbcYfzftY3EIdygDgfdfrXV6H8U/Cvi+wvb7SvEnh3UrXTU33k1pqUM8VouC26RlYhBgMctgYB9K+NfFngbxJ4lb9p2DQdP1P7VrR02SyWGJ4zqMUMrG5ERwPM+TcCFzu37cHcAfQvAM6+Mv2vvD/iTwncJP4P0H4fx6Zq91AP3EMgaRls3IGBMmYnMZ+ZQvIHSodBOPNfp+l/xLjXaly26/rb/gnvOr/ETwd470qHRrPxT4auL7V43FhDFqUMkl3tzuMaq2XAKnO3ONrelcBY/sy3el62tzPMphjbdnuB/nNfMPwx8B6hpPwk+AytoeoW17pvxAa91INYyJJaxCeAmWXK5VdgT5m4wo54r9ETEL2Ao5yZBgkcY/pUVqShs+5pQrue6PGPi38Vbb4f6O1sjgXKrhV+nHHT/OK+etf+JM/iDUPOlcZzj2Fd3+3/AOG4PB13pc8EkqPdlt6scgd8jjvzn6V4v8K/AesfE/XIbHS4JZZJW+/g7UHPJ/KsDfmOqtdXadcbsjPUHv8A/rrq/Cccl/OApPP6Vn+Kf2ffEvws1KOHVrR4iVDI3BVgfRhwen4fjXTeCrFowreWVyQMcdetArs9U+FkP2fyo9ilA47c9q+hvhU6p4gtycBNwLcV4N4EtJCqiIY5zwMAf54rc8T+Kda0HTbm7sUkm8pdzMVysecAEke/H40Bc8F/aN0lp/j14m25RTqMzc8ZyxJHP1/CqnhvRnhUZ3fNyMnH61efTZtc1WW7uXd5Xfc7uSSxPf1zmteysAq5IPydB600iWyusAW3IAUNnGKa0JdCQVwDxkVovEmMuMbffjP4fhUT2/7wtjgDgZ9/aiwmzMurR5o2wByuP8/57VUhUwFkbC4GME9etbZt/m45Az7Uk2micAD73rjge386fQXQxDbeSHYAMD1HrU2j6e0sjFl24IHPQ/5JNWLTSZBKyvzz1HQ/l35rTsLQQzFQAoPTBz/n61DY0ixZ6cF27ChXHGTx+RrVsrTfOERduQDjAzTrDS2MOeVJ7963bW0igijZcAgc5OTUt3HcSzsRaopPzEen6/T/APVVwyrISi5xn5sHGKgeQeQTxhuue3amFwG6Dk4GPekO59GoA0jDBXBPFWgPLTHOMYyD1FUlQC4YHBXIOB/XH0qdwz5GCCvIY9M0kaEkbESKT/H0qZY1aQk9u2Onv/n1qE5LKFzxwAev86llAt9rM4HsfXtTAn3+ZtPHHQZ/Wp1cB8NwnXp2NVpZVLJjIIx0as3V9YWC35fJIy2f5DikmDNLVdVhhJ8tgByMHt9feufuvHJtrh4416dc8f8A6/0rm9T8RSSzHAO0cAA9Byc/j/hWW1808bKUJzyNxAIHFNMnmOgufFUlwx6qrn7o7jpVSXXpnuB83ynr16/5zWM135ZUEg47ikkuWKYJJJ/P34okxpmnNqG+UhnIzxgHGT1qCWXIGcDA5BJ/n/ntVNmw5Jz0z25/z1poYnKtuJ9zg0Kd9wZakmBCsrlRjae4FLFcFkySCpHB9azmUtIWLbgBwB296lRSQBkAntjFNEbFwny0yCcdME8f4+vtTWciI8EnOPpVRQBIcnIbjGRRFIWBUkgA9+1VyormJyqbM98En079cUklx/eIwTj17dvWmqMDp8vfH1GetDtsYjAPbkH8aTQJjZZt0eAeeORyaovctEOpOOmRnNXZYsLjls+hxVO6TaxbhVA4Pqf8mpBojRSHLHIUjs3OaV1LDnJ9MjGTUYyyk5xz165GKlR/OUA5J49cUEirsMhAOQMDI9PU/hTo4iVByOuM0pl8pkJAIznFSq+YycLhuQoOfSgaRF5eZDkEY9uv+f6029hkZAxYdfrxUsPzZwSM8g96tW1ib9nVUL5Xr/n6UWG2c1q19c2ijyXkUr/dJFZ8GuTOQ0szu/cZ/wA+lbGt2DRI5cMCp5z161yd+RuwuRnk9gtVEk77wv4gV50kDn5cbgD3xwa9T8Ga95jDJOO5HHT0/CvnLRNd+wT4U4AGOOOlereBvFBcqWb5cYAzjH4/n/kUNMD3vSNVWVAM549e9UPifoieJfDQcLmS3HmKCTj/ADisXwxqyTqmG29gM8V1CXUdxaMrDerKc+h4oaKSszxI2IjYDaM5w3GcUrISRgYz6da6jxT4T+z6g7IFWEnjn296wLq1Wzm2b1bHGB0JrNo0iVjDvccg8DnvVfWrqLT7V5ZCQEByT1/GrEs6wR5Z+B1OcV5n8ZPiXBa6TNZwNvdjh8HOMDP9KkoxPGvxp8m7kggMToCckrz36VhaZ8WJFuh5gQIe3QD6/j/OvK9f8RNLes+4gseprLTxmFkALAEnB5qGOK1PrLQLuDXIFlhYMeuBzjrWncKyQN0DLznpg14h8Evina6JdbLmfbDIpXr0Paus8W/H2ztAYLKM3JwfnX7o44P51jKpY9PD4Oc9kel+F/2pdW+HMD2ssgurXPzRy/MCPTnOelZ3in9tHwI7mTV/CNnPdDkGKFXBOcknP/1+tfNPjL4hX2qSuZJDGGzgAYA9a891zWDLOzu5YZ5yaj2rZ61PLYJe+fXsn/BRnTNN3QaF4ftdMjcECQIFOOnQenp7VPpX/BQazRjJdw3UjnAymOO3fFfDt1rzFjtzntUUN9f38wWFZm3HACDOaOeRt9Rw66H6O/Cn/grFp3gK8uDc6dd3UUg+UAqCD+Jr0iw/4LO+Eb+MpPo+qQlv4iqN2HTDcd6/K+z8M+IZ8MtjfOen+qYirZ8O69p3MtjdxlfWMjNTKtNK5LyzCy6H6ueGf+CjngDxdc7HvpbNn6eYhxz74/zxXpfh344eHfFCRfZdSt384DCmQAnPbGetfjNoNxfpqKI4kjAODuB45r2bQPFF7FBFGsjqYgApUkbcDjGO9YLHyT1B8O0pK8G0fqzKySOHT+ID8aYEKMcnI6+9eM/sSfE268ffDKSO+ZpbrS5fJ8w/edSMjPHUf4fWvZxy3JyD3NevQnzxUj5TFYd0arpy6EEyAZOAMiqwUK+B3GauTkSEkY4PP+NQyABOmf61scjInj24PGO5zg1zvjm4a10G6c/KAv4/h+VdHkEnqfbPHSuR+Ll0lt4Uu26kLgc4xmqSA+YvE9x5l3LJgAsxI9ea4zxGcREEE56YPNdTrchfdnGSf65P0rk/EjFIJHAHyDJ+laxJZ5F8Q5iIJiDt46Ht3/pXwx8ULk3Xim9kPXzCT+dfbPxUvlg027kOV/ds3BxgYr4a8a3X2nU5jzy7fzNdlM5ZmVYENMucDPAr3D4Uw/Y/CVzLj5nXAz+P+fwrxDSkBuk9M+te/eCIxaeAlPTecZ6etbJnOfWv/BMPSxd61qF6ygGNQCdnXGe/avvLSVyOuQeNvTNfHX/BM7w8LXwvqN0GwZJdv3fvfd/+vX2VpgEewDn1I5zXn13eTOukrI4DwZ+yd4f8HftVeJvi/bajrsniTxTpcelXdpLJCbCKKMQANGoiEgb/AEdTkyEfM3HTHsdl+8X5gR/vdqrWqBeex/UVetE+T3z6YwKwlJu1+hpGKW3UnjQCPaSeM8Z/L+VMIKnAYkcde57mnJHgZOTnnPrQU4PQEc8d6kZ5n+1f+zJon7Xfweu/A3iTUtZ03R76eGeeTSpIo7iTynDqu6WORQu4KThc8DnGa9AsVTTLGGAzPJ5Eaxh3IDPgAZOABk+wA9qp+INbfT42wFbaOB/hXC638QZ5CwQFTjnntjpV87a5S+VX5up2+reJodPhyHGf0rjvEPxMWIOsbjPqOv0ri9W8XT3zEFz+BwTWNc33mnlsMeSSM4/zmpaGb+qfEK5uHZQ/y5/L2rlda1ee8UgOcjPViQCT7k/4U25ufM4wwC+9Ubi4XJGQG6/5/wA+lUkNdjJv4/NjwSxZhx9Kpy2x8sFjg4z09PStCVfMy2QQW49DVS8VFHqpHIp3JsZ8iZ3Y4IBznvXO6o2UIBJAznnmt2diXbB+9nGRwPyrC1aEBDjbuPv1pJ3B6Izowdy4UZB5HrXSWCKIwAB+VcxFIx2DHzDH15rodLYsoOcE8g+nFNiTOk0q4AhwOvbirs11+6XJACn0xWRpsghGAR6k5wavGQOCwPA5/EVmUW4bhWVS2G2/NgGs/VtafT4XkQ5ePoAeppk2pLBEcYAPGaovqKsCXMe3HQnp/nigD5Z+N134m/an+J8Wli3ay0rRpWhaR1xjnB6Z9Ov+Fe2/C/wNpvwj0KG3sY182NR5k2TktjnHPT/PpWvdTW0Fy5iijjZ33OVAy59/Ws+51LexGeTg9M4//XVKIHruj/FHQfHOjjSPE9uZ1ClI59uGiz1w3p9Pyqva/sjaFqlybjR9ctXhfJEcjYK/l7145PqItldxtXsAfX/Jqi3xFu7NSIrl1CjClXxj16c0+Rkcx9WeDfgro3gezkk1C9s37796jA/HANcD8c/2gfC2meGrrwz4edJXuR/pM2BsbBzgds5/L9a+Q/H/AMftTvrqWzF/cMqtjJlZiD36/wCeK5LTvEEryEmaQs3PJzz/AJJo5GHMe2Jbgo5jBJz17UsUXlkkkkf3R0rlPAPima53QzHKsMDJ/wA8129pBhCwLZY+h7dKdrAyEwhGOVJDEY44WnxWqqpxhvY1IHEcrEblzx6Yp0Z2bgSeRxz+lKwXRRjQGbgKH6EdRzU32AwzFhnGMjHYGpzHtBO0cdOOfpTkIA2ryeOgJz78UNCK9nYfvW4BL4zgfl/X9a1LHRCmS5JOegJBxnvTrHTvIkDY568nJ+lakAITIBVhg5Hcf5z+lZtFjo4EjAAwPcDk08sC4IID455wcf5/pTXYMoAZQc8ZHH+eailciPK4JHOccVBLF85QGIyd/wCGf881DPMU2MSy89AvH61BJflo9hJC9M56f59qz7jUV38EZB6Y4ppiPrSEPIg4YsByMAcVOQsYOT2/i9P/ANdVobkFWJIBOfTNU7y7UwnLMpxgH39v89qhM6Llu51ZLGZQxJVvfFU7jxXC2Sd2RgYA4/zzWFrl42/AYhME5zkH6isO5lG77+QBgKegqgudBe+PC7lFI2lTkg5z/k1j6n4ikuFdnLBO/PT3/WsaWc20rKOc9CP8+mKikfaSRkoeoPUegpJCaL0swZdw+Xd6Z4NRo0mcAtzxnuPxqkZnVjgYB6d8D/CrcbEOuR8xxz1pdRWQ6KQDHytuI5BP4UKUIyrcjuD+VN5Y7Wz7f5+lRsTHIPmPTAHYVQ7pFgOGCgtgEdscHvTJ2ZM5JJ6jHPNQtNsYE4zjAPYU+OYueeTjgZ6dqaJuxVJLFWwBnr1zT/M8t+RwM4NMnY53AZJHXP8An/GlX5lJ+XI64HIpoLMdtMjbgTg4BUinRuIslh90dTzzTYIhtKgckYp+AUbOc9T6fzoch8pKChRiuecn+uKinb5GAyuPTjv/AJ/KljfcxHGBxgd6j+zl5/vbVxxnnH4fnSuJInjX1GVPr0FVr+Es2MnB688VbC7ouWyMEcD/AOvTBGJWBP3evqTRYsorCLdemdwwRSKfszgAYUjr3H+eKuzW6sRjBwMA49s1RlRSylgTn2/z3pqwrIkjB2Dp6jtUkTAvg5zjHPfnFQ24AIBBwevv9asLDjByAF6kCmkTYW2hCs2BnJzkYGK3PCMZW9Xng8nmsm2cRoMEEn1OTWz4TYvqGRk8YP1pgyv8Q/DmN00eCWGSuM815frtqbYbiN2ecYx+Fe7a1HFPpbKQrL3wOn0ry3xloLKWK8jOemeKdhHnsl2sLkk/N23c/wCfWuq8Ha+0UyAMQp6BegrlNa09oZWAH3eT2x/nmquk6w9ldL820bj+dPlJbPpDwV4hEqx5JyQM9OOK9B07VS8AGSzY5z/k18/eCfF4yuXwVIU+hr1nwzrhu7bd1K9amSLQ/wCKerSW1nDLnbHnBI+lcBqfjMWdqWdiMHPzHGa7bx+i6poZjY/OGBQk8mvDvi682kaYIyTlzgN3AxWUo6GiM3xN8bLi6MsMRIK8dsEfh7fyrzbXtZecOXJLuDk5x/T61BexMLv5efTrzSXEH2qPkEjGDjof/rVk5HRGN9EeZeLb8veMEOAT2PXiq/h7w9PfThpBhGPOeSPw/wAK6XWPC6SaqJB91DnGMbj6Vq28KWlvubbgdupxWE6nY9rA5df357D9L8PjT7cHd8pwfp61Jf8AiKys4ikaGR+ny4OP8msv+0pNYv0hikIT0Bx3/wAK7LQfh3a2yJPMhkdvvBu2e1YODb1PUqYqlQVkcA2ga142ZzbWsu3OchTxXTeHf2W7jWYt99dfZwPvKo3GvZfhhpiXV+tpGgUvwvtn/Oa9P0r4Ba7eTborY7XPO44wPXmtYwSPMq5jKXwngvhb9lzQNPYCWFrgnABkzge/Wvob4K/Arwza7VTSLXcOQWU9B+PfP613Xgf9la4uZ1a/mEQJGQOePpXtPgb4NaX4LhUxkzuD1YYz/n+lNpI45Yicupe+F3wm8P2Okxt/YunR8Hj7OvI/EfWsz456d8P/AIf+FLjUdb0nR4reIFj/AKOgMhAPAwMkkZrT+K/xs0X4H+DpdV1S4t4IoxhEL4Z27KB1OfpX53fH39oTW/2lPGb3d3JJbaXHITaWSsdkYAxk+rcde36nhxFdRVj1ctwFSvLmexz/AMXtb0f4jfEW7vtD0a30bTmIWKKIY3AZ+YjPBPp+pqho2lO1xFFCjvI7Abeuc8dKsW+myQtHBBG008hwFUZLEnpX1r+yL+x9/wAI95XiTxLD/prJutrVuRFzkMw9eOlcVCjKrI+kxeKp4Sld/I9H/ZQ+Fsnww+FluLpVW91JvtMi/wBxSPlU/Qc/jXpqttI6fXNSSpgYGBgccdKjwM9zt7gc19PQjyxUUfm2KrOrVdSXUc3UjIAA6Z6VCqBlxkEZ7dv/ANdSMckfMcevXP8An+lMkO3r37VscrIZQIc4PXpzXn3x3uWi8IyYJJYHtXe3hLMMZweDivLf2ibpotEgj3ZEzY4PYdvpVRJPn3VkImb5ztPqK5HxbdCOykGRkjBGK67VWABPGRz78VxPjW4X7PJk8kHBHWtYkyPCfjzfrD4Q1NlxnyyOCeM4H9a+KNcl8y8OfXv0r6//AGmbtbfwXdkYLudo+hzXx7qrBrgj9a7KZzTG6REHv41xncfy9a+kksVh+HFiioqlsYIxzxXz14cs2l1aBB3YAA19G68f7O8OaPbnG0kHr0GB/wDWrU5j7u/4Ju6bn4MR3DFgzylWz3wSM/jX1PYQhdoG3gdx0rwL9iKzXTvgfppjjGJQJCdpB5/+uM/jX0HpGAozznmvOqu8mdsFoT6jrun+GbeKfUr60sYZriG1jkuZliSSaWRY4owWIBd5GRVXqzMAASQK1Y2K8AAn618r/tcCT4zftl/Ab4YW8iT6bpl9cfEDxFCnE9rDYKEsHbJAaGS6d0K4Ykqp4CnP1R5XknByCKzlGyT7jjK7a7E8TYUqcsPr3prxrjP14pFymD3AABprvhhj5d3Ujuam5fUoavo63kZ/vDv7VxHirwpHYCVgFOATkdK9AuZTEhJJ6fia8w+JviaWxJQHJJwO2f8APSiJZ5tq9ypkfaeD06/nis6SfD5ZmbIOMjpzUl/cCWUuAfmPUZNVGzMx6YPpnmnIi4j3e9yD2AI9ORVe7bYBkrtx3NMVw24lsqR270SAbeSRzz7e30pJspsrTyMWPO78cVDefdOCN3UEVLNCM5PIzyefeq1yDLGy8Hdz16/5NPWwuYpXDJgbjjAzxySPX9awdVUPI2wbR3A5HWtbUbchTuJbHHGOlYt2ApJ3dvwP+QaaFczJ43iwZFOc5OO/51raZerGQgAJbsffj/Gsq9BwOCdo9fepbSfgNjLY6j+VKQjpLS+KuuSo3YyCecVpvcbVUKcHGT/hXN28w2rkZJPHfArSgu1YAAnJ9uv+cVJoM1lniCkb9pIGSOvHT+VZE14fmOTkdv8AP4/lW7fKLqAKQfx+lYl5pDEOwyBjPPcfjQguZN1c4kbjJz0x7VQncCMuxIA7npVi6tJTNtKHOcZAPSlfRrnUIThHXjByMH+ftWsdyWzlta13dvThST1PFeVfFr4xw+FrB7aykE12w5Zf4Ov/ANepfj5qt54ckaK0Yq+dpI5P6d8d68wuvh1qeu+HJL2FA0cce+RiT8vOP511Qhc5pysYNp45mvtQaWclt7ZZvrzk16B4euVvwjLjp27V5N4f0m4aV98bgKxAYZx+dem+C4HtrdUILkYzxnpVyikZwm2zvNI1P7DMWXCKOhxnn3969N8N+MEvbdIy4DYHXvgV5VY3ClUyRkd8+latle/ZsbThgvbj+Vc0o9TpSZ61tW4j3qcHoOM/5NSbABkn7ozwTiuZ8Ga6btQkjcqckE5NdBqE+wjaoXf056VLWhSIbq6aSZdjBR25681e08KzDcQCD6ZJrNghHmlgOTxtxyB/9atGwDS7eMc8Z7dzWUh3NOCfKHdjcOCf8/WpzMVXBJIbg54FV7eHdGxx3JGBnnp2+n6VYJjWEsD8w5HuAf8A9dSN7AMGEgFcYyDj/PaqU2omBHVTtx6N9KHkCu21jjG7g5xjHp+FVLq5M4+ZVO4dQc4555osSQNJ9pVyxGGPfqPp/nvVCZJJmIyy4GF9Dz/n862LTSHkjHOQuf8ACtvw18ObnxBdxRW0EzyO2AoXJbIz+PANFhI+gLmfy4y24EduMYFc34h1tlkKlwRg5HTJrf1aErHsUjvj64rjNa0mW7csvQn6+wFc5s0U7nXZbtWJLjqD6dP/AK9VWv3XOW7dhjtUiaabVmDAgjk4GDnj07dP0pZtP+TeAxA44PPT8f8AIq0IqT3O6cKcfMDgj0HP9amRTkMx47A+lQfZh5u9uGGfmzmpg4PViexJ70ykySMlQxIA/h/TGKcGPlgq3Kjj2+n+e9RLygyOCMg54x9frTzFskH9w+nFDE3ckMzNGABjHU7aY7kNyMEdeeRSGcFlJzzxgE805hvXoSRjkjmsx2HIzeemcdORnp7YpxC+YecA9celQwqynceRjBHqMVJnMm5sEDuOuapXsCsSbtuRnAwScjmkikZGIJ56cfn/AJ+tEbZGDgFRxnkUm8yNtGPb36Ursq4+J/NkCYAYdz1PapdhJK5IzwOtNtkCsGwDg8fLz+VSySbeyshGMiqQEYj25CqWBIHuc1NHFu+Zto4wBnGfemGTZIChBHYCkWYkYII9Ae3FCYErliQAAQOTxjNOCZTcOMcdqOChyTnoDnpToieMlSOnPU9P8/jTAjMnO3k7l445qhdW+W2nJLde2P8AP+fbWlcRAbVXcORxnFZ10yGQ46dRx09TVJCexEAyNyMjrkf5/wA/jViWTevIUnd246U0jfkhRggdv606JAXGOOc8/r+tNuxKZJZPyCQQOg46f55rf8JRn+0ck/LgdOh9qw4wY3AAJOefrXR+FlXcWJJxjvnHvWkFcib6mrr03l2DbeATz61xWt2/2uErt3YP04rY+Ifiyz8O6a0lzOkYTLAHvivI9S/aP0u3c+VHPKHPB6AD3/8ArV20sDVqK8Vc86tmNCm+Wckh/ibS/s7szY3dTwOmP/1VwWuI0c42Kcg5OBxiuqn+L2k+J8Dd5ZXllbj19eKqailpqELGIht2cYbI61pLAVYfFGxMMyoz+GSZW8F66badPnIYNkhh717h8N9fE4Xa5AxkZPX/ABr590/S5Ib7cFIUHivb/hBotxe4xEcAABjwAfXP+e1cdSFtzup1FLVG98TPEbLNawxuQyfOTjA/zxXEePdBk8TaOXI3PFyBjPbsK9A8U/D6UT/apXUBRgAdBVCHTVjUDd6ZwcdKxdtjpjK585XegyxEmVApQ/MSelYt7rtpas8QkXeBtxnODX0f4q8B2Os6Vc4BicxnBUY5I618haT4Tm0zxBdxzTCYrMyhlOVfB6+/f8q8ytOx9FlmF9o7voaEIaXfIxJPXp171yvjfx3BpG6J5FVm4UM2B/n/ABro/FeoJpdg6dOOa8B8e6XeeM9WeTedq8KvOKMNRdSR6WbYxYajaO523wg+MNhbfEP7NqD7hIcK4AKqa+n9O8U6Rculus8LN0GznOOM18Q+DPgzdalfgI/lSk4Uk4HNfo9+xt/wTmWbwZa6t40ubjzLiMSxwRvtyDyCT16Ada9KpheRXZ8ZDHSqSO2/Zm+Fp1jxXa3rQt9ngYP5gJP0J9uK+q7KCO1XAVFBOMAYxWFoGj6T4J0uOy06MRRRKFxncxx796tPqjXDgMWwe57CuGokjtg2zpre7RCVUbV4z71g/FT4x6T8IPCNzq2qXCQwQ/KoJ+eVz0VR3NZHin4i2Hw78N3Gp6ncCC0tkLsxPJA7e59q/P39ov8AaL1L9oDxi9xJJNDpFu5+x2eflQf3yO7H9B+OeCvVsj28ty5153exL8ePj9rXx/8AGUt5qDlLCFyLW0U/JCufTPJ55P0rL8PWst3cQ2tjBJNdTMFVI1LMzH0A/CsDQdOm1PUIre1ieeaUhVRFyzk9ABX3r+yB+yHb/DPT4Nf8QQLNrk6h4onBP2McdQeN351wwoyqy1PqsVi6WCpWXyQfsq/siW/gawtte8QQrPrUgEkcT4ZbfqQe43cjp0/l9BZB6YAHpSyENGcdB+tRuxLYzzXvYelGEbI/P8ZjKlebnNhIxXGc5Oe31qENjO4/Lk96ll2u4I7j1zUezcD04zXTE856iFueBu9cH/OaY7ZXGKUHAx2HXrUbsHbjj0yaszZW1AjbwMc46dK8Y/aTvhGLVOSV55PWvZboqByOTzgmvBP2jrnb4i25IAQAe1VEDyTU28wvyoBzj61wnjKcL5gLAYBB56V22qAGFhuHXIz2rznx7cZkcegxj0rWJMj5w/auvzD4Z8sEHdJgnI9q+VdScmYnueMYr6Q/a61FFtbdAT8zEkDsRXzXeybpa7KZzVDoPhwn2jxDDnnnPuMelfQ/im0W+1HTLMtsbyxgldwzxivB/grZ/bPGFovTLj8K961S2a9+JOmhdx8uSJNuM5yfT8a1Zz2P00/Zg0k6T8GtDgKhWS3XjGMjt+mK9e09vLVeBz144FcP8KNMFj4O0xAgXbAo2+nH+H86q/tV/GMfs7fs1eNfGyzW0NzoGkTz2LXKkxPeMuy2RgCCQ07RrgEE7sV5crt8qO26Suzy79iSWD45/tf/AB5+K4d7m0s9Wh8A6G8k3mfZYLCNGu/KKsU8med0lXA7E9WavrPYHiPoT1GK8Z/YA+C138Av2P8AwJ4Z1FZk1i304XuprcYaWO8uXa5nR2BO4pLM6Zyc7RXsoyCM7c/40VWnLQmkrRVxyEEHJAUelV5pAGzn5QuelV9bvhp9uznkDnjrXnmv+OrzUJzFCpUdjjJrM16ndazrcFtbuzyKoA54FeL/ABO1qK/u8ISQD/3z61o3tpqWpAtKz4IJwwwD71yPiTTZNOyGYMSfxHanEpmRJh1UsQrDr6fnVXYzEjJ5JGO9LLJlQCe/PNRq2zcwyAo6+npTkJMrvE1vMepAznPanTShVBBIB9KJXeSX5iPQgdv8/wCFRIPNUDJIJxyevvTQ2iKWR1B2kncenWohIGcq3AHXNWLlvLIXGfqapSsRIQcnPT6df8KZBR1N2TkkYGTjqKxLxjKxG3GAfqf8/wBa3b6VJg2eVHT1rIdRJuIyoxxkYH5UAZV1brASAScn8+tUYboLdMG2kD0PQ1oXa7lZsHJz36daxdSXySZOmevvQNM2Le/VlwXYAHGPXk1etb4LIvzBh0z3z1rn7ScsoJOPoMnP+cVdiugi8csCOw71FhqR06P54+92zwOv+RS+UHbGTk8YOeKztG1bEIEpyc+o/wAjtWkrh+Qc9yRxikJkttZxH7xyerZ5xWh/ZIlgOEBUqTxzWRnE5Ydf5cetaek600MqCQnaCADjOPb+VarcLHzB+1Xb2nhu2nM5UMGLIp6H6V896T8cvsNvPp7SeVBMpUqB9f1r7M/am/ZuX41aOsllMEuIzuWMgc//AF+tfC3xe/Zq8QfDGWSS9gcIr7QfXvn6c120noc9SN2dr4JuIPEskcSFdijjjtXo8PhyKziABXd/KvmzwV4hvvD0YYFvk9RXceFfjNfz6kscrZTI6knp2pyZEY2PYJdN8nldwGO/BP8A9aptLt2M3O488bvrWn4ZKax4fWVkKsyg/wAv/wBVWdP0KbUrnZDHn+gz/jWB0KxoeD4mXVIFAJZmwB0xn/8AXXdalbMzCPgcEHj8vrVbwZ4GOlBZ5wfM5IDDp71rahbszqzdB8vPfmo5R30M20tGikUcNgj6H+tbVnbLEnTnvhqrQf8AIQRQRtUc5GPetKNljRSRg46jk4qJRGpDLcCMKZeSc42/jior2ZMEISCMkZB/+vUl2nnykL8w6Yq7p/hqW5mDFNqsOPUc1FgMm2tXvxheNw+8R0zWppfgN7xxsBfaMkLgA/nXqPwm+A1/4wuEitrN3WT/AJa7DtAHXJxj88V9MfD/APZV07wNpMdzcqLi6HLAjgE//roSA+dfhf8Asz3OvyRTXcLw223JyQS3PQZ71754J+FemeCLIR28IDk8sRls4rtINNhswEiQKqDgVVkiWJySMZ9+f89KdgPn+WESoA3JB6epxVK/01MthVGRwc5q8kqg5IGenXHTj/P0qcBbsNGVOQOBnOf8/wBK5LmyZ53rMDxFiqkFe+P8/wCTWVNM6g5zzjAIxXot/wCFvtrE4zk5B7fjWBqvhl7eMlYwQGx0HQ/5FNXGkcfKzKcvgnoMDmmoCwVCuWPTPtitHUrUW+crgggkdT0qjt2OrnOABk9qoGiVJGAAYDrn1NSKvmKCeGI+v+elRAMCoUEl+mO/+NT2zGJgwJ7twePT+lBASBZGywHH8R6fSgkGRht3bRyOnFOnOdrH5V6jgjNMZWXDLwSuADg4pWHccqFnbg4U888e38xT1fdER1Hr7UwFlcrkA5BbHYDFSSEmIHLEA88dfzpghYjiXuBkhhnp70+OHDFhg4GeD+JFN8whiVBwPU5z9aA5HJJOBnr0pWHfUdLNtQkZGOcg4z9KInwAC/GQec8VDywOQ3HU5/z6mpIiqgDBwvTnJ60tguTwSq6nY2AQOp5P+fpTJYyCzEA4Hfn6VJlIyMdT6HoaftJyAR9V6UNFIRDkEKR6L6UNL5ZyCCfrimbdg++Sc4NV5QxfkNj1z19acWA6e7eVvoOQpxmmCdVYBiMDqfX/AApdhAOOrHIJ9fx/zzSyRcoeNp4OenX/AOvVWZLY+NgkpJwcnjv+tTr87cqMYJGBzj0qJIyFXnHB5H0qSMsr5zu7Y9PWmr9SUiQwk49/XvWlb6zHoek3M7uqrChcljgcDNUEw8g24DAdCO3+eK4v44eJW0Xwq9uOTeHy3yeQO/6V34Cl7SsodzizGr7KhKp2PKfil8RLrx5rTySSlrVZCYlzkYP/AOquHvd/kMyjcoz17fhWusAupeSSxPfmva/g/wDBy2k0KK5uoklM2HO+PKkdhzX3VSvTwtNaH5nh8PWx1Zu+p8wHxLJZTlckEHAIFbGjePZ7Mr5c+Aeo3c8//qr7Es/2W/CHi5PLvNOhhLL/AKyJCCnuOfXn8K8l+OH7ATaWZbnwtqMbohJ8i54Y/Q4PSuVZrh6mktD05ZJiaPvR19Dlvhx8cdI0bUQdbQ7MDa6YLd/X8K908MftNeH309W0qKJo+m4EAn6j618I+O/COveEr17fULSeBk5O4frWZ4f8U32kXaywTyRSDqynrj1rixGX0qr5os7MNmdaiuWa2Pv3VvjdJqzFmzg4CjtiqkfxTRifkwDyDnOBXzn4H+Kd5LbQ/am844G5geee+K7238aadLpxZZgrshJV85GOK8fE5c6a5ke9g80jVkonT/Ev41vYaHLBbZWaddikHkHHX34NeN2CNDbtM/zHqDz/ADqbVLt9e1snLMnO3PTg9anlSN9StrQttjZgGIxwM818fiLupZH61gKao0OdkkXwmk8aeEb69kLRyY3QAdG+v6ivDbDSXudTaBMFlk2lufXFfoD4P8OaH4o0O1srG5RB5QiJIwR8vXp/LvmvmH4qfCm3+E3xNv8AR7a7S98iQM8iqRsLDdg+4BGcfTtX0+SYVSlZn51xZmr5eaL8jC8HeGIdKRZQgLqQwOckEV9d/sw/tU6l4tv4PDmpXJlljjPkSnA3BcYXgV8pazfvomnbtwQYBGOOa6z9jnU2uvi7bag8hWCzDByzYPK4/wAK97MaNP2T0PjspxdaVZa7n6F6fcNMFckkOcAf1q1qmtQ6Lp01xcSRxwwKSzNwMVxMXxS0rTLUO99a7V6/vR1/P/OK+ef2uP2oW19P+Ef0aZ1hPN1KjAiQdQuf518JiZcup+p5bhZV5qKOX/ar/aRufjD4lk0yxmYaBYSYjC5AuW/vn264ry2wsXmmQIpZm4AA61TiACsxIHqfevpf9hf4NaLrl6viXxDcW/2e2YrawSyKFkYZ+ZhxlRzxXlxi6kj7ipVpYOhpsj1/9hz9kpfCGn2virxBbBdTk+ezhkXJhTOVc8/eOAQCOK+oS42Dnp+Nc9F8QdISJNl/ZkKAoCyqeOn9KVvHumFc/b7YIeeZAK9KlQ5VZHwWNxk683OZuzyYiHbIwWz1qPJJJ5B7571hx+O9KnBK31qR6ecpx+vrTv8AhPtKiRWe+tlPYGQc11RicNzcPzDP3T602R8oSc4HbrWHL8RNIVcm/tAG7GVQfyqA/FHRQrhdSs2C8H96Mj9a1SMzcZ94JwfX61EX2k8Zxz9axB8T9C2s/wDalmB6mUfNjt/n+lMm+JGigMTqdmMHaT5oxnp1qrMhmrqkwjtyRwR04r5t+OepfbPGE4Jyy8H0/X0r23U/iXorRHGo2OMdPNXn6c186+PNV/tjxLczpIrIXbBU9v8AP8qaQjj9WYtIVDAdutecePpgJG3L7A16FqTjc+XG7JyN3Xn/APVXn/jTTJLwvswRnse2f8/lW0CZHyD+1fdGWa3UkjknGeg/z/OvBJwSfr719N/tFfBjxF4n1oy2mm3VzGiHJjXIxn/P+ea8qb9l/wAYiUKNDv8AcDjaYjke2OtdlM5qm5H+z1ZNN4pR1PzIfz6V738NiNc+PdhaMfm+0RKTwcjcpHt3/wD11wvwN/Z+8T+HvEXm3ek3UMYA5ZCBnIr274JfCe/0r40aZqdzCIIEugWkdgOPX8Dg1b2MuXU/SvwlFs0+2AJIEag847DmvCP+ChENv8XviD8FfgtI7fY/iD4kbVdZj3kRXWmaXEbqe2k2MHHnN5e1hwGQnORXs+mfEPRbOAFtRsUVBkkzKAvTvmvCvgL8RdG+LH/BQf4q+ObvULNtK8FaXZ+BdBukuF8idyfteo5BP+sjnaKMtjBGACea4IK0nLsb1NUo9z69tpcqCOo5qwjArkkjHpXKj4o+Hwcf2tp4LdP3q8/5/wAKlT4naFEhb+19PKg4ObhRg5x69c8VjymyNnVNMTUoiGAYD37f5xWWnhS1tZMrHyDk56mmj4paEp/5ClgQuckSqf1zjrUZ+J/h+Zd66vYn02zrzzj196OUEZHjWB7LT22Kq8de2a8e8UXM1xMfMJ3c4HXNeweJ/iX4flsZEGpWLsyngSgnPv6V4j4r8U2F7qTm3u7dgOQVlUjjr+tNIu5mzJxyckDp0NRDI25HYk88DGaZLr9qrFDcRhuMqH5NX5tDmawiuQv7uQ7gd2MClIVkZsi5lK/LgDJaoY5MjJIKk88dO/8AhU8sex9oPTGM96rHcHO3hQTkev5f54ppDCYYdSeg9hVO9czRZX72OPY9v1qeTG44I44P6VGsClP7p5bkDH6UyLMw7jcqkFeo59qrFS+/JPvk8H6VtvAjkknrmqstgo3EdCeuaBGLNa8nPfv0xWZqenqYnPDHP4V1H2ALA+FBHc4NY99ZEscAMucex/GgDmMvDMPl+UEYPr/nmrdpMoVV5YDjHXj8ak1WwaWInocVkQ3T2tztk3ALgfjQBv8A2sgYQhccj3rX0nVfNiGW245IbjIrl47/AM1htDEscDHftmrsVyrSBWI55HPU1DKR1Yl84DnIHPB4FNdjCd64z+HH+eKx7LVShwWIUY5Jz/n/AOtWjFdC5jBGePWriwe5MusSQkEtjPVSKyfHPgix+LmhvYXkMRkC5Qkcq2KuSKCxIyD+o9qZod61rqYDAtg7PxrZTsS0fImu/s5va+L7m0MZW1hcgPtPzDp/nNaFv+zbpenX8U6SsdnPIxkfn9a+rPHHguHxAhuYQPN9AuS3+eteX+IfB2oR3DRi2YFTjPv05/z61XtBWOf0TS0gEVjbISFwgzzXq/hXwhB4atQcq05zkkenb1rG8BeAm0dlubw7Cq4APHPHOa2L/VCbxjHkpk7cHr19KnmFymqzqpOHye3fFRyWSyITvBR+vzd+OayEmmlc8kt355FT28V08BRQzFiNpJORxRzDexBPppgnkZWBU8nviltZ2mZlwdwbqelbGm+C9Q1CDeymNSQMn0Iro9B+G4u5YonZWmY4GDjP4UmyVsUfBnhNtavkVIzK44bgnvzX0r8Hv2WotTeK41U+XGB/qwevpXLeBfh9f+HrGEQWx2/eDbc5Irc1nx34j8PQRjz5okPUbQBjH+fyqWy+h9LaF4e0nwraLDYwQwR7Qvy4zgf/AK61dWuEm0htrhjt+or5Z8H/ABi1jUNWEN3dFgzDHynjI6+/5969+8K6g1z4fG5yxdcj0xTJ20KN1hpMg85Pr9P8/hVK5fLsOBz0xnNXbtxLIwCqv4fzqhKxdzk4IHPrUtWLTseCtGtzL129+tTQReWMbAGJAzTYSQA3BAH58VYVSn+0v5HmuFG1g4ikJHKnkYGP881ma7CqQPtOOwPXGTWu6AqrAjk9Bk1l62+YiMKcdv8AP+eK0JtZnn/iS0K3BY4YjkAnjpWQIiYSRtOfU8H3/KtTxTdyGZ9g4JwST1H+FZUTGSLOduMnvxyaCyRLZZ15IXaM4OOR/hSwWx3n/dCnJ/SiM46enVjTlbevQg5xxxSTFYXycAZPzEDjGM+tPGC4YjnOMetNWfdgnaCeDz9KGkwxBHU4GRjHv9aYNEjHLk9Qcj0waUyhkwOo/DpTGJAHp0HuKblkccHb6461LYJE0YUkhS2ByCOD7Uu/YgKjJPQZPGOo/WoVkKkgkjggZP8A9anpJlyuCcnHIxTuMcsIZDk4UY//AF/59adFEWbBwT+o4oQKinjk8/T/ADxT44jHLj+HryeSeP8A61DQrCtCUBztGTwc81JChKhSPmJ9O3Smq7q5ySTUgcMykY6Z44/ShaDGug28DJOOnT61UkQxk5wGz/k1cGMHlh/Fn0xUVzaB2DKTt478DPNSnYGd18Lvg5J4/snnNysCqxAyu7JFdgf2TXxxqsZxknMJB/zmtj9mVS3gtmAyTKc8Y46V6pBAxT51PPQ0+YVkeJr+yXNG2BqVuQcElkIwf8/ypX/ZSubdONRtTnJ4Dc/pXtkzi3iZmIQKMk+leS/Ez9q7RPh3qL2U5Msq90IAH4n6U1NgkZY/ZVvtrbdQtOT8p2npzXF/E79gPWviBJG0OradCIVO0OrZzkc8dscV6x8Mf2pvDPjl47U3Bt7hslRJjDe2c/zr1m3iLRBgdwI4rfD4qdKanHdHPicNCvTdOpsz4lj/AOCX+vROu3WdKZAScMHBP5DHP17/AIV6/p/7K2qadYRwR3NmUiTaN2egHWvflhJcqMnPA60t0n2FyJCwJ5PHH6114jMq1e3tGceEynD4Vt0la55Dpn7PWq2UGPOt2YcZyap6j+zZrN8CPtNrhhgncT1/DtxXudsPOjDfwnPU80rw4GOxFciqtdTv9mmfI/jH9gHVfF5P2u40uZZO7Z4555x9Pyryzxf/AMEdb68cS6bqthbyk5KSMSgOO3GfX9K+3/iB8VNH+G1k9xqdysCoMkEZJrz/AEH9srwb4l1KOJbqSDcflZx8p+v+P/666qeY1YK0Wc1fLaFX40fJ+j/8EiPHOnzHGuaGkQOFw77jg46BT9a2If8AglZ42fh9Y0JsL/fcHP8A3zX31pV5b69pcN1ayxzQTAMrrggj61eSED268YqqmZ1px5ZMxo5Ph6UlON7n5+6n/wAEzvFfhHw9cXqXem38lsu4wxOd7/7uQPbv615vqf7EXxYj1ZZbTwlqE0TgNuUDHsOT1/8ArV92fH74hz+E/FHh+2LFLW51S0hbDbcmSVVHuevTvXtbSFQcYIA6ADivJ9lHm5j6mrmdadH2T2PzO8MfstfFbSGjjfwrqls54VgwyDjP972P5Vhar+xP8TtW8QzXtx4Y1N3uZSzOwDHB9ic8DtX6li8iMq5dA6kkBjinGRXbIIYHj1xXq4THuhrFI+YxmWQxMeWbZ+UvxR/YZ+JNzDBBaeFNUuUIG9oot2w8cHH+eldB8CP2LPH/AIUsNQSfwrqlvJPD8nmQYVvYH19vev09Qc559xSNeBV5YZ7itcRmc6qtIzwmTUqElKLZ+Jaf8E+f2i9S+Jd0txonitNHe8kZZVuSUCZO0L82emAMcflx6pb/ALCnxRTAn8K6u7gbixjJJx75PNfq3bX6h2AkGS3IPY1ciJKDoccHvXjV6SnufU5fmE8LflVz8qbj/gnJ8VfHPgm5l0LSoIb1WMOy5nSFonGM7gxB6Hjg547V53D/AMEd/wBp6KLy49TaKHOVjTXgqjOT0D4HTp+Ffsh4TZpbzW9wwY74ouD28qM/1q5qWr2+ko0lxKsSZ+8x4ooU1T0RWOzGriWufofjbD/wSC/adR1267cAFQcjxA236HL9eBTpf+CQn7Tscj41+5dQPnK+IWx9PvgHv+Qr9h7DxTp+qvi2vIJW6YD85+lX4owCSSefU11qp5HmNX1PxqX/AII8/tMEAJrsql/vE682AMY7P6dqcP8Agjv+0yzgf8JC4Zjk515iT+O76/nX7LNnYVxuXHB9qyrjxJYwXW1rqAPyArNjFP2vkRyn49yf8Eav2k3mUvrLZICFjrpPy8jB+fOBn9a4vxh/wTA/aV8LeIjpSQ65qUwtxOXttUMsZXcVwCHPOR09CK/cqynW4hDKcg89etYNrPt+LMqbiQdMDYzkf60801Wa6C5T8QoP+CYn7TMrqP7G8To7HaT9tb+e4VZ/4dSftLujSnSddbjDA6iAcdOhkHGM9fSv3Te6EOBwF9cYqNNat5ZSvnxbm7Bh7CmsQ+wuQ/Cyf/gk3+0xLJzpGssSSfm1IHr/AMD74/Skg/4JE/tL3EnOi6oA3HOpoB0z/wA9PQ/mfev3dimLgYCkdORS5wSACNvtR7d9g9mfhMv/AARw/aOkAzpt185wc6kvHHf56S5/4IwftGoxJ0uZlI4I1NRnHbl6/cu91eC0K+ZKkWD/ABMBmrUGoLcqpWVWXtg54pquw9mfz2fGn/gnH8c/gVZ2V1rGi6y39oymKEWs5nLEDOCIycdDjPpXAj9mz4vOyY8O+L28rDDbFMSn5cjpX9HviBh/wk2hZClGuJB1HI8p/wDCtx40Dbti8cnI4FWsTboQ6J/NlY/sj/Ge+Zlh8L+L2IxuXyZsjnjisbVfgL8VfD3jjSPDt7ofia0vvECSyaZbyrKrXzwqHlVF/iKoQxx0H1r+l25kiQZ/dr78V89f8FHP2cL79oH9naa58Lh4fiF8Pr2Lxh4PuI4llk/tOz3SRxbWIVhKN0e1srudGIO0CqhibuzMqlBpXifiL4k/Zb+M3hLwrqWsaj4e8WW2naTZy311NKsqJFFGpd2bPQAAnmnfDH9iT40eIvBdhq2keFfE8tnrsSX8U8UUipcpMoYSAjqGRhyOoNfpv+2l+1do37bv7D/wY0nQb210aw/aA8QWsGuQ3Mxin0vR7BnuNalWVzGu20e2VXkOFePdgEOCO78U/wDBRnX/AI++Irvwl+zP4Mh8bDT3ezvfHGsvJY+ENHlQou1HVd96w3Y2Q44KOvmISRd5KO39IzvBzun00+Z+Wsn/AAT5/aEXBbwj4vIxuGBKR6+vX/PWrOnf8E8v2g73UI7Y+GfFUDzMFVpZHVM/7xOB/wDWr91fgL4f8WeDvhHo+meOfFFv408WwRP/AGjrMWnx2Ed27SMwCwxjaqopVARgts3EAkit/wASxB7RQFACTRHPc/OK53W1sdSp6XPw6tv+CTP7SMyZbSdVTI6HUMEHHpvq9Yf8Ehf2jNQZ1a2vIQnGJNSClu3GX/n71+40i/KCCcVn3eu2lldGGW5hSUjOxmAYj6VPtR8h+KLf8Ea/2iGc4jkLk9Tqi8gdOr1N/wAOcf2hgA/mOrKPlxqvJHXj5h3r9roLqO9jyjqw9VwaJI2A5zgCj2zFyI/Gnwb/AMEgv2gvDmv2moXEyiGGQO+/VcnGfTdz619zeFP2XvGsPgyxtL9Lea4t4wGKzgqxHYdO1fT+uatb6ZZSvcSxRKqkku2AOP8A61ZWg+O9N1aRYYLuCZxgbVcHNRKpcqMT5r8Q/s0+INA06e8nSIRWylnKODx3PvXmN8vkthlztyOlfcnjy3a48GauI8bmtJR69VNeL+FPhdouraLA9xYo8sq5dycHPPNRzFNWPnSJ2a4I+bHPQf59KmniIBK8kDgEda9O+JfwTvbbxNL/AGdYubUY2BRkEcZ/z71w3iXwvd+HJFF1HJAWHAbGDVJkmJJF+6GBySenrioLlMrhjknseP8APevV/gp4E03x1p93JMpmeIMse05+bbn8a5PX/hhrFteShbGbZvwOBx+XQVVxNHFtAM7uSSOTk1UurHzlfJAHJAwTnHPNb11oUmnXey42xnocjvXpGofBi0f4bDULdZZrssvC9CCCf8P88UCseCXunGPIZdvt0zWPe6ZHOckZYZxXomseE7u2jeSa3lRYxg7h+FU/Cfgu38QeI7eCZwiSsFJU888cUEs8vMb6bJsfI7qcfeqaG9DsFJJJ+XJ5r2b41/ABPCSwCyR7mKWEOX6lTn/9XfvXkV74H1CxIcQONx4Xng0mhotRzedCuXBcZyegA/lWjb3LR4IOPXPrXW/Bb4Jr42MkVxP5TKoIQLuzxz6f5Ndn8Rv2aIPBvg+XUFuTJsZVI24JycUKyH5nkRvmA7dgSO3v1/ziq8chaVmz9MdqsNpu+QhchV4Hv+XFA0jzOQfcfzqlqJ7luwu5CwUSEggg59KvtqSRW7kqryEY+p6UaB4J1PWYw9vBJIqryfTP/wCv9a1o/hlrAbBtnDDk4BOPb0p7COP1BbnVLjAUhP4qtaX4GkvAHmkRUOBgn+f4V0qfDfWB920lPOD8p4/zmnP4J1uzTaYJkx065/zzQmA2w+H1lGN0jLuPfPX2/wA+1bmnaBZacQ4KDH6/n/niuK1ux1HTZtreZG/YZIzmsLUNU1CyhkZJZAVOWA4Hbn/P9aLgeu309rDAzhl2ovQdKyfCXiYSeLbcdUMo9Tjnr/n3rx9/EmpTXAMk0m0Dn3+ldx8Mt6avavKZGG9ST9f09qOYVj9I/hf4Wsr7RLORoImDRgnIyeneuE/ap8F2OnRKsEMaeYMkKMf5/wDr16Z8D4WuvDFhkZygGfw//VXln7Wf2+6+IDWqI7QRIuNo6MR/+qjmBM8P8PaWI9VQt94MBx3Oc19B+CJduhImdysAc5yCegrj/h58Hnu4Yru+jaFfvAcENxxg4r0i3sI7KERquwfdGPpikrjKE567Txj8veqc7Ek4JwDyOuKuXLgTOBx6e1Uy2889uKGgPBEhEaMMgbTxyf8AOanFw8MxPA288DH+eKY7bAWBIK9cmsvVdbFpb8hmJHrXEjpsX73Wo7MNvkxnoPU/5NcxrfihZJCibdpPToxrF1PxPJdyMu4lRyDjAHbH6frWVc6g0kIDAnJHX6//AFq0JaJtVu2ldsAFW43f5+tUIlIALDnntwP8mpQ32iTOVHGcmnCJXXDEL1PHegYqqGCkKCe49aeUCoGBGfccVHF8uSQSc44/zihv9bn7o9e/0pCbHW6FlwzDJPpj/wDX/n0pWXC4Bzkf5/P/ADmpUIVQC2Mio8qZWwN3Oc56ilZjHCPco4bJOQex/CpOV+UjkYPT3p8eQqkKD/snp16+lLnz2BK4ZcA88U7ARPCC4wRz749utSwx/J0HDYweeMZqOYkkYClh7479acke1gT0HYZoYCs4jcHC4PPA/wA/5xUnn73QjIyOnXk9f5U3aTuI4fr0/Kkj5ccY59elRcCaORVdt/OOM4z3pwRZSCAcAYGP8/Wlh05rhsAFtxx7jmtOw8OXVw67YiO3FFwKKwbFBUjPYZ7VOqncdvYYz1PrXS6f8Pri7kAYDcBgHqBW7pfwmDBS7ADOMf1oA739mKJV8GuuDxKcEe//AOs16mttggHpgYHrXJfCXw/FoOhGFFG0NnjiuzETPjaAT3z1oA4j9ovxWnwx+EOrazKW8u1hdyR7A1+Nvxds/F3xu1/UvEOpX91YWjF7i3syxUCMEkY564+tfsf+114Cl+If7Pms6bCX81VErAdWRSCw/wC+Qa/NL/goxo8nwU8TaXoOjWv2+w1nRbfUIr0ZYRCUOrxggFSwZSDzx0x3ppjSOY+EWg31p4Nils9Vlt57dFKM3zFW7fUDHAr9N/2HfiRrHxO+A2lXGuuDq9nutbmQg/6Rs4WTHH3lwfrmvyD+Fn/CVfD+BJ7e1lvZbiQMbWRWOew4BzX7HfsZeGtR0f4E6LcaraCw1LUYFup7fkCIsM4pslnppf7LcRSYDbGBIFXNUki1OJNhBDfpSfZAexI6dadFZpFIPlx2yKSYtWR2tqIogFzjtnPFJcho7WWTtEpY8dhVtIPlOQeT3+tEtt9p0+5hJ2GeFkBwCFJHBxTuET8kv2/vjX4j+MPxR1Wy0a6ng0PR5WtpZk4aaQDDgHPRenGD+VeNfDaLzoGWbV5oruFh1uCrBex59OfpXqvxMtpfhn8P9ck1RGXUtKvbmK8jKnzTIZ3BJU4OeRz6c18m6bo8viUX15LM9ig+ZVdz8wPVRxzgelXFXKP1j/4Jk/GO81mO68PTalFrFlEv+izK2WiZPvIe3fPrX2QIjHnjAJzk18Hf8EbvgHH4W8Iv4giWfyrnnzHY7XcgjC9MYBOfw7Yr78ePy8YHIpNAfMX7c1lNHqPhZ4izStrmmqAvPzfbI8fzHtXu3xh8fW3wo+Hl5rV0CohU7AQWy2M847cdq8N/b9RLM+FJ2JKpr2mFjxwReRfN+Fdf/wAFJXaL9ka/vEJQWkgVyDjbvIXn/PXFNIpM+MfGP7d3iHxD4jubk3rQQFz5cbEYXk44xxXsH7I37bD+J9dt9Nv7k3Dzj/VlwwOBzg+uOfzr8k/i98Yry816a1tnbCyHCqxxWz+zV438daT8V9Ak0e1urm4fUIgkUZOWJYZGO4/Cr5A0P6KrUi6jR1BKuoYH1zivlH9vv9s6T4N3zaBoM0ceohd13OTgQgjpyMZ/Wvqfw2WtNEsBOrb0t4w4J5yFGRX4o/8ABYTx5qcH7VviDwzBNLCJLgTXEwJH7t1BRc46BSPypcqFY9F8H/8ABQzxBY+LNreJxIFcEK8/BYsOOuO2a/RH9jv9pFPjx4WlW4UR6np4VZwWB3jj5h+OePavwBvfDml2vlpErXjlcuxPf2xX6Wf8EKo9ZX4ga1DNdTXWlR6cJY2f5zESwGzd+P4UnHsUj9NvCKLjXnYnybe9Z2Y9QBBESSfz/Kvzf/bG/bJ1fxx8TtRsNN1Caw0fTZTCkavjzGVuWIzg9B/9av0g8JoZ9O8WQKC73E8qKoJBLG2jwAfxr+eD9qX4oX+nfEzVtKMcq3VncyRyo2VKuGIIPvnNEVdg2faPwY/bF1HTL2Jrm/EqhthlR2L5BAznPXj+dfpT8D/Hp+I/ge21AyCQtj5wQdw6jpx+VfzheDPi1rei6vEUR2bfwEzkk+g9a/fD/gmwNSf9k/w9earDPb3F/H5yRzLtbYSdpx2yCDV8tib3ND9vD9pxP2avhUk9vJENX1TelvvbHkKoG6Q+gGe/f8cfl1rf7fl3deLpUk8TSzyXBxI6tuTOegPTAOf8a+hf+C+WheIfEd98P7W0EkWkak1xb3FwjYVGTa4Rvcgsffbjtz+ZuqaJa+H9YW0ECS+UwWVyhLA5560KIXP16/YG/a61LXfENlo1/c/abG+wsUjZYhjjHJPQivsizk834rqp3Yk0vIG3/prg/wAx+Vfjn/wSk1m81/8Aaf0PwxYGe4tLnN0Bg7bYxruJz2yoP6elfsrp4MPxjslbbsGlscepEqd/y/WhobXU+SP+ChP7bl18PPFt34Q8Ozi2uLJU+23GQNrNzsX6DGfxr5w+G37ZniBdQge71KR3Vss5kY8c+p+lfN//AAVT+I+u+E/21/iLpFzFNE0OrzMu7KgxuxeNge4KMv514b4A+MGo6PqcLOzqMjJDdfrSUBM/oI/ZY+MTfFbwksksomkjUHcTknrwfyrc/aP+O+mfs8/CnUvEepYb7OpS3h3BTPK2dqjP4k+wNfOn/BIDVLnxJ8LL3VJEY2sriKNv4SdoJwe/emf8FuPhf4i+JX7K9jH4dlli+w6tHNfBCQ3kGN1JyP8AaZR6fN9KLFWR8cfEH/goNrHxC8dXU8/i5Y2mdlEMUvliNSflXjjgcZ9ua95/ZQ/bC1vQ/EdnBfXU15ZTsEbdIWGD3578D9a/KG6+Hllp2qSW87uSDwwbj+VfRf7DOtaxpnj/AEnw/cvLdabqsm7Tn6ncJMMoPUj+RFNwstB2P3Hv76LVJ/DNzEDtuLskZPIBt5W/wrzX9tr9ra1/Zl8JwQQKlxr2oxs1tCT8sagYDtyOM8cV6HZ2b6RZ+DLeddksVwI3A5wfssuf5V+Tn/Ber4keIPDP7aFxaN50envptq9m27ClPL+bHtv35981KVwsevaP+3/4g8UaiJr6+dZGPCxN8oyeOmOmfrX1t+zF8eW+JFnFDPOs24EI/BZmHXJHfj65r8Lvhz8eLiLVY47h3wSFw5yMV+o//BMLWrnxJe27ruaCBssw55YA80+WwWNHxN/wRs8Ap+1R4p+KHjrXBrPwsgnu/E1l4Nu1lWz0rU5zbyXdy7ebteJ3gZjFsVGDIrArHhvJfiP/AMFGHXWodC8GW+k+HPB+kYg07TbGGO3VIVPyAIoxGMY+VQAK+1v+Cjug6vr/AOxD8QLPQ3mF/Lp45iPzmMSKZQOCfuBq/n7k0JtK1iZbiSTzUflt5OfXJrSUpTtzPYyhRhC/Ktz9VfgN+3V4l0/XoTfXBubeaQbkY5UA5yAfx/DjHv8Aedl4lj8W+BLXUISdly0LjPbLrxX4p/steK7jVFhsLt97gK8EpP31J9fYjH41+wfwHsZ9M+A+krdrIJHELjd3HmLg/Qj9DWDunY1sjhv+Chv7X/8Awyx8PrSz08xDxHriM9sz/dgjUgM+OMnPA+hr887T9qLXPEOqG51DVpruaR95LSNg859fU16Z/wAHEvhDX4vFvgbxRYwSNpI05rBpADhJFkdtp4x0bP8A+qvz0+F/j65GpIksjBtw3ITnv2z3p2drmctGfsD+xd+0le6jcW9hcyzTWsjKgUjIXJ4xn/OBX19rOtW3h/w/eajeyCK1sbd7iVycBURSSenoK/N3/gnPpd14t8VQ+UGZLadNzY+6uBjP41+g/wAZPCEvxA+DvifQrdsTatpc9rCwbadzRkLz25xU6rQasflZ+0T/AMFF9W+N3xJvYYNZ/s/So5mjtLONtqBASAWPUkjGece1S/Bv40az4Y1mO5W9ndHYFm8zkY75r44+KHg678FeK9Q0vUbOWy1GwneGVX4MbBsEV6/+yf4jn1a2bT7wiVLVxtbuVx0/z6U2gVj9d/hr8Q2+IvwcvLl3fzFspAWPBOEPPFV/hupn0OzJALeWpPHQ8VX/AGcvB8mkfAWZ5YjbyXljMypjGFKHHHb/AD0q98Nov+KdtGBB+Tr6UiZHUatEEjX0I4r5t/aluPN1ZIg3l4jL9O/evoT4meMdM8BeF21LVbuC0tIlGS7hS+ew9Tk4/KvGpfCdh+0paR62lxNZwOCkIVQxZR/jTTIaK37CsbS2V6H371nYADoflHPT65/CvcPENgLYFyuByCOPSuS+Bfwzt/gvHMkFy94szb8su3Ht15/Su413V4daOBCF4x170XYWPi3463DzeKLkgHa0x46LxngV9NfAOwA+F2ntnzMQKCSOvHWuH8b/ALLq+KtUe4/tIRK0m/Hl8+uCK9R8D6YPCfhmLTt4lMUYj3hSN2OM9T9a0buCRy/xcCQeG7sBIx8nUgHvXzJ4Nupl+Kunr/AZwucevH9f1r6v8d+GH8U6WYUkWNmPVunuPevLtD/ZhudE8ZWupC/tWW2kDkBWBYen+fakNRPTfFviLRfCXhyO61i4sraKNB805Uc47Z+hr5/+N/xp8J+MbVI9Ku7O4mizny0xnHA/r1r27xt8LLHxhrlrqt5aRanNpyBba3uGJhiPOX25wX6ckcY4r58+MX7CWuePPiZJ4h0m80vS45juktUUrGnYBce2euKIy1CUTV/ZDv8A7drt8WbdgLx1xnP+f88ezfHFA3wtvM7hhl5Hb/63JrkvgF+z5f8Awnmea9nhnkmVRmMng9xz2r0D4meG7vxX4NnsbbyxJMVILtgAA5NVfUz8j5KeziZm+X5h3AHy/jSxW6nGUHbaOlen3X7M+sxRZD2zkt1Vs55+lRD9nbXgo+SE85yX6dP/AK9UmDJvgT4ytdDvltbrYqu3yk4Cg+lfT+haPYajbxusEUqMAc49QK+U5/gxrPhuF7yWDEVv8xdW4HOPTPUivVv2a/jErSHTLty7pjaWBFNjSPboPBdl0FtDk+qipp/B1hLGV+xwZ6D5R1rSsbkXADKVIYcc96szQCMFhg4H+f8APtSHY+TP2i/BkFt4ocLCiL2CjGe/5e9eKeItGjMTblB7FfXFfSn7TMTJrrNgfOo49DXgniNDhgRyx5PX8/8APagXKcF/YyDBKq6YyCvWul8DWwj1GAgZCsATurP+y53AsV+nY1veEbc/b4wTg7gQx9c8frQNRP0j/Z3iDeFdI2g7XiQDPqQM/rXWeL/AlhrvicNcW6O24KSa539m6Pb4J0t8ZXYrLkdB6fpXd67GW18Mpx84PTrQZs434q+GbXw/HFHbRBEPYLgV53qSNJjnHOeP8+1et/G9NyxYxjb3PBrya8O0txkZ6jtVJoEzJmB3MD1PPI4IqExsiNwSf89auTuNxGNpHGSaq3B+Y7fmJ96bVxnz9qZa3ty2OQCRk4LVxXiTUnjTcDwMnG3oMe1dXqqO43KRgAnpz0x/hXGeJLSSSNgQflPy7cciuJK50HPXE4kPmA8H06fWmSygqAvfPIqq1s6Sne2VDevHp/jUsUPmsGHKdyD0561Qkx/2tS4BZSQdvHb/ADxU3nmVWxhSOB7dahMKxnq2frx2qUKxjAUgnocfnQDY5F83ORkDkeh9aUrnAOV2nJPB2/8A6sn8qWOPK45/L+lLFbbmXHYY5PUdaluxNhQ3mqoJDLjrjv8A1qYhRCRzu7YHWnW9i5lTKgD0xitCDwtNeyAJG4DHk4P+fWi+haKEJEke3hcHB4yasJGEiwCSQcHn9f8APrXRWfw4lYL8pHPJ9+1bWl/DTymDuDzxjAoT7gcHDYPONypnJ5AGO/etKx8OT3mcx5B4HPQ/5/nXo+l+Dra33b06+q549q04dMt7RSqxgAcjAJobA880z4dSXB2soV85JPaug034WR253S4Ck5HqTW7Nr9tp+VwNw6gc5rK1H4jqkRVULH1GeOfapA07bwXZWydFOP73TP8A+ur8UFjYou1IgcdsZ4//AFVwr+Mry8cKGKjsFBAHP/6q6Xwp8LtX8Y6elzHdW8COeBKTlhgegNROVlcDRHiK0tx99WOc4HNMX4g26yfIBu9SR/jXJa/o0mi6jPZvMk0kLFGaPO1sHkis+KDjduOM18/U4oy+EnCVRXQ7H0h8HdUGuaCZsFSXwRnqa7e3TYm05x29q8K+E3xbsfBGhC2uYZ5nLl9y4xzjA5Ndkn7SWklSDBdJngcKf68f/XrN8W5b/wA/UPlZ6Nc24uoijj5WG0j1/CvGPi9/wT98E/GAym5W8sjKhXZA48tSQeQpHB5B4OOPrXSSftJaXGmBa3bvz/dA/PNOj/aY0+NP+QfdOCMjDKMUf635Wv8Al8vx/wAhqLOQ/Z1/4J3eC/2etRF5FLfa5qKkGO4viMxYJxtVQB0wO9e92toLePavyrjge1ct4J+M2meLr6SzRJIrpEM3l8ZMecZ9v/112tmgu7cuinHTJAr3cHjaWKpKtRleL6kO5AqFWbOD3zil8oA/1znirJtgkgO3r0yOaDb7evT+VdRPMQ7MoAOnY+9N2kcYJPc4HFTSQkKdvTNLBGSSfm7E47U2ho8h+OX7HPhf42apJqNzD9i1C5TZdTRIGW6AXALoeCcYGeuBz7eZj/glL4H1p4k1e4udQtYWVkiihWDBHAGQTx7fWvqpkwpGM/h0qWGDzLeNyPmfII/EimpDOf8AAXw50n4ZeGbXRtFsbfT9Os1CRQwjaqAADnuTxyTye5rda13LkAnAqeNASB0H51KbXMPQjPai92B8hf8ABVLxFa+DPhXo+r3kgittP1mxnmbBJVVuoiTgcnhf0rrtW/ad8B/tD/A68064h1K50DxTp5QsIVWQqw4Kg/dYdQSOoryH/gukhi/ZPnkIKkXlsAef+e0ef6V57+zDEH/Z/wDChCtj+zox75A5zWkTWEbnzN4z/wCCX08XjTU7jTdftLrTZJmktZbqJorhV7BgNwyOmc84z7V9GfsG/sreC/2fNRtfEviW9u/Eet2b+barBEi2tuSGG7lsucHvjHoetc1+134h+IWg6Mw8G2MNzbPbyteTMQr2wAHK/MMnBY9+nTtXBfsIeMLnR/2YPEGr3dxNcDTbu5l/eMSQqxIxHr1zWiTK5UnY/Sy7/bI8LxzCHbcK5X7rFA3/AKF9K+UP22Pg34M/aR8dReKraO5sNTMAtr3fCjC6jUkoSd33lJxnHIxX57x/EvSvHtvqOt+I9b8Qw+KLm6LWk0OWt7UfKQW53AZzgJ0x36V9f3/xQ/4Qn9kD+37rWIdZuV08xwX6I2LmRvljJB53Z2hs9wafKUonhnhD9inULjxDdRxTafdQiUqAQeBz14IHoR/Ov0W/Yhg8FfsjfCxdIsrTUbrVL4+bqF0yriVuoRQW+VF7evU1+Yv7GXjDVfg3+0D4fbV966d43tjCjSMcSB5CI3+vmKR9G96/RmygaWNWTIBx+PFTO6KjBNH0b8Lv2ofCmpaz4qtv7UigvrTUo3lt2yXhV7WAqTgd8HpnvXgf7YX7AHwN/a68WXHiOS/m8L+Kb3D3N/YoPKvSP4pEIxvPA3DB9c15x8PoJIv2i/iMrbiGOmOpYZ/5dQCPpxXa/FP4j6b8JfBN1r2syy2+nWJXzpFjZ2XcwUfKoJOWYD8amLsyXBMzfgJ/wSo+AXwc8SxatqWuXfime1w6RXqhLfcDkEooOcY6ZwfSvsmx+LXhDTrGO2t9StYYbdQqRqpVVGOAOK/Mv9mv9tm//aK/aH17RLW1hg8NWVmbizd42W5fayLliWwASx4x0A75qn8Zf2tvFsvxpvfBPw/0/Sb2/wBJi827ub+X90pwDsHzqMjK9T1OMDBrazZFkfol8cbH4aftBeCp9D8Ry2d/BIpKbgcxOVxuUjkMATgivg+9/wCCS3hpPEd1/ZHjSzjtLhiUivLQy7B7NvHOOmRXS/srfHLX/jB4Tvh4l0R9F1bSZRDKQjLDcjHDpu56g9z255rw/Wv+CiWqaP8AtSr4fC2D+Eo9VGnzT+UfNwCI2cNnGA+T06Z9jQlqVyo+/f2L/wBmT4XfsgaS09hq0Gpa/ND5U2ozKFKISCUQAfKCcdyeOtbfxs/bN0f4VftBeB9Jhgm1UeK7K9to5YHCpA8Rjky2euRxx615rCfNVXU5B5BB7V5B+0pZCf8AaW+CLhVdhdakCWAII8iPj1o5b7g42O9/4KA/s8eBv259Mh1Gewl0DxdbxrHHqsSLJ5yAHCypkbscAHOQPUcV8u/DD/gkboHh7xTZ3fiPxXfahZwOHltrS2WIzKOq7mJxnp0719oXVu8VqSo4xnPWvg/9pP8Aab+INz8YvDelvpOpeD9L/tcRRuzsDqqiVU3ZKjK4OdvI+bntQl0E4o/TL4SfFHwn8EPA9l4d8O+HxpmjafGIoY43AOB3JI5J9c81p+KP2g9H8X6Hc2F1pT3NpdxtFJG7qyyI3DKR7ivgX/goP+0Nq3wo0nw/oGi3w0288Qynz7zZ81rApUFlJ6Eluv8AsnpXM/sjeONUk+N/9l6V4+m8Z+HPsxkuVv2dbhXxjdGsmWIDYGQcYb6GhILLY6z44/8ABPLwN4kui3hm3utHeTcWE85mw2cjHQ47HJPX2rvv2JP2UvDv7NPjW08Sap5+t32mK/2GHAWGGR8BnAOTnAGB69a+ff8Agop8bvEL/E6w8JeFL7U7ebS7Nr+/+wTPG4JBOGK4OFQbjzj5hX0V+xv8VJPjH8BNH1W5m+0ajGhtr185YyodpJ9yMH8aUloNJPQ+oPHX7VIjk0GaHSm3xaiD804AOYZR6eprwv8Abz+CHhn9vix0W41m2k0fV9EDRxX0BEjPE3JjKnGRu5HPGT61seJbNp4tMVcYF9GffG1xgfnWrqFhM+ly+UQJnjOxicDOODz71MUNwR8PeLv+CYfw80LXNMtLvxtcabeXkm22jIijkuCDkiNSSWPtzivrz4L+J/DP7C/w2O+4sorVfmlvb9xGZG7ZOQOmBgV8LfE/wN4x8C/tpfDv/hMvEMOu3d5fxSW5jVljt0E2NgG1QM+o6966T/gpT4tv7v48eB/Dp0+41exji+0jTo3Kfbp3kKhcjOeAB07n1zWjiQfe2gft46b8ZdGuk0K80TVrZ1MNykUizptYEFWH0PQ18Iftn/Bf4Z+HNXBlubPw1e6s5a3hjiLBcHkAA8ZyOT0/SpP2OtS03wv+0xqWlan4duvBniK5sfk05Jt1oycEgLgEN0I5Ixu6V5H+1tqkXx2/aD8ZXD6ta2ll4Ss2islklAW4eIgMi+rM27p1wKm1g6H0p+yx+xfZfDK4g1W+vH1EKoNvGFAjUE7ueTu+nv8AWvtaX9oG9t/CTNdeStvYqjHYm0kKy4/wr5e/YM+LKfGH9nrS5JTm+0oGwuRuyd0eAGP1Ug/j1r1/XLc2/gvVOflaHB/Ej+VZzRfKjuPjb8UPAn7Rfw4uPDviPQLnV9KuvmAbCPC+Dh0OcqwycH6delfClz/wTV+HWmePTqMOq+IV09X3pAY41cg4yGbJH44/OvpG2tRBpqkAqSOx78VxvxgXVLb4f6xJokElxq5tytoigEmQ8A8/iahMxlFHo/wL+MHgj9nrR/7H8O6PHbSMR57PdAyytjG5u+fp/WvRb39tH7HayTvp1utug3s73OAv1OOBjFfkf8SfhZcfB7wDp3iHU9c1OHx9qV4WFqbjMiLu++e/pznBLYxXuX7TvxG1Dwz+xzo9lfK8Gt+IobeGVDkHG0O59ewH40NEJnov7Snw78Gftn+LZ9bgSytL8SbZZ9OlDCVscl8DBbPQ+mM56mX4Jfs06P8AB/UIbmK3jujGEBSTOJWQdW6Z3Hkj+lfPP7DPiG7+FPxSvPCWpAZ1SJZgoP3ZNoYY9coTke1faa27OgK9CcfQVMrotWO+b9o7XLzTZrFY7OOCWEwKixY2KV24HPuKi8eftSeGv2dfhfaXGq3cUt/Lb5trKKQGaUgenYdeTgcVwn2N4bWV8Nu2kgE7e3ODX5tfE/4g6r4n8ZX0l7e3N0yyMi+axJCgkBeew9OlXEho96+K37Wev/HrxQ9xqd5MlkjEW9mr/ubdck9B1PTJ/Kvuf9ixfM+Cenfe+TOM89STX5P+CbmW5vEBLkEjI9Oa/Wj9hi0J+AOjtxkx54GMfX8zTaE9z1ZozAFJ6E8cgVEZlhy24ADrz0/zmqnxOSRfAmqGHeJfIIUoTnOO2K8Q8TeJdR17wto+mWr3Kx2wCXrFWUOeMZI69/zpcomke8yXkZQASJnp15/CmS30KId00YJ45YCvnHUl1Oy8OR2ljNfveNI4i8sNt2Ac/gCRyadp2lXWv6gYIbrVTBa6f5hZ5X3mUAA9eM7v55FNpiW59GLco7EB1I69a474o/GfS/hZZrJdu888ufLghw0jY/kPc8V5PO2q+ErfS7pLvUZ3u7ZmlJkLNHnHHt2rz/xDqXm/G/w816zSQtmS4Er7wAMn5t3H9KiTdj2cnw1OviI06mx7J4R/a503xDqkdtdWF3pwl4Dy8qT6ZFex2Crf2SyxHKMNy89QRXyv4q8T2Wt+CtWKfZhNDfCK2EeMhAM8Y69O/rX0V8Bkuh8MdMa8Mi3BhUuHHzDjvU05Ns9biDKaGGpxnRVrnRzWBkjwpA4weOtVr1/sdixYhQASSeiitSVhsJAztyeDzXneqfGLTLyWezeK6VclMldoPrjvjPHatj45x1KWjfEa81OHVMxxvNalpIkAC5j7Z684611vha9fVdFglmVVlkTLYGBn2rh7/wAb+HNCuzHiSN3XygVQnfn+ZrofCHj7T9U2QW+8AAEbgQef8aaG0aXjxd3gzU12k7oSf1FfNWiaxJ4f1NbmA7SrBtvqPevpfx1sl8C6r90HyCAx4A5Hb86+WdTjLfd4C9M8eorTcEj7E+BnxPi8aeHom+bzEGwjdzxxXo/m748A8rzXxZ8CfiI3g7xHDvZhFKVRlJGOvX+fevsHw5q6avpazIwdSMgqcj86lsdjx39pe2/4nAkCn5l5OOnHSvn7xPax+UN3LP3xnNfQ37S3F1GRxhQc5zXgHiGElc4GF4/H3piOPkUK3Ixjkgdcf4Vr+GMG7jwSSWwVx15rLnK/aNvBJ4/GtTw2fKuEOFPz5GQeOai4H6afs2wLH8OdGXk/u175/U13mtWu7XlBxkMCD+Neffsu3H2j4Y6K7HkIB15r1HVbdX1tWP8AeFVczkjnf2jLQWUEOwYLRD27V4ldkB8Y+6MDHavff2m7Q29haEAAlBk9McZrwS+OSc8nJH1poSRlzH9/jBAPOe//ANfrUUqMzg55+6M96nuNqOMDufoKgkIYE5zj3zQxnz8YDMvB464I6H1rG1nQBcqQg24Bwc8VuwgsoOe3Oe9SGLzOCOCO/p/kmuZI2bPL9W8KtFIxy21j0Bzn8qoNo0zNtROmSePz9a9Wbw6k74Y4UZyCKb/wiUTfMq87gW57UdRWZ5aNEnyuYjlfoafaaBLKCUEmd3IJ68cV6cvhqJZNxC5Tp8v+c1esNBhU7vLT6dwRSbBHnll4FnuYiAgIbncDW9pHw42SB5iNu75uN1dpHapvUBRgdsVbih2k5x68CkkFr7GLYeCoLds7cE8cfN71owaBHaSj5UBPHy9sZrSSDKkYAx7+/wDn86l+yjOT06CkyyutokaqAFAHAFPEAXBx+P8A9an3EogXJOcdRnOP8/1rldf8ZG1hPlncetFhGtrPiWHS5FwUfgngcjpXL6v45mkYrEcDpnOcVhzalJfTYfgN68n8K19H8HTak6gpgduMHr2q7DM5Vmu5i3zyE5POcf568e3arumeFZdTlIHyge/P+f8A69dzonguOxVWZQzEemMD0rdtNLSJTt25GBn0Hp+FS7Acbpfw4IZWc4Y8f5/+tXtPw90aK00+3hAwiL0781y1rZbep4HNdno1xHplksrlVjVNzM3AA7k+lY1l7jYI+ePFF0bvxLqDv8rSXLkeuN/09KoKhkGcAhu46VufELS9P0vxJKdO1OHUYJk83KBcxEk5QkHk8DnA69Kw4sIcj0z/AJ+vP/16/mPMIzhiJxfdmqaRHcy3NlGHjgeYOScIP8f88VR/4SWSC8jje0nUSHbuJUjPHoea3rJiwckgBRlRWN4VuXvLAySclpWIGT0B/wDrVxczKubKZkAB4zk9eSfSrER2lTjb6+tQwThmG0fdGTg1m/ETVrjQvAOrX1hG019a27SQJsLhm7cDrRTjKUlFdROXY9G/Z13Xnxl8QNnItdLtUABwAXklbp+Ar6s8EW4/swFsnJ/pXzh+yj4GbSdKk1241a21TUtetLVrlYIfLW3KoW2YLtzlz6fSvprwKoOlDIyWY57cV/R3CmEdDLKdOW//AATJu5DrGnhZiEyoxjGPesyZTERggA9a2vEZKmYj0z+VfDs37eWveH/2dvi/4ie40/VfEXgvxLfadp9jIFVobZJkjjMiKQWCAsxPcKcmvpOQze59iC5IBJIPanLPleOlfA+kftbfGSz8NeL/AO0dT023XT/Dy6/puparZ2kJSbIzbmK3nk8yB1OEk4bdjIPAMPgv9vP4n/FL4X+CvEGm6n4a0vUfG3jdPDP9nGyNz/YyeU5YSjcrtJuUMBkfKR68VyMLn34XyOBjvk9qPtf2a3AJG0E9fxNfn+v7Xfxu8L+EPFOu3/iHwvqNr8PvGUXh29h/sMwvq8TyxoX3CXEZUSAgKPqTjnA/aq/bi+IMdrcXGi66s/hq78Sv4exaaM0Vv5YJUqbt3Ehm+U5CIV4PPrMqbR1YOj7arGm3a7SP0GHxW8Ppr40xte0f+0Wbatr9pj84nrjbndmursbpZoiXKADgelfBkX7O/hG5+xaQ11r/APwkGpeG11mObzIzbRSFWYowwGI4+vv6aOj/ALQ+s6V+w1q91e3dy8+iatZ2sNyzESGJ5AQu/rkYPPoQO1Qr3Pr844Up4TCvE0KnNy2umrb9Vrqeif8ABVH9m3xN+07+zhdaB4Rskv8AWBdwTLbvMkQdVlUty5C9Bnr2rh/2fP2PPGvgP4MaBpGp6StvqNhbeXOi3cLhSCeMhsHj+dfW3he+kuPCWn3Mzl5ZrWORyRjcSoJOPrXmsP7bPgwfAS8+Il3Le2GhWt5Np+yWIfaZpo52g2IisdxaRcLzyCM4raNz4yMrM8c+JH7J3i7xB4T1a1t9LDvdWkkSr5yZYspHOD6mvDv2R/8Agnn8SfAvwF8Q+F/E/hyaxn1aaXan2iGQbJIVQncjEdvWvrfT/wDgox4DXwxreqatbeJfDn/CMXNtBrNrqWmslzpiXHEM8ioWHksf41JA4yBVnUf+Ci3w6tNM0u9gm17ULbX7u6stJax0e4uTq0luMyGAIpMiZOAwG0nODwcaJsbqan5veEP2HfjV8Kvg34v8EzfCjUdVbWpH+z6lEYiuCAisQGJ4wWXuC3PrR8Qv2E/jKv7PfgvwJZ+DdfnD3El5qRjt2aO1LSHYrHpxuJP09DX6LeDP+Cmfwu8e32iW1pea7b/29f8A9kQTXWi3UEEV7/z6ySsmxZf9ncevOBg1ifF//gpRoHhn7Bp3h6w1a+1LW759L028u9Omh065nRtrKspAD4OOARnPWlzs68JRlXqRpR3eh+fXxm/4JI/Fbwv4J0/UtIn8R+J73SHjjtbD7LIGtkJ5MWWOADtOAB+lfa3wt+GPjG++HWkXuueHdS03UDaI9/HJblPJlCjfx2GQe/AxXR3/AMafjf8ACiK68QeI7DRr3R9PkUXtlG0W+FGPBBjYsM5GCdwHpX0l4V8fWfj34UReI9NctbXtg1zHvGCh2klW91IIP0pc/Noz2M0yDE5fBVZtSi3a8XdX3szhfDv7HXg611W+12H+0Fv9ditzdMLkGP8AdxhF2jbgfL19a0db/ZP8JeItLksr63mvbabh4Z9ksbYxjKlcHkZqv+0t4x1PwN+xt4w1/SLmSy1TS/C897aTxqC8Mq25ZWAIIyDz0r51+Pv7Y+q+KdK+Etl4L8X2A0TxDHKniLWtN1eztzbXcdqkiWrXEqvFC7szsQy7j5ZAxzSUTwbs9O8A/wDBLL4X/Db4q6r4u0ca5a6jq8RhmiSeJbZVZlJCIsY28oD1rk/F3/BEj4PeO/GWp63qF54xa81WRpp1j1CJI95OSQBDnHsSeleNfFz9rn4teDvgX4G1fSPF39teKJbrVYr2Kwt01SO60ePeo1R/IVVMluDjcuInYZ2nbXWfFD4rePdeX4wXHhj4q6+mjfDnwLpmv6NcWcNo39qXL20splkdoTlHMfKjA+YdNuDrZ2MXJ9D3T4S/8E1/BvwX8FXmg6Pr/i2ayuM+V9uvIpmtMjH7siJcDnODkZ7dc+T+Iv8Agi18EvDHw9urbVfEHiHT7Zr4ahJqV3qFvHKjgFQpkaMAKdxOO5I56Vz3xC/aV8efAPVbn+2PH+v6jp/iH4YW3ifzhplpNLpGoTXcNtut1AiQR/vekpIXAYk855n4W3l/8ev27v8AhCfFviHWPEnhm20hLyKC51a1vJYJHhkcgy2qrGpJVSVwSBjkjArOcnHVHs5LgYY3ERo1HZat21eiufWPwx+B3gDW9HhsdE8U/wDCQrp8Ucbyw38NxIQAAGcoPvHHNN+J/wCw94T8W+IPC2tXNxqcV94Yui1kVkUoxnZI2Djb838OMEdO9eA+KLbS/hf4C8A/E7wNY3mgXt3qU9lPZfa2uEuER2X5i394R8gYHzdsA19zeIMzeH7d2UAm4tjyeh86P+tZU6smerxJkEcuVOpSk5QndaqzTjo07X+Rwlx+zHpjRBDe3Q46hAPavJ/jl/wSr8LfHjxP4a1LUPEWr2j+GpzcQxwwxlZmLI2GJ5x8g6epr0n9sn47at8AvD/ga/0oWXl674y0zQr43KFlS2uZCjsvIwwwMH9K8O/az/ba+JXg/wDaB13wh4A01JIvC/h+HWzL/YzakNTlk8zbG7LLH5MPyAGQbjnPTFbq58q5aG5+0H/wSP8ACP7RPinQtR1fxBqkI0Ilfs0UEey5UuCVbuM4xx61HL/wR+8E2nxr0bxrpGqXOh3GkxBBZWlpGlvNhWXcwGOcNj/gIrjfF3/BQr4hab+0D8OPBaHwjpUPxNsdN1IzXgkaXw0ZEYz28qhtsjSsu2FspycEHrWdqv7YfxxntrjxBY6v4Ni0qL4pT/D2Gwm0eR28ozmGO4kkEwyynaSFCg/pRdozbN3xP/wRU0zWfijrni2H4j63aaprqPFP/wAS6GRFidAhjG5vu7QB6471c+Bn/BPjwL+xNYahZX3xLzb6q6ypFqLRW+xwMMyAvzkYz/uise//AGxfib4ZuPEHgPVPE+jS+LdH8Zx6FBqFhoEk93qVpJZi6HlWu/y1lAbDM7hAF7nBryz9nuW0+L3gX4j+NfidJreuar4Z8UnRpNkyW0kse4KN6rvVSvohIGMDgZqKk2kfScOZTRx+I9lXm4ryV23959p2n7M2g+KLO0ntdaa7t45Vnjlh2Or4GMZBwepp/iX9neOK7tbexu0aSdGJEvy8LjnjP96vJP2eJZvgJ+2bf+A9KuLy58NanAJ1gmfcIG+ziVXx0B+8pwBkEZ6CvqfXgI/HWh/d2vb3aZPX/lkcD8v0qIVL6hxDkzyzEqkpc0ZJST2dn3XfQ+Iv2h/+CVvi/wCL3x/8F+LLDWdBtLTwxMk00c7v5koEquQuEI6Kep79utH7U/8AwSt8T/GXxx4Y8VeG9Y0PTde8OyKVe8DmKQK29eFU9G/n2xX038afjfqfw4/aI+FXhW3WwGleN5dSjvpJwTLGbe282PyzuAGTkHIOeMY618+ePP2+/iOPjT40tPDPh2O+0LwPrUWkzWC6LczTX6fJ50xvFYRQth8orKcgZPUZ6FdnzrZw3hb/AIJOfEyf41at4/8AEvifwvca5Npklpp0dmJkhtnZAiMcpuwoz6k5znNUvg//AMEKLbQtEupPG15pniHXL2d5PMt5ZY4olOOOVGSTkk4r1Gz/AG4PHmoftl6v8KGufBsaaFb3OqSaischN7CIFlgskj38XKl8yZJ+VSQorn/hz+1T8dfH6/B4nxB4FsU+MNvflCmhSuNINrH5mRun/eM6gjB4UnODjlak82pT/ZP/AOCV3jL9mnx14ik/tvQrrwzqzF7a1R5PNgIb5dwKYzt4OD2Fe261+zndW+kXVpLqmlW73kTIgmk2gknr0PTHpXjB/bZ+InjvwJpthZaxY2XjK3t9Xe8tdN0Zrp7hrO5kgWVjK6xwQnYCcsWJYbRgVx/7O3gXRP2jPgpoPj7x7qviDUNX8U6z/ZTGB42CTtnaxLj5UGDwM8YwKxm2j6bIMnp5hKUZz5UvK/6o+jrb9kW+/s9UGpWL4XogYDp64rS+FvwE0LVW1Wy1axkfUNHuzbyuJSA6lFdSADjBDZGcHmuc/Y38e6n4Z+Mfin4aahez6laaK0kllLKSzxqj7CM+h3KQO3NeweEZdnxk8ZW5UZZbK4+uYSuf/HP0rNSucOd5VLL8U8PJ30TT7p7Hms3/AATe+Dtx43/t658NfbtYDGQXF3dyzkHqPlZiOO3HFXPid+wJ8Kvi3PZvr3h4Xz6eCLcG7ljEeSCeFYegrxf4iftC6z8F/wBrj40aRJN4hmu/EWk2K+EUSyuLu1W9+zSLsXapSPLtGTnC888V8rfs0S+P9L8cvD4x8TeL2hudL1GfxVYxSak95aYDvFLudRHHN5gjCiNiDnB6nOiTPDZ976P/AMEzvgr4Y1u21K18MGC+tWEkcwvptynpnJf/ADz713q/s9eD40AW2YA9xOQQfxr81fD0XxT1b4MeI4fGV18TLTxpq2o6RcaYxmmj26PvEeYthwsmCxkyNxwpOfmr0Hxn+yfrvhO8+McWk6t8QZ5PBMWn6j4TDarc3H7yXLTYBIErEgg5zjPem4XBSZ9j/FjwV8N/hP4Sl1XXV+y2oOwATszzEg/Kq55J5r5K0jwf+zh4g8UT3F58MtbS1upTuvZp5XjBODkqsnAJ54z19K8T/aytPGOq+Nb/AFu90PXNO1S3162aJLtL66upbcquWEnFtFbcYCAF898Ak/ZPj342aPreqeItDutU0dtBuPDYmtY08tUW7KAkKQNxfPOOvTisptxZ93wtlWFx1OSrU3Jrqnsvu3Ou8P8A/BPP4K+I/Cq3OkeGLOOG8h3wXUM0jkbhlWGWIPXoav8A7MPhMeFfhnFpxBBsZZIj8uAQHI6Vof8ABP621GP4B2jXwmSM3Uv2USgg+VkYIz2znFcR8RP2pNF+Ceo6tolrE13rEd9OPLK7Y4v3jYyT19gOuK0TZ8rm2DjhsZUw8XdRbR634j1Oy8P2sk97LFbwIMMZGAU+g+v+fpzPhD4k6V42nu47OL5YCOXAG/8AAdB9a+WvEvxS1b4las13qF68xzuRAcRx85IVegHQfhWpoPxMn+GK77eC7l+1yKjNEnyKeByxOB1/z1q0eckdP4//AGx7zwP4gnthommzrA5TIcqzLz+XT8qwv+G/Jlct/wAIpZBcEYWbBP1+X6dq2Nc+COk+M0TUVvtPhuLj5nV33SFiSSW6456fhWNL+z5bo7D7VatjJGyMEfyqyRD+3+HwJvDFttHAAm5+o+X/ADiuP+Jn7UOmfFCyjgm8NC0mjyY50lUtHk9MbeR0OK7Bf2dYHOPtGnKMceao5A/DrUeu/APS7C2V3uNOllQYVYovb1FS4o6cNiKlGaqQdmjybwd450/QvEUFzPpTakkTK4ikl2ocHuAOfp0P0r1NP24tctroiPT9Os7ZD8kRBYqOwzke/b8sVzd/8BU1KaKaCWOLywMKE2qw9zTH+ANzNIGkMEy4+YEsDnP0pKCRti8yr4iyqyvY9Etv2+ra/tmhl0C7eTGC8coKsPyyP1rivEXx/gur957XSmtQRkpOwPPJ4/z2rofDHwbexsyFtIgQPvbsEZqXVPgSmu2jRXcU0ucFSJuhq+U884+P9oS0gy17ZPiQ5zEMkdq3vDH7W/hnQchrG+duqlY169s85H61oyfsr2f9iWwtLW3aUsTL5khyPTqRz+Yrmdc/Zv8A7OchrO1zzt2SZOOvY+lKwHcat+3L4Z1Hw/e2n2HVGeeMop8tSCffnGK8VvPjDYTzkJFMFYkBtpBxz2HTiuwsP2fFeMSHToXAGQGkbk/j2/z3rlPGvw0h0udo47RLWeLqBJu3fqffpVRQ7lez+L9i18Qu4YXedyg5x2xzX2P+yP8AFmPxl4Otz5zyR8BWcEE/XPP5818F6f4CuBqUjsrNvBA+XBHNe4/ss/E9PhzrEemztErTOvBxx659uaUo9Quz6O/aWYK8TbS4IHGfrXz/AK4jG1cruLAZHYj3r3T426kmtaTbyL8wkXsePavDfEUIIbBLLyMjr6His7iOHuCQ5IY/KcZzyKv+H5GF3H/EA4xj+v6/lWbd5DuynCgnB68Vo+FTmVAwDEdTjk1MiWz9JP2WtQx8MdHbqqqOAPfnAr2ye6E2pK3ABIr53/ZfvQfhjpS9Cq+nQ9f617dDqwi2HOcH0rRaoTLv7Ul2smm2jJlg0SjOOnFfOt8u+RgDjn1r2z406mdT0qHJPCAfT/PFeJ35HndTggqP8P0pWYijMMjBJx7d6rO4TJYHPb2q677WIPzAnPuP8iqVwMS9xnParA8KhARcdc9Rkcf/AFqdakFnXGGP3ucZ/KkiG9VIJ47A8CrIgJGSeR1yM5rnNYjYUcITkjkZy3TtVi2KumMDjPPemwxBDhwAT1x1FSwxAL07cdQaCxYVyxwoBz1xUqWu8jIbOe3tSrCNm48Y5+n+cfpViNWXDEN8x4zjIosQkJDahsqSAT36fjUi26iTJXjg9akSUOVwCQAelSRR70GcFc8c+1KyKSEEQCjJ4Ixz6VHe3KwRckYUU27uBYpuZgqgfSuS8UeJFVmVXJU84yMdqOUYzxd4rRxsikJweSD09q5dWbUyByFJx7/5+lCo97cZAJ59eTz3/wA9q6/wb4WFwwfZ1XoR/KmkBF4S8Gs7l5AAp5bP8q7zTNNS3TciDgY44PpTtJ06Ozj8tF4wCRVtItpCgNtJ7jihoAihJfA6EfWpo7fZHk455yecfhTrbAjOM+oANM1C+FtAWPYdulTygI16bWYFiBk9Oc9e3511l9bfavCV3CsZdpLV0VU6klOAPzryi98Refq0SBhguM44B5Fexab8ttGM5yoB9KmpT54OHcV7Hg0nw21iIEf2ZesT6RMaik8BayoX/iVX+MZGIGwM9O1fRDqVUsuCT154ryZv2oF8PeJ9T07WdJeJLSRo4JbOVrhrgDkZUou0nO3ALcg9ua/Pq3h3hakub2kvwHc5a38EaxDvB0jUssPm/wBEk5z+Hv2qhbeBNV062CpoWsbCc4+xSk5JyRjbXpekftO6VrPhSXWotN1WewjnNvD5XkyPMwTe2AH2/Lgg/N1FRW37Ynhi9v2tFs9Za8jbymhNsofzN+CmN2M4+bOdvYnPFZLw0wr/AOXsvuRSkedL4c1c4P8AYeujHf8As+Ydv92rMOgaysoX+wNe45P/ABLpv57fevR7P9rfwtPBdFl1GFbSAXL74QCYyAQwUEnBJwD0J6Zrb+Dfx10v4xXl3/Y8c/2WxiV5ZJkMTBnPygKRyCOcg8YwQDwKj4aYVO/tZfchXMn9mDw3qOkar4sur+xu7GK/uoGt1uYmjdwsIViAwHGcj6ivpjwPH5emJ06k/SvPw2OM89PWvQPCB8vSogWPvmvvsuwccLh40Iu6irEthrMatK+7BHf2rzCf9mv4f23iG71ZPBfhhNSvzL9pul02IS3HmgiXewXJ3hm3Z67jnvXp+pzoXcjkA9j0rDv5OPlznsRXeiW7nhPxF+F/wN/Zy8ETXWv6N4P8LaFdXcJkZ4VhjmmVt0YOOuDkgdBjPbNY3xi8V/AD4Ca5aeKvFz+GdH1PVbqLVLacqzXFxMqbUuBGmWJVSRu28Zr4A/4Ky/EHx78RPiF4kbxX4O8ZaX4c8P3aWPhi6W1ddLcCZRJcSyFcO0ijCY4G8Dggk9rpnxT8NeOf23/h/qHxT0uLQPDdz8PFjtLPxPCscEcimdSzCT5Bu2MRnkgqepFaqHUR98aJ4f8AhT8UPhRf69YW3h3U/CfiC4/tu8u4SpgupoyHM7sDw6tGM5wQV5715BB+zJ8Av20/BGsa18OV0CfUv7Ra4Op2hl2w3gO4loyRt3ZySqjPB5xXxf4N+OWo/Cr/AIJleKfDOgC7lm+IPiy70fQYIgWkNm6qJSgPzEFBs4yd0o75x1f/AASE8eXX7NP7Wlx8P9U0nxL4c0n4gadFJaWuuWzW0z3kMe4uoKgFGbzlUj1QHkYolDRm2Hryo1I1Ybp3PpnTf2W/jKnjeK4bU9Oie3sxpiX/AJkTxi2A2hAuwtjBPJXPXnPNN/by+EVr8Cf+Ce9xo9tK1xLJq9pLcz4x50hfnC88cAAdcDrX2MHAU4JPavmf/grfKkf7HkgkJWNtZs8n0wWOT6jiuflR9DmPFGMx1L2NSyj2Ste3c+i9DtA3hSziBwv2WNP/ABwV8rT/APBNXxFq/wAG9T8A6l490698NHUX1fSov7BAmsbs3P2gGRjKRLHlpFK4UkP14r6w0AqdGtFBBxCmCOMDaK0IkBQD5eBVLQ+de58nwf8ABOfU7n4ceIdAfWfB+hw+LpIbXVB4e8NJYKdPTPmQxkuzF5M4LOWCgnaBV34X/sCax8MfEvw1E3iq21Xw/wDC+91M6RE9uUuvsl1Dsjhcj5WaM5+bjIxwCK5H/grZ+0x8X/gd4Buz4D0ZtK0G1itp9Q8V+eheFpJvLFvFEw+8Tty3zYVjwOtY37cf7bni34Ifs6/BOy0rWp9K1z4iQ2Z1HXFs1vJ7SFYYGnkSIq252Mo42ngMBg4ItXYj0Wb9gC/m+HGh6JHrtgkuk/EWTxw0wgJzG0ssnkgY+98456cV8/8Ax3/YQ+Ifw6i8F+JdbvNJ8XyeEdce/vtZie7fUrqLzN6eaJCyRoqgLhOMqvNe3/sB/tML4j+G3xD1DX/ibc+NYfCV080q6pow0rUdHt1jLYnUABw20kHHBDDP8K+HfsBf8FFviZ8Rv2u9DsviLqG/wH8Uob5vDNtJaQRpaPHK/lqHRFdsbDH87Eksp60pRZ25fi1h8RGtKPMk722v8zvL/wCPlr8QPFfxHgsNI1q4fx/BbWunwiJWkR40CDeoY9e23J9q+sPgd8Orv4U/sw2uiXYCX1rptxJOowQkj73K+nG7H4V3Wk+B9F0O+e7stJ0y0upeHmgtkjkfJycsACckZ69RS+NJxD4N1mU4UJYzFiSAAPLbvWajY+nz/iinj6EcNQp8kU03d3baVl+A7wrbQ6l4L0+OeKKa3nsow0brlGUoOMdMe1Mf4Y+GjpM1gfD+iGxncSyW5so/KkbjDMu3BIwOSOwp/wAOZftPw80SRc5fT4D+ca1sbMdTjjFUfIM8Z+MH7THwv/Z6+IXhbwxrctha694tni0bTbO3tVklKOwVUYKMpFuZRz8vPA4NZ/7QX7Uvwe/Y+lttM8Sx2dld67btt0zTdIN1Pc26k72eOJDiMZblsA/NjPNfJ3/BSj9l7wz8Jf2uvgp430q2u5PEfjL4hW82p3k9w0u5Vlt9saKeFRewxnnr2rN/bp8P32n/APBV6xvdT8fv8LdJ1nwS0Nj4gkgiaJdnmb7dWl+RSzZzzn5sDG4Z2ikZs+5tO+NPwy8b/s/S/E+GbS73wSmkTTS3sllu2WceTJGY2XeApQgxkdRjFeIeFPBHwx/bz0g+O/gp4iXQNQ0Vjo8s9pZSWOAE3eWUwjL8sn3gMEMR24+T/il+1t4v8a/8EjvDfhi6tJrvxP498Qy+HtO+wWX2ebVrG3mV2lSKNRuLNshIUc5PU5z1/wDwSo+JbfAz9vvxP4Cm8G+JPh/oHxE0uG80nSNbtXt547m2jOWCsOVfFxyOMqB1GATppxZ25dmNfBVlXw7tJfP8z62+Bv7AEvg3ULGXxX4il1uw0if7VY6XEz/Y45f+ehVjjqc4A5PUkZB+hPE9nv0gKGyVmhb8pUP9K11Gf4hjFZ3iIrb6PK5YjaV57j5xzXNypHVmueYvMaiqYuV2ttLJfJGB8Vvgz4Y+PHhL+wvFujWuu6Q0yXH2a4B2eYucNwQcjJ/OuF1v9gb4P69omj2F34D0SW08Po8VimHXyY2cyNGSGBdC7M21iRknivZFTacg5APNJcReZCwyVLAjIPTitIux5LkeFeI/BnwSl+Jlz4B1Kw8LnxT4ziivJNJk/wCPm+itRmJsZyqRhPlAwAFOB1rI+JfjP9nv9n/ULfwp4p1bwZoVzd6oviNLC+vAsgvC+5bpgzZVi65DNgEg4718naD+ze/7OP8AwWy+GsVz4m1rxZqvinQ77VL7UdTbc7zNFeLsQZO1FSNQFycfTAHkXxt0HxTeftUftX6vcXHgYHw48eozWniewS6m1KzifMMNtu+4pRY8lcEkxDIJyNOQm5+k/wAe/h78FbfwRqPirx7ZeFrbRr+8t9RudVvZAiSThBFDKJQfvFCFBB5BHWvnC0/Y1vrrwNdv8F9R0TVfh14unW/SO1nRUkKHCtuPUKcjKtzjBHavEP8Agof+1foXxe+A/wCzj4Tv9KutF0HxJFZ+Jdf0nS0Je1sox5SxRIMEqQZinpsU17B/wQS+Oq+Ivhl4t+Gsktyx8Eak11pYugY5jYXDsy5Q9CJAxI7eaKynC8bnu5JntfLKzq0Em3/Mr/8ABR9Jfsyfsva14O8aXPjLxtfw6n4nuLcWkYjwUt4wqryQAC21QMjtnk5zXsPiSNE8S6HkHezzRofTMe4/+g1tom3hsZx2rE8WpF/b/htnTe5vpERj1Qm1mJ/QH86ySsZZrm1fMMR9YxD12VtEktkkc/8AGb9mzwT+0Xa6bD4y0KHWotKd5rQSSyx+S7DDEFGU5I4rBvf2H/hbNrunak3hKx+06akCQgSyiNvJx5RkTdtlKBVAMgY4A9K9aSPtyDis/wAZaPd+IPCWp2FlfSaXeXtpLbwXka7mtXZCFkA7lSQce1bRkzyZbnkGlfDn4J3vxFvPBlnaeGZvFel3r+JbqwiuN2oQTy4DXL4bzBuDKMnjBUYrJufiN8AfhZ4/8N+DJNb8FaV4h8HyPDo2nSagizabJcDDIoLcO4bG08nPAr5Z/YV+AY/Zl/4K+fEPwudd1bxHPJ4NW8m1HUZN9zeTSS2sjux5PUnAycDHJxXzR4em8Q+A/Cvxg8e6vp3gTWh4V8f+Zqum69Yedqt/K8/lqEcnMca7iVA6kueduDetyT9Ov2g/h98BfhX4Ysr3x1a+E9As7m4uBZ3F84izNPl5dpJ+bcSWKnIPJxXhU37KXxC8G+GtO0bwILHU/B0d8mt6VcWnl4JYZRjuP3duOPun3rwL/grN8etC+Of7Q/w/8J65BrLeH9E8My6vdW2nQGaeK8u4C0ClARjYVgJz2c9jX1j/AMEVP2hp/jP+x5ZaNqTSrrfgSc6LcpLxIIlG6BiDzjyyF57xtUThdXPoMi4hrZZOUqUYy5uklc9J/Ze/Zz1bwBrms+LvFlxBceK/EGRMIcCOBCQSOABkkDIHAxXWeHz9l/aD8SR5BE2kafLtx0PmXSk5+ij8q9IuFCxtzn29K8705Iv+GitZIZhcNotoChTAKCa4IcN35YjHbbXOtzjzTNK2PxDxFfd9tklskduYlYnGPm6//XqGSziDlljX5h6cn2qz/AQDntio5GwmSMDrz1qzy3qfFHxX/wCCwWifDj4ga7Yr8P8AxfqHhfwxfLp2peII4kW2jlLbRtU4yCQ2MkEgZxiu+/bC/wCChnhj9kj4P+G/Flzp9xry+KWUafa20yxvJGYw5k3MPugFf++hXxh/wUG+PXiP49ftQv4U1Xwb46/4U34Xv83VroelnzPEM8ZOZGdgF2FiVHJwMkZJBXU/a58H/EX9sf8AaI8B2fgPwBNJoHhPw7HPHaa9B5FhA00YJSTJCl0Vo12hidyeg51UVdCP0B+DPxK8P/tdfATSdf8AsUc+keJbQTPaStuMeeqMRjDK2eR0I4rmbb/gnr8OE8RLfPY3k0Stv+zPdHys+mAMkfjXhH/BHjRPH3wX0nxd8M/Guj39gnh28NzYzvEwt3WRj5kcbkYcB/myD/HX3IJuRwefX/Gs5RVz0sFmuLwkXHD1HFPezsVrLRrbQNLgs7SGK3tbaMRxRRrtWNQMBQOwAr8vv2zr19E/ad8WRh/ma+aX5uQgY7v61+pUzAgEYzX5V/8ABR9/7K/a88QBdyifyJMtjJJhU/59qInnzm5Nylq2U/B+umeBdxAwO/QV9SeDfhFZaz8Ebea8lklikkjumBcjDyRFlAx6Ac//AKq+Pfh7BNqOlqwDMCwGcZGAe9fS1jea5J+zbqCpNOsljd2caBTtZU2TAL2/2fy5rVIlM04rnTLGy2ppLxMBsz5rAH2qC416BE2i1kx05ckVP4ru7jwx4VjumVIoxCHYtyPu5PNeUXv7TNhbMU/tCyyeM5Bwfw4qhcx6gNZgaLcLWQsevzGmGWKZQxtS2Ovznn9K8wH7TtgsPyX+nue+1lx9frRbftP2srPH9ssXZeqgZ/lSuUerW2qQwjItGGRjG7j+VSDxUYZAI7eYqTyolOP5e9eYRftFwXDYE9mWyScY5PrVuD48B3JD2TAHOMDj8aLmbPVLXx1HGMvBO2QCF35xz9K29H+JdjbEs1jdMScD94Bx9MV5bpfxRlumVBbwsOADjOfp2rZg8bSNDk26At0AHOO3etQudfrvjSz1JnPkSqWOQMD0rCn17TQXJinjC/M2SCP0rk9W+JstpOM2sSgZzuU4+lcv4s+LP9oRxoq28Owksd2N1Z3A7bxR4v0iLTdkIvJJOB0AAryHxJ4jjjumfyn3ZJDbuD7/AMv/AK1TzfEhA6IqRXA7DcOe/FZups/iNz5UREh/gTnr/n9auIEvh3WZtbuRBEDH5xC7tu4gk4GP8K6v4ofs76n8IvEWkXt5cRzm9YndGpAUAgkZ9MEf5xWH8NNBuYdUQtBLGUbO4jhSMkV7j8fNY1P4o6F4df7GN9lmJ/JQnJVU+Y47nGfxPtTC5SXxu+u6HHA7qGgUADjB+n51zuvoTBITzkcY/H0qsLWfQdda3ufNifONrDaw/D1q9qkYa1ZVZuBjr6//AF655Aefzx4uWbbnOcjrx7Vc8My4uEUA7S2Mjpjn/P8AnNVNRYNdPhTyecfwj/J/WpNIkIuVHTB78VDIbPvv9ma6K/DvT224VVxwevNexy3JcxNnjIJ9e1eI/sxT7/hzYLwDjgf5/lXtDDy4k68/rWkBC/EOTzNHU7s4A5615b
J'ai réalisé mon coffret d'alimentation pour piscine au sel. J'avais prévu 4 disjoncteurs (pompe à chaleur, pompe de filtration, régulateur de pH et électrolyseur) et une horloge (avec son fusible 2A) pour alimenter ma pompe de filtration.
Après réception du régulateur de pH, je m'aperçois que celui-ci doit fonctionner en même temps que ma pompe de filtration et ne pas être indépendant comme je l'avais initialement prévu. Que dois-je modifier sachant que je suis novice en la matière??? Merci de votre aide.
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RBmRXhpZgAATU0AKgAAAAgAAwESAAMAAAABAAEAAIdpAAQAAAABAAAIPuocAAcAAAgMAAAAMgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB6hwABwAACAwAAAhQAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/4QjdaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIi8+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cnPz7/2wBDAAIBAQIBAQICAgICAgICAwUDAwMDAwYEBAMFBwYHBwcGBwcICQsJCAgKCAcHCg0KCgsMDAwMBwkODw0MDgsMDAz/2wBDAQICAgMDAwYDAwYMCAcIDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAz/wAARCAJYAyADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwC4kY5JJDAk/XPX/PvUqxKiDlXDD5QeP89KidJVUEoduQc5/wA+tAyy7Rkkcnkn+Y/zmvlz6toc8MZBQj5SRgZ6809rVTtAHJGcgdKfDbADOcn7vIz/AJ6j9KmWPKsQpOMD5h7H8KCCO3UxsR3LZyeP1q0SrsC5yQR1Gf8AP/16jgjVTuySDnHfj/CrFqqB8gckjp3xTuUlcerBlPPBOOD3zSxoFZSFHAySO1SlAik/dyM08xFUO0kZI/8A1UMSQy0iUE7gMA/3cGrsCFBndyOB71Db/KQCc45JH8qnZQ75J4I44GelRdFNXGtH5qMQM5HylTgmlRAqAgZx0z3qaGAb9xXCHIz2zTyo8kgn26AU46AkRNiRCpGAQRj1+tLCpicgENn+9+dSI4fI44/XvUgTaoCkk54xjIqnJjBBvAJAIGcgVJYp5ZGQqkevFJDEyrkjJB6ntmntjG7GcY4HepYCynlgDgg8+9PVGaP5iAV5ORyaYJVCkdewA7mmLqyQAsxAPU4607ATSW6Qw55BY+mcUrRAjqTxx7Vn3fii3t0y7IGUc98n/wDVWVffEe0gXcDuOOMGkkFij8T74wWDRbeJBySRgfn9a8surVWZpAoLtyTjqf69q63xx4rHiBjtG0L0x3rk3B2nAbngEdRRYGQqiuSG4DDGfX/P0rovhpHHB4wtpCMFW4OcbScenviucuZ/LkBJVSOgq74b1X7LqSSkspj5BA/HPp+dFkJ7H1rNoba1pkCMzBNuT6f4V83/ALc3grTvh7oMOsksoC7JSzbucZGP8Pavof4UeNYfEWjQKTlk/vd/bpXzj/wWMF5a/ArTri3VzbHUFS4wMgAq2M9x82B+NFhJn50/Ffx1F4l155YFwO3rjA6/h6VR8A/FC+8Ea3DeWc5jaJslM/Kwwcgjv/TtXIanetuyFIPfPFXfB3hq/wDGGrQW1jBNNPM4RFQZLEkcVSQnufrJ+wb4hi8eW9vrdsF2TxgHawJU5wRn8+vNfR/xP8NL4w8A6vpzgEXcDAZPCsOQfwODXhH7AHwWu/gJ8GbSx1Rw2oTSec6qMCPcB8vXkg9/XNfQmoaiv2CXkkletPZCZ+fXiHR5tA1Oe0lwssLkNgEZOf8AA1nR6h5VyPUnPXg/5/SvW/2pfAzaDro1SONjDeH5tvIDY6n8PTH615BbQma4GFI56e39ay5TQ6/SbpJ7QZKjaBjA7VK7hpCwIKd8n9ap6QA8aqAvPp6+uff/AAq3ErohX9F5B5x2pWAnSNY4wFQDGcY/h9TWJ40+QRTL97PzHrWzDcL0YlZOnTH+f/1VU8TWy3WlT/xMq5GD7e9U43NDw39oeb+3bs3Hd4wpyfvED0/KvK/CjmzuVLb+p4znucV618S7X7Zp7sVJMRICj8a82ttFJI/hJ/PFTygesfDbVzE0e1uPlyP8/jX05+zPrlze+JobeIgiTquc7vb9K+SPAMj2Em4j72BgccjjOa+qv2KpzP8AE+0UBcsu4j2o5R3PX/2gdU1LwboTubaSCIcF2UgDPHH1r5qufFk+o3LNJKzEdOTxivtv9uVFT9nvUpSo3K8RDEAkEuBj9f1r8901YRyYy2f4iMcGk4lRPTvDPipYZBlhhTyeg46fzr1vwl8TrXxBZDTb3LjafJYnlDjivmvS9ZESAb8g9cdc+vrXb+Adb8zWrRwRncMc9OPz61K3B7H238A4dvhTDEHDEe2RXb3UIa2IyenrXMfAm1aHwhsIYjORkevP8q665h2wMFHGM56V0QOOe55/qUZFwQAd2c/SqE6EsfXqT2+lbWqlvOcBSM+1ZciFuCMjHJ9ad7MEjMu495G4E/56VA0exNuCAa0XjxjPGfeo3X7wwOnShO4WKhTdnjnr9TUU0eT83zcenerrW4UEhe34GorlQqg4yfT0qg3KckAccc55INVp4PKt2yM5HPParzx8gDr9Kq3zDyCSRjHT1oQz5u+Os5l8SSKueBtBHAwCeP1ryvWY8HCnAJOR69f6/nXp3xkm+0eK7jJK4O3nv7/jXmmsxbJXIPXOT2rVIzZ5Z8QIyjMpUoN3Q9se1fK/7WN1h7VQcdcAnpyT/Ovq7x+4LSrlU2g8gV8eftVX3n6/HFk/IhXk8+v9a6qO5zTPFZzvk5z1rqPhrai41mLkYByR6iuWk5bNdx8IrXzddTAA2gnp2wa7U9DA91+C1mZfidpaIuQLhOnHcf8A1q/U/wAE2Jh0y2R9zuIlByc9hX5ofsr6aNS+M1hC8eT5wxx1xz2+lfqH4XtdsCKQu0L+dcWN3SN6KOg06DOAuAByOK2LOMwkYyB0OKo6cpLKV5LdiP8APvWlCCzYJx+FcHKdJKYRNJyePp196lSBNucgn1/yKaPmI29MdRU0fLjIxjnB9adgDy/MjwxGBjI61FJaeWmQPxB5qyy7dx5JHGMUMhWTOckdiKLFtFaIZYnkUEMEOBkE9R+NSyYLYIyDTEAOVxkD34NIaQwx5GOMgnqcfhWB40LWOhzsWLFkOQe3+eK6Pb8mSAD+tcb8W7023hyVcbi3y9M4NBV9D588Rr9ovpZs5LnJ9PrisOeIPGQSO5565xWrqbMGZSdobO4kcfWsm6Qxtgckn8hVJGdrFO5ttsBA59MdB7Vzl9HGkrLtJHpjpXVTLsXoBwSM9x71zusBWuZNpKhDxjnPtina+o2ZEalbsMCNqngdhXY6RGLi3R2Kj/PWuWaUySAtllY4I/z3rqtDXZbKBkEj5fQis5RGb2lQh0OOT+B5z/n86v8A2VQ+SQSOvHTrVLTw0aFWJyT1q3DIRgAZx0PQHFSolxNzTvHVh4A0KbUdUgF1Zx8MjY4+mfpiofCX7Wvg7xHrax6ZpkVvdb8Ftg3Z/wA5/KuR+Mg/tD4Z38IIjG3P/wCsV8ueE9Tk0bxGrKxUq+Sc4zj/ACaOVjOj/bil1bxL8U7nUbqRprabHkZzsQH+Ef5/lXH/AARgvPFXiW0sIFM127fKWJOBnlj3xXv2v+Bofif4atft+Y2C5BA6A/8A6v0NcvZafpHwKDPYNFPeZz5xHKjqBnnn+lVYVtbn07oXw08O/DLwbHdeI5La6uTHk+ZyF78d81y+tftWaZYTeRpYVIoxgbQAAfyPrXzZ43+N+q+N7lftd7K8ePlQMAF/AViWuqSXNxkSSNn+IGncZ9WeHvjtZ+IpFTUY4rlJTkg4G3j0/D9aq/Ea+0LQNPn1VLhI7NU3FS2NhJOBz26f/Xrx34e6fLfyxqWYrkAsTyOf8/lXq1v8Ao/itax6Zf6jPFaXC/MI8Hfxxkn06+nX6gFI+Rfjh8cZ/iJqLWtrJMNPjYiNM8NkY5rm/C+kMeWJ9c+vStX4heA08DfEPVNJVWxY3UsIYj7wVyAf0rR8K6V5gRWBG08EjnAFBmzpvCFrHZohJUtjOMY/z0rqLvxE0dkYocq23r/nvWBZo0QyowMfTn1qzO22PnACjoTkGgZVSXO4ZOSTjvn/AD0phDTyKdww3X6dKLxmiKHnn1GP/wBVRorno3I44zzTTsKyJ4X89HTOQOTgcc+9NiZYkbYPLJ6YHOPb/PSmQR7ZQcuOAQTwOn+f0p5YSncPvZyM9QPSi5BYMgkbcwXeTkEDAqdZ2lYqnO0dT34qqPOnwEjcrgc84HGfwra0bRDbS72G5iAMdcdPxqGyki1pNg08ycthRxnj6/59q6mxtPkDcgqSBzx7VmafZkSL5YIL/KctnPauj0rTyke5toB6469KE0NKx9DLK0luN23GPTrRbx7WIGcjqBx+n+etIittx/dwOOasRJzx8rHjHb/P+FQmaiscLwT155p8GGfjIPU/5/Ko3G2U/KzA/ocira/OV+ZQQOMCmKyIjaMjNjbz3K/kKswx4wTluOnpSSjoQSSTxn8KlVNsYYY25xj3zQCQqAu3qwPGO9WCmYgSRkjvxn/P9aRY15K8EjscYp5IjMi7g2B0z0NFhjYiCGHy5747/j+dTQAbBkcEZ5FU2uVt/mLFQCeT0Pt/OoZvEcNvGCXUHHbk81LQGxGQybQcY54+lKzqCBwGxk8Y71ztz42t4TtBwfUcmsnUPiGQ+F5PHbk/5zVAdv8AaIrYclRn9DUL65EiFsjKnI9684uvGstwWcu2GXAI4zVOfxDMyEly4P4c0Aei3Hja3gkfbkgnnj3NUNQ+IgjXKhCBn2IPTPNef3d/JM5AZhu6ryce3tUBmO0HcQF+9xnP+eKTA7C++IM7KXiYJ7Vmv4vuJeZDgHjuB2rn5L4nA3EAe1RPcOFRME4JPTOTTA17zWJbhQ29mBHHPp/n9Kz578yDLNux1IJ+v+fwqhHeyNIVYAckLkg8VBeO0rnD8YxxjP8AnpQS2XLi8CKAGDbsjBqpPeuwx0yMjPTOarPKWIBJxSXEYROqkqOnagOYdOTdMmcZ4IHP40W9x9lnG0BiOQaQMrFTwB2welNZBJIMZGOvPOaAvc7zwL8QrjwjOk9szGNjuZc9OP516R4h8feG/jb4HutB1+O3ms75PLmgnGQRngg9iOoPUV4HBfG1ypJYZxtB4zSyP50/yt5ZOOh4BzQNaHOa5/wSy8F6hrzXVr4muLfT3YsIQgd1HXr06cV6f8Ff2bvh98A3V9Mt/t98CMTzEMyHrx6fjnoKh8O+EpdTjVTexrGOP9YcjPXpXYaHouh+DkL3V+juD8y7s84zj8iPzq4olnqvg/VW1JElcgQ4BUHoP88Vrar4iW42xRNlRjOO5/z/ADryWT4z291H9nscpHjaTt5Na/h/X3uGQlst3/Kl1EavxT8Ip458GXVqyCRwN6f7LDpXyvcaONJvWhxh1JGCeQRx/j+VfYdvdJInLcMOuOleCfHDwb/Y3id7mOHbDcneDjAzzn/PvUlRZw1lCUI+8OPXj/PIq7EC0YwM57dvzplpp7kgEADpjr+dXE052XAIIU4zjn61D0LSK4gZclUUADIxwaVoGmidQACehyM54xVv7A8ibSDkfpThp5iB3ZYexyf89aaZZ5B450UyCeIDI5x33ZH+FcTbeGBGQZEX5fm46f54r23xN4bE9z5gB+b2xisI+GlSTaqqc+pp3QHK6H4ewysQRg9M5r2j9nLxFP4H8dwXMSB5Ixt2E4Dc9K4e30QxMDjp0Ab6V6H8EY7Gy8Y2Z1Jgttk7n6HPGKV0Vynsn7Zn7Qlr4q/Z2u7KaJra/mlhKoTwcMDwfTivhibxeY2b5lOehJr6/wD24vhRNrfwlF1oiG6SJd48pcsOOOByfT8a/PTxFdarps3lT21xC5GSGQg9elJspJnqdl4zQzhC6puIBw3U/wBa9Z+B1y/iLXoYYCxbevHfg187fCr4a+KPiHq8FtZ2FxL5n8e3ag59T7mvvb9mn9ney+FFnDd6nOZdWZB8qkGNOB+v/wBaotqDR9Y/CKPyvCNuDhSygsMda6K8JSFj144rB+Ht6k+noEfJVQTg5xxW9qJ22xBGcCt4s5JrU4W9DPcOMDk9/TNZ8ib2BG09x65rRvCRK+Rxk855qlKQGbGcjpx1ovcSRRmBMmDkAHI4OajYncc+mcnmpZlzOTnI7joc00jBxzj0x9apMCvcsWwF+6eajl3EAbeMdaklGBuGCRjryKgY7n4PHvTF1G7Soxz04qhqpxbtgHkcYrSZCoXnGeMVk+JH8nT5m/iC5A9qEM+YvifO1z4juucASFee/Neea6TErDjpn613XjW4FzqlwQcbpCwzwSMmuG1thtO7oOR7Gt4kSR5d46PlSSBsYOc8etfF/wC0vf8A2nxlPknKjjtgDivsn4j3JbzSfmyTjg9Mevavh/473ovvG942eA2MZz+tddNHNM8+5MvPrzXpvwRshJqRk5G1T/KvN4Y/MmGB0r2L4G6fiynlZRmJcjJ6+1dKOc+iv2IPDzar8cNPmRVYRP8AOTnI56/59a/THSFDFSNpXHY1+eP/AATfsXvfinMSoKQxls+jbgR/L+dforo0bCPHfj8P881w4t3kdNHYwbz9ov4e+GLnUo9Q8deDbGTQ/l1BJ9btomsSJBHiUFx5Z3lV+bHzEDqRnqtU+I/hrw54Kj8R6l4h0TTvDjxxzJql1fxRWTJJt8txMzBNr7l2nODuGM5FfA+o+J/BfgX/AIKy/HnUPHkum23h6PwBElxNfRbogj29gjx5I+9IjGML1cuEGSwBwPg78L/Gfwu+Bf7I+seO7fVNM8F+EPEepX2ureApHoYnkLadc3StxFGh3nzJMCISgEruxUxw6aWu9vxv/l+JMq7TaS2v+Fv8z9Ebj45eCLLwNaeJ5vGPhaLw3fyGG11Z9WgWxuXyw2pNu2M2UfgMfuN6HEVn+0b8Or671OGDx74KludEtft2oxprlqz2FuNuZpgHzHGN6fM2B8y88ivzu8Y/D7xX4i/Yk/a11KwtL7UfDHxA8eLf+Dra2geVtWT+045Jbu2RVJlhliETK6ZBEDkcDJ7jwd4GFl/wUX/Zz1JdDe38O6L8K7W0u7lrBkstPuhb3jLFKxXZFKGZCFbDBmXgEiqjQTTd/wCuW/8AwBOu10/q9v8Agn3Bd/tAeArXwXZeI5PG/hCPw7qsjx2eqPrNstldupYMscxfY5BVgQpJG0+laPhD4qeGPHmt6rpuheItC1q/0GTyNStrHUIbibTpCWASZEYmNsoww2D8p9DX5Pw+FtS8If8ABD/4m6bremahpN5beO4riG1vrV7eaOJ5rIK6o4BCthwCBgkMOxr6DvPDmqfFH/gpbp2pfBye0sNN8O/CmTR9Yu7W38i1067ZLpbSynXbiOeOQ2jmFwHVYcFRswFLDpJu+1/wV/8AgFxxEm0rb2/F2/4J9q+H/jB4R8XeMtR8PaT4q8Oatr2lBvt2mWmpwzXljsYI/mxKxdNrEA7gMEgGrfjbxvonw30CXVvEOsaXoOl27Kkt7qV5HaW8RYhVDSOQoyxAGTySBXwx/wAEr/Avh7xT4d+Gkeva543tPid8G7nWdPu/C0tnFbxaWb7znd7ofZxM0UibHVpJSPOGBnG2u7/4KqvqHhn4jfs+eL7z7UPh94P8bw3niWUFjb6exkgFtdTKucJHicbyuAXC5y4BzlQSqKF9/wCvxLjWbpudtjtv2Pv2tNf/AGgPj38YvCupzeFNQ0bwBcacuj6nokEsa6hDdJPJvctPKj/KiYKYB5PORjqPGfxg8KfFHRr9PDHifw74jbTGCXq6ZqMN4bVm3BVkEbHYTtbAOCdp9DXxx4J0jW/GGvftyjwXp2rWtx4rhibR5V0yaFdRKJd/aEhJQZlkEhCj7zGUMPUdL+yHp/hHxZ4M8HeL7HxF4r1HxjoXgmDwVq2mXNvDDa6J9laMvbyolvG4lWbd5fmOzshY/MASLdFW5ttF+X+ZMar5uXzf5/5HPftZ/tQv8E/HHgrw5YyaJBf+K77bcXWoy/utNtQyqZXQOpG4sQrE7f3cnBxXN2nxp+IekeD/AB7e63e/C+41Dwro0l7FaaRcTXckVxCjNKlxH5isq5QjqCCf4sGm/tw6Xc3v7R3wMvLe2uLi20nWZ576SKJpEs42ltcPKwBCKdrfM2B8rf3TXDeN9GvH+N/7Rswsrww6v4VFtYSLbuY72UWSxmONsYd9527Rzn6VUIp07211/Bk1Jy9o100/E9I8KftfaLH8NfAl/wCKL7SbHXfGkccgto5RDFArFt0zb2JSIbSAWJy2BnrjpNd+KvheCS9aTxNoMa6coe5LajEPswLBQX+b5QSyjnHLAda+cSJPCenfsv6hqVvd2drpctzY3bS2sgNtPJ5SpG425DMVbA7hSegJrbT4aWPjj9u34hrr2im/0LUNEiige5tmNvNKIrVWEbkYEqjzBlSGXD4IwaudGF2/X8GTTqysk/L8Uex6v8R/D3hbV4LXVNe0bTrm5CtDFdXsULyqzEAhWIJBOceprR8U/tC+F/hl438PeHtV1ays9R15nIWe4WNbOFIpH82VmICqzIEXJBZm4zg4+U/2m7621E/GHTNI0m70+a2t9Ke+IimmOo+W8ZSRQB5cEMUavk/x/KQQAVPaarqH9i/tLfAnxHf/AGpdLbQJrc3PkyPvmazlxGAAWaRi6gKBklhgVCoRaT7/AOVyp4iSuktv87H0p8IvH2qeKPH3jCG81TwdfaLpckSacNJvPOvbcYfzftY3EIdygDgfdfrXV6H8U/Cvi+wvb7SvEnh3UrXTU33k1pqUM8VouC26RlYhBgMctgYB9K+NfFngbxJ4lb9p2DQdP1P7VrR02SyWGJ4zqMUMrG5ERwPM+TcCFzu37cHcAfQvAM6+Mv2vvD/iTwncJP4P0H4fx6Zq91AP3EMgaRls3IGBMmYnMZ+ZQvIHSodBOPNfp+l/xLjXaly26/rb/gnvOr/ETwd470qHRrPxT4auL7V43FhDFqUMkl3tzuMaq2XAKnO3ONrelcBY/sy3el62tzPMphjbdnuB/nNfMPwx8B6hpPwk+AytoeoW17pvxAa91INYyJJaxCeAmWXK5VdgT5m4wo54r9ETEL2Ao5yZBgkcY/pUVqShs+5pQrue6PGPi38Vbb4f6O1sjgXKrhV+nHHT/OK+etf+JM/iDUPOlcZzj2Fd3+3/AOG4PB13pc8EkqPdlt6scgd8jjvzn6V4v8K/AesfE/XIbHS4JZZJW+/g7UHPJ/KsDfmOqtdXadcbsjPUHv8A/rrq/Cccl/OApPP6Vn+Kf2ffEvws1KOHVrR4iVDI3BVgfRhwen4fjXTeCrFowreWVyQMcdetArs9U+FkP2fyo9ilA47c9q+hvhU6p4gtycBNwLcV4N4EtJCqiIY5zwMAf54rc8T+Kda0HTbm7sUkm8pdzMVysecAEke/H40Bc8F/aN0lp/j14m25RTqMzc8ZyxJHP1/CqnhvRnhUZ3fNyMnH61efTZtc1WW7uXd5Xfc7uSSxPf1zmteysAq5IPydB600iWyusAW3IAUNnGKa0JdCQVwDxkVovEmMuMbffjP4fhUT2/7wtjgDgZ9/aiwmzMurR5o2wByuP8/57VUhUwFkbC4GME9etbZt/m45Az7Uk2micAD73rjge386fQXQxDbeSHYAMD1HrU2j6e0sjFl24IHPQ/5JNWLTSZBKyvzz1HQ/l35rTsLQQzFQAoPTBz/n61DY0ixZ6cF27ChXHGTx+RrVsrTfOERduQDjAzTrDS2MOeVJ7963bW0igijZcAgc5OTUt3HcSzsRaopPzEen6/T/APVVwyrISi5xn5sHGKgeQeQTxhuue3amFwG6Dk4GPekO59GoA0jDBXBPFWgPLTHOMYyD1FUlQC4YHBXIOB/XH0qdwz5GCCvIY9M0kaEkbESKT/H0qZY1aQk9u2Onv/n1qE5LKFzxwAev86llAt9rM4HsfXtTAn3+ZtPHHQZ/Wp1cB8NwnXp2NVpZVLJjIIx0as3V9YWC35fJIy2f5DikmDNLVdVhhJ8tgByMHt9feufuvHJtrh4416dc8f8A6/0rm9T8RSSzHAO0cAA9Byc/j/hWW1808bKUJzyNxAIHFNMnmOgufFUlwx6qrn7o7jpVSXXpnuB83ynr16/5zWM135ZUEg47ikkuWKYJJJ/P34okxpmnNqG+UhnIzxgHGT1qCWXIGcDA5BJ/n/ntVNmw5Jz0z25/z1poYnKtuJ9zg0Kd9wZakmBCsrlRjae4FLFcFkySCpHB9azmUtIWLbgBwB296lRSQBkAntjFNEbFwny0yCcdME8f4+vtTWciI8EnOPpVRQBIcnIbjGRRFIWBUkgA9+1VyormJyqbM98En079cUklx/eIwTj17dvWmqMDp8vfH1GetDtsYjAPbkH8aTQJjZZt0eAeeORyaovctEOpOOmRnNXZYsLjls+hxVO6TaxbhVA4Pqf8mpBojRSHLHIUjs3OaV1LDnJ9MjGTUYyyk5xz165GKlR/OUA5J49cUEirsMhAOQMDI9PU/hTo4iVByOuM0pl8pkJAIznFSq+YycLhuQoOfSgaRF5eZDkEY9uv+f6029hkZAxYdfrxUsPzZwSM8g96tW1ib9nVUL5Xr/n6UWG2c1q19c2ijyXkUr/dJFZ8GuTOQ0szu/cZ/wA+lbGt2DRI5cMCp5z161yd+RuwuRnk9gtVEk77wv4gV50kDn5cbgD3xwa9T8Ga95jDJOO5HHT0/CvnLRNd+wT4U4AGOOOlereBvFBcqWb5cYAzjH4/n/kUNMD3vSNVWVAM549e9UPifoieJfDQcLmS3HmKCTj/ADisXwxqyTqmG29gM8V1CXUdxaMrDerKc+h4oaKSszxI2IjYDaM5w3GcUrISRgYz6da6jxT4T+z6g7IFWEnjn296wLq1Wzm2b1bHGB0JrNo0iVjDvccg8DnvVfWrqLT7V5ZCQEByT1/GrEs6wR5Z+B1OcV5n8ZPiXBa6TNZwNvdjh8HOMDP9KkoxPGvxp8m7kggMToCckrz36VhaZ8WJFuh5gQIe3QD6/j/OvK9f8RNLes+4gseprLTxmFkALAEnB5qGOK1PrLQLuDXIFlhYMeuBzjrWncKyQN0DLznpg14h8Evina6JdbLmfbDIpXr0Paus8W/H2ztAYLKM3JwfnX7o44P51jKpY9PD4Oc9kel+F/2pdW+HMD2ssgurXPzRy/MCPTnOelZ3in9tHwI7mTV/CNnPdDkGKFXBOcknP/1+tfNPjL4hX2qSuZJDGGzgAYA9a891zWDLOzu5YZ5yaj2rZ61PLYJe+fXsn/BRnTNN3QaF4ftdMjcECQIFOOnQenp7VPpX/BQazRjJdw3UjnAymOO3fFfDt1rzFjtzntUUN9f38wWFZm3HACDOaOeRt9Rw66H6O/Cn/grFp3gK8uDc6dd3UUg+UAqCD+Jr0iw/4LO+Eb+MpPo+qQlv4iqN2HTDcd6/K+z8M+IZ8MtjfOen+qYirZ8O69p3MtjdxlfWMjNTKtNK5LyzCy6H6ueGf+CjngDxdc7HvpbNn6eYhxz74/zxXpfh344eHfFCRfZdSt384DCmQAnPbGetfjNoNxfpqKI4kjAODuB45r2bQPFF7FBFGsjqYgApUkbcDjGO9YLHyT1B8O0pK8G0fqzKySOHT+ID8aYEKMcnI6+9eM/sSfE268ffDKSO+ZpbrS5fJ8w/edSMjPHUf4fWvZxy3JyD3NevQnzxUj5TFYd0arpy6EEyAZOAMiqwUK+B3GauTkSEkY4PP+NQyABOmf61scjInj24PGO5zg1zvjm4a10G6c/KAv4/h+VdHkEnqfbPHSuR+Ll0lt4Uu26kLgc4xmqSA+YvE9x5l3LJgAsxI9ea4zxGcREEE56YPNdTrchfdnGSf65P0rk/EjFIJHAHyDJ+laxJZ5F8Q5iIJiDt46Ht3/pXwx8ULk3Xim9kPXzCT+dfbPxUvlg027kOV/ds3BxgYr4a8a3X2nU5jzy7fzNdlM5ZmVYENMucDPAr3D4Uw/Y/CVzLj5nXAz+P+fwrxDSkBuk9M+te/eCIxaeAlPTecZ6etbJnOfWv/BMPSxd61qF6ygGNQCdnXGe/avvLSVyOuQeNvTNfHX/BM7w8LXwvqN0GwZJdv3fvfd/+vX2VpgEewDn1I5zXn13eTOukrI4DwZ+yd4f8HftVeJvi/bajrsniTxTpcelXdpLJCbCKKMQANGoiEgb/AEdTkyEfM3HTHsdl+8X5gR/vdqrWqBeex/UVetE+T3z6YwKwlJu1+hpGKW3UnjQCPaSeM8Z/L+VMIKnAYkcde57mnJHgZOTnnPrQU4PQEc8d6kZ5n+1f+zJon7Xfweu/A3iTUtZ03R76eGeeTSpIo7iTynDqu6WORQu4KThc8DnGa9AsVTTLGGAzPJ5Eaxh3IDPgAZOABk+wA9qp+INbfT42wFbaOB/hXC638QZ5CwQFTjnntjpV87a5S+VX5up2+reJodPhyHGf0rjvEPxMWIOsbjPqOv0ri9W8XT3zEFz+BwTWNc33mnlsMeSSM4/zmpaGb+qfEK5uHZQ/y5/L2rlda1ee8UgOcjPViQCT7k/4U25ufM4wwC+9Ubi4XJGQG6/5/wA+lUkNdjJv4/NjwSxZhx9Kpy2x8sFjg4z09PStCVfMy2QQW49DVS8VFHqpHIp3JsZ8iZ3Y4IBznvXO6o2UIBJAznnmt2diXbB+9nGRwPyrC1aEBDjbuPv1pJ3B6Izowdy4UZB5HrXSWCKIwAB+VcxFIx2DHzDH15rodLYsoOcE8g+nFNiTOk0q4AhwOvbirs11+6XJACn0xWRpsghGAR6k5wavGQOCwPA5/EVmUW4bhWVS2G2/NgGs/VtafT4XkQ5ePoAeppk2pLBEcYAPGaovqKsCXMe3HQnp/nigD5Z+N134m/an+J8Wli3ay0rRpWhaR1xjnB6Z9Ov+Fe2/C/wNpvwj0KG3sY182NR5k2TktjnHPT/PpWvdTW0Fy5iijjZ33OVAy59/Ws+51LexGeTg9M4//XVKIHruj/FHQfHOjjSPE9uZ1ClI59uGiz1w3p9Pyqva/sjaFqlybjR9ctXhfJEcjYK/l7145PqItldxtXsAfX/Jqi3xFu7NSIrl1CjClXxj16c0+Rkcx9WeDfgro3gezkk1C9s37796jA/HANcD8c/2gfC2meGrrwz4edJXuR/pM2BsbBzgds5/L9a+Q/H/AMftTvrqWzF/cMqtjJlZiD36/wCeK5LTvEEryEmaQs3PJzz/AJJo5GHMe2Jbgo5jBJz17UsUXlkkkkf3R0rlPAPima53QzHKsMDJ/wA8129pBhCwLZY+h7dKdrAyEwhGOVJDEY44WnxWqqpxhvY1IHEcrEblzx6Yp0Z2bgSeRxz+lKwXRRjQGbgKH6EdRzU32AwzFhnGMjHYGpzHtBO0cdOOfpTkIA2ryeOgJz78UNCK9nYfvW4BL4zgfl/X9a1LHRCmS5JOegJBxnvTrHTvIkDY568nJ+lakAITIBVhg5Hcf5z+lZtFjo4EjAAwPcDk08sC4IID455wcf5/pTXYMoAZQc8ZHH+eailciPK4JHOccVBLF85QGIyd/wCGf881DPMU2MSy89AvH61BJflo9hJC9M56f59qz7jUV38EZB6Y4ppiPrSEPIg4YsByMAcVOQsYOT2/i9P/ANdVobkFWJIBOfTNU7y7UwnLMpxgH39v89qhM6Llu51ZLGZQxJVvfFU7jxXC2Sd2RgYA4/zzWFrl42/AYhME5zkH6isO5lG77+QBgKegqgudBe+PC7lFI2lTkg5z/k1j6n4ikuFdnLBO/PT3/WsaWc20rKOc9CP8+mKikfaSRkoeoPUegpJCaL0swZdw+Xd6Z4NRo0mcAtzxnuPxqkZnVjgYB6d8D/CrcbEOuR8xxz1pdRWQ6KQDHytuI5BP4UKUIyrcjuD+VN5Y7Wz7f5+lRsTHIPmPTAHYVQ7pFgOGCgtgEdscHvTJ2ZM5JJ6jHPNQtNsYE4zjAPYU+OYueeTjgZ6dqaJuxVJLFWwBnr1zT/M8t+RwM4NMnY53AZJHXP8An/GlX5lJ+XI64HIpoLMdtMjbgTg4BUinRuIslh90dTzzTYIhtKgckYp+AUbOc9T6fzoch8pKChRiuecn+uKinb5GAyuPTjv/AJ/KljfcxHGBxgd6j+zl5/vbVxxnnH4fnSuJInjX1GVPr0FVr+Es2MnB688VbC7ouWyMEcD/AOvTBGJWBP3evqTRYsorCLdemdwwRSKfszgAYUjr3H+eKuzW6sRjBwMA49s1RlRSylgTn2/z3pqwrIkjB2Dp6jtUkTAvg5zjHPfnFQ24AIBBwevv9asLDjByAF6kCmkTYW2hCs2BnJzkYGK3PCMZW9Xng8nmsm2cRoMEEn1OTWz4TYvqGRk8YP1pgyv8Q/DmN00eCWGSuM815frtqbYbiN2ecYx+Fe7a1HFPpbKQrL3wOn0ry3xloLKWK8jOemeKdhHnsl2sLkk/N23c/wCfWuq8Ha+0UyAMQp6BegrlNa09oZWAH3eT2x/nmquk6w9ldL820bj+dPlJbPpDwV4hEqx5JyQM9OOK9B07VS8AGSzY5z/k18/eCfF4yuXwVIU+hr1nwzrhu7bd1K9amSLQ/wCKerSW1nDLnbHnBI+lcBqfjMWdqWdiMHPzHGa7bx+i6poZjY/OGBQk8mvDvi682kaYIyTlzgN3AxWUo6GiM3xN8bLi6MsMRIK8dsEfh7fyrzbXtZecOXJLuDk5x/T61BexMLv5efTrzSXEH2qPkEjGDjof/rVk5HRGN9EeZeLb8veMEOAT2PXiq/h7w9PfThpBhGPOeSPw/wAK6XWPC6SaqJB91DnGMbj6Vq28KWlvubbgdupxWE6nY9rA5df357D9L8PjT7cHd8pwfp61Jf8AiKys4ikaGR+ny4OP8msv+0pNYv0hikIT0Bx3/wAK7LQfh3a2yJPMhkdvvBu2e1YODb1PUqYqlQVkcA2ga142ZzbWsu3OchTxXTeHf2W7jWYt99dfZwPvKo3GvZfhhpiXV+tpGgUvwvtn/Oa9P0r4Ba7eTborY7XPO44wPXmtYwSPMq5jKXwngvhb9lzQNPYCWFrgnABkzge/Wvob4K/Arwza7VTSLXcOQWU9B+PfP613Xgf9la4uZ1a/mEQJGQOePpXtPgb4NaX4LhUxkzuD1YYz/n+lNpI45Yicupe+F3wm8P2Okxt/YunR8Hj7OvI/EfWsz456d8P/AIf+FLjUdb0nR4reIFj/AKOgMhAPAwMkkZrT+K/xs0X4H+DpdV1S4t4IoxhEL4Z27KB1OfpX53fH39oTW/2lPGb3d3JJbaXHITaWSsdkYAxk+rcde36nhxFdRVj1ctwFSvLmexz/AMXtb0f4jfEW7vtD0a30bTmIWKKIY3AZ+YjPBPp+pqho2lO1xFFCjvI7Abeuc8dKsW+myQtHBBG008hwFUZLEnpX1r+yL+x9/wAI95XiTxLD/prJutrVuRFzkMw9eOlcVCjKrI+kxeKp4Sld/I9H/ZQ+Fsnww+FluLpVW91JvtMi/wBxSPlU/Qc/jXpqttI6fXNSSpgYGBgccdKjwM9zt7gc19PQjyxUUfm2KrOrVdSXUc3UjIAA6Z6VCqBlxkEZ7dv/ANdSMckfMcevXP8An+lMkO3r37VscrIZQIc4PXpzXn3x3uWi8IyYJJYHtXe3hLMMZweDivLf2ibpotEgj3ZEzY4PYdvpVRJPn3VkImb5ztPqK5HxbdCOykGRkjBGK67VWABPGRz78VxPjW4X7PJk8kHBHWtYkyPCfjzfrD4Q1NlxnyyOCeM4H9a+KNcl8y8OfXv0r6//AGmbtbfwXdkYLudo+hzXx7qrBrgj9a7KZzTG6REHv41xncfy9a+kksVh+HFiioqlsYIxzxXz14cs2l1aBB3YAA19G68f7O8OaPbnG0kHr0GB/wDWrU5j7u/4Ju6bn4MR3DFgzylWz3wSM/jX1PYQhdoG3gdx0rwL9iKzXTvgfppjjGJQJCdpB5/+uM/jX0HpGAozznmvOqu8mdsFoT6jrun+GbeKfUr60sYZriG1jkuZliSSaWRY4owWIBd5GRVXqzMAASQK1Y2K8AAn618r/tcCT4zftl/Ab4YW8iT6bpl9cfEDxFCnE9rDYKEsHbJAaGS6d0K4Ykqp4CnP1R5XknByCKzlGyT7jjK7a7E8TYUqcsPr3prxrjP14pFymD3AABprvhhj5d3Ujuam5fUoavo63kZ/vDv7VxHirwpHYCVgFOATkdK9AuZTEhJJ6fia8w+JviaWxJQHJJwO2f8APSiJZ5tq9ypkfaeD06/nis6SfD5ZmbIOMjpzUl/cCWUuAfmPUZNVGzMx6YPpnmnIi4j3e9yD2AI9ORVe7bYBkrtx3NMVw24lsqR270SAbeSRzz7e30pJspsrTyMWPO78cVDefdOCN3UEVLNCM5PIzyefeq1yDLGy8Hdz16/5NPWwuYpXDJgbjjAzxySPX9awdVUPI2wbR3A5HWtbUbchTuJbHHGOlYt2ApJ3dvwP+QaaFczJ43iwZFOc5OO/51raZerGQgAJbsffj/Gsq9BwOCdo9fepbSfgNjLY6j+VKQjpLS+KuuSo3YyCecVpvcbVUKcHGT/hXN28w2rkZJPHfArSgu1YAAnJ9uv+cVJoM1lniCkb9pIGSOvHT+VZE14fmOTkdv8AP4/lW7fKLqAKQfx+lYl5pDEOwyBjPPcfjQguZN1c4kbjJz0x7VQncCMuxIA7npVi6tJTNtKHOcZAPSlfRrnUIThHXjByMH+ftWsdyWzlta13dvThST1PFeVfFr4xw+FrB7aykE12w5Zf4Ov/ANepfj5qt54ckaK0Yq+dpI5P6d8d68wuvh1qeu+HJL2FA0cce+RiT8vOP511Qhc5pysYNp45mvtQaWclt7ZZvrzk16B4euVvwjLjp27V5N4f0m4aV98bgKxAYZx+dem+C4HtrdUILkYzxnpVyikZwm2zvNI1P7DMWXCKOhxnn3969N8N+MEvbdIy4DYHXvgV5VY3ClUyRkd8+latle/ZsbThgvbj+Vc0o9TpSZ61tW4j3qcHoOM/5NSbABkn7ozwTiuZ8Ga6btQkjcqckE5NdBqE+wjaoXf056VLWhSIbq6aSZdjBR25681e08KzDcQCD6ZJrNghHmlgOTxtxyB/9atGwDS7eMc8Z7dzWUh3NOCfKHdjcOCf8/WpzMVXBJIbg54FV7eHdGxx3JGBnnp2+n6VYJjWEsD8w5HuAf8A9dSN7AMGEgFcYyDj/PaqU2omBHVTtx6N9KHkCu21jjG7g5xjHp+FVLq5M4+ZVO4dQc4555osSQNJ9pVyxGGPfqPp/nvVCZJJmIyy4GF9Dz/n862LTSHkjHOQuf8ACtvw18ObnxBdxRW0EzyO2AoXJbIz+PANFhI+gLmfy4y24EduMYFc34h1tlkKlwRg5HTJrf1aErHsUjvj64rjNa0mW7csvQn6+wFc5s0U7nXZbtWJLjqD6dP/AK9VWv3XOW7dhjtUiaabVmDAgjk4GDnj07dP0pZtP+TeAxA44PPT8f8AIq0IqT3O6cKcfMDgj0HP9amRTkMx47A+lQfZh5u9uGGfmzmpg4PViexJ70ykySMlQxIA/h/TGKcGPlgq3Kjj2+n+e9RLygyOCMg54x9frTzFskH9w+nFDE3ckMzNGABjHU7aY7kNyMEdeeRSGcFlJzzxgE805hvXoSRjkjmsx2HIzeemcdORnp7YpxC+YecA9celQwqynceRjBHqMVJnMm5sEDuOuapXsCsSbtuRnAwScjmkikZGIJ56cfn/AJ+tEbZGDgFRxnkUm8yNtGPb36Ursq4+J/NkCYAYdz1PapdhJK5IzwOtNtkCsGwDg8fLz+VSySbeyshGMiqQEYj25CqWBIHuc1NHFu+Zto4wBnGfemGTZIChBHYCkWYkYII9Ae3FCYErliQAAQOTxjNOCZTcOMcdqOChyTnoDnpToieMlSOnPU9P8/jTAjMnO3k7l445qhdW+W2nJLde2P8AP+fbWlcRAbVXcORxnFZ10yGQ46dRx09TVJCexEAyNyMjrkf5/wA/jViWTevIUnd246U0jfkhRggdv606JAXGOOc8/r+tNuxKZJZPyCQQOg46f55rf8JRn+0ck/LgdOh9qw4wY3AAJOefrXR+FlXcWJJxjvnHvWkFcib6mrr03l2DbeATz61xWt2/2uErt3YP04rY+Ifiyz8O6a0lzOkYTLAHvivI9S/aP0u3c+VHPKHPB6AD3/8ArV20sDVqK8Vc86tmNCm+Wckh/ibS/s7szY3dTwOmP/1VwWuI0c42Kcg5OBxiuqn+L2k+J8Dd5ZXllbj19eKqailpqELGIht2cYbI61pLAVYfFGxMMyoz+GSZW8F66badPnIYNkhh717h8N9fE4Xa5AxkZPX/ABr590/S5Ib7cFIUHivb/hBotxe4xEcAABjwAfXP+e1cdSFtzup1FLVG98TPEbLNawxuQyfOTjA/zxXEePdBk8TaOXI3PFyBjPbsK9A8U/D6UT/apXUBRgAdBVCHTVjUDd6ZwcdKxdtjpjK585XegyxEmVApQ/MSelYt7rtpas8QkXeBtxnODX0f4q8B2Os6Vc4BicxnBUY5I618haT4Tm0zxBdxzTCYrMyhlOVfB6+/f8q8ytOx9FlmF9o7voaEIaXfIxJPXp171yvjfx3BpG6J5FVm4UM2B/n/ABro/FeoJpdg6dOOa8B8e6XeeM9WeTedq8KvOKMNRdSR6WbYxYajaO523wg+MNhbfEP7NqD7hIcK4AKqa+n9O8U6Rculus8LN0GznOOM18Q+DPgzdalfgI/lSk4Uk4HNfo9+xt/wTmWbwZa6t40ubjzLiMSxwRvtyDyCT16Ada9KpheRXZ8ZDHSqSO2/Zm+Fp1jxXa3rQt9ngYP5gJP0J9uK+q7KCO1XAVFBOMAYxWFoGj6T4J0uOy06MRRRKFxncxx796tPqjXDgMWwe57CuGokjtg2zpre7RCVUbV4z71g/FT4x6T8IPCNzq2qXCQwQ/KoJ+eVz0VR3NZHin4i2Hw78N3Gp6ncCC0tkLsxPJA7e59q/P39ov8AaL1L9oDxi9xJJNDpFu5+x2eflQf3yO7H9B+OeCvVsj28ty5153exL8ePj9rXx/8AGUt5qDlLCFyLW0U/JCufTPJ55P0rL8PWst3cQ2tjBJNdTMFVI1LMzH0A/CsDQdOm1PUIre1ieeaUhVRFyzk9ABX3r+yB+yHb/DPT4Nf8QQLNrk6h4onBP2McdQeN351wwoyqy1PqsVi6WCpWXyQfsq/siW/gawtte8QQrPrUgEkcT4ZbfqQe43cjp0/l9BZB6YAHpSyENGcdB+tRuxLYzzXvYelGEbI/P8ZjKlebnNhIxXGc5Oe31qENjO4/Lk96ll2u4I7j1zUezcD04zXTE856iFueBu9cH/OaY7ZXGKUHAx2HXrUbsHbjj0yaszZW1AjbwMc46dK8Y/aTvhGLVOSV55PWvZboqByOTzgmvBP2jrnb4i25IAQAe1VEDyTU28wvyoBzj61wnjKcL5gLAYBB56V22qAGFhuHXIz2rznx7cZkcegxj0rWJMj5w/auvzD4Z8sEHdJgnI9q+VdScmYnueMYr6Q/a61FFtbdAT8zEkDsRXzXeybpa7KZzVDoPhwn2jxDDnnnPuMelfQ/im0W+1HTLMtsbyxgldwzxivB/grZ/bPGFovTLj8K961S2a9+JOmhdx8uSJNuM5yfT8a1Zz2P00/Zg0k6T8GtDgKhWS3XjGMjt+mK9e09vLVeBz144FcP8KNMFj4O0xAgXbAo2+nH+H86q/tV/GMfs7fs1eNfGyzW0NzoGkTz2LXKkxPeMuy2RgCCQ07RrgEE7sV5crt8qO26Suzy79iSWD45/tf/AB5+K4d7m0s9Wh8A6G8k3mfZYLCNGu/KKsU8med0lXA7E9WavrPYHiPoT1GK8Z/YA+C138Av2P8AwJ4Z1FZk1i304XuprcYaWO8uXa5nR2BO4pLM6Zyc7RXsoyCM7c/40VWnLQmkrRVxyEEHJAUelV5pAGzn5QuelV9bvhp9uznkDnjrXnmv+OrzUJzFCpUdjjJrM16ndazrcFtbuzyKoA54FeL/ABO1qK/u8ISQD/3z61o3tpqWpAtKz4IJwwwD71yPiTTZNOyGYMSfxHanEpmRJh1UsQrDr6fnVXYzEjJ5JGO9LLJlQCe/PNRq2zcwyAo6+npTkJMrvE1vMepAznPanTShVBBIB9KJXeSX5iPQgdv8/wCFRIPNUDJIJxyevvTQ2iKWR1B2kncenWohIGcq3AHXNWLlvLIXGfqapSsRIQcnPT6df8KZBR1N2TkkYGTjqKxLxjKxG3GAfqf8/wBa3b6VJg2eVHT1rIdRJuIyoxxkYH5UAZV1brASAScn8+tUYboLdMG2kD0PQ1oXa7lZsHJz36daxdSXySZOmevvQNM2Le/VlwXYAHGPXk1etb4LIvzBh0z3z1rn7ScsoJOPoMnP+cVdiugi8csCOw71FhqR06P54+92zwOv+RS+UHbGTk8YOeKztG1bEIEpyc+o/wAjtWkrh+Qc9yRxikJkttZxH7xyerZ5xWh/ZIlgOEBUqTxzWRnE5Ydf5cetaek600MqCQnaCADjOPb+VarcLHzB+1Xb2nhu2nM5UMGLIp6H6V896T8cvsNvPp7SeVBMpUqB9f1r7M/am/ZuX41aOsllMEuIzuWMgc//AF+tfC3xe/Zq8QfDGWSS9gcIr7QfXvn6c120noc9SN2dr4JuIPEskcSFdijjjtXo8PhyKziABXd/KvmzwV4hvvD0YYFvk9RXceFfjNfz6kscrZTI6knp2pyZEY2PYJdN8nldwGO/BP8A9aptLt2M3O488bvrWn4ZKax4fWVkKsyg/wAv/wBVWdP0KbUrnZDHn+gz/jWB0KxoeD4mXVIFAJZmwB0xn/8AXXdalbMzCPgcEHj8vrVbwZ4GOlBZ5wfM5IDDp71rahbszqzdB8vPfmo5R30M20tGikUcNgj6H+tbVnbLEnTnvhqrQf8AIQRQRtUc5GPetKNljRSRg46jk4qJRGpDLcCMKZeSc42/jior2ZMEISCMkZB/+vUl2nnykL8w6Yq7p/hqW5mDFNqsOPUc1FgMm2tXvxheNw+8R0zWppfgN7xxsBfaMkLgA/nXqPwm+A1/4wuEitrN3WT/AJa7DtAHXJxj88V9MfD/APZV07wNpMdzcqLi6HLAjgE//roSA+dfhf8Asz3OvyRTXcLw223JyQS3PQZ71754J+FemeCLIR28IDk8sRls4rtINNhswEiQKqDgVVkiWJySMZ9+f89KdgPn+WESoA3JB6epxVK/01MthVGRwc5q8kqg5IGenXHTj/P0qcBbsNGVOQOBnOf8/wBK5LmyZ53rMDxFiqkFe+P8/wCTWVNM6g5zzjAIxXot/wCFvtrE4zk5B7fjWBqvhl7eMlYwQGx0HQ/5FNXGkcfKzKcvgnoMDmmoCwVCuWPTPtitHUrUW+crgggkdT0qjt2OrnOABk9qoGiVJGAAYDrn1NSKvmKCeGI+v+elRAMCoUEl+mO/+NT2zGJgwJ7twePT+lBASBZGywHH8R6fSgkGRht3bRyOnFOnOdrH5V6jgjNMZWXDLwSuADg4pWHccqFnbg4U888e38xT1fdER1Hr7UwFlcrkA5BbHYDFSSEmIHLEA88dfzpghYjiXuBkhhnp70+OHDFhg4GeD+JFN8whiVBwPU5z9aA5HJJOBnr0pWHfUdLNtQkZGOcg4z9KInwAC/GQec8VDywOQ3HU5/z6mpIiqgDBwvTnJ60tguTwSq6nY2AQOp5P+fpTJYyCzEA4Hfn6VJlIyMdT6HoaftJyAR9V6UNFIRDkEKR6L6UNL5ZyCCfrimbdg++Sc4NV5QxfkNj1z19acWA6e7eVvoOQpxmmCdVYBiMDqfX/AApdhAOOrHIJ9fx/zzSyRcoeNp4OenX/AOvVWZLY+NgkpJwcnjv+tTr87cqMYJGBzj0qJIyFXnHB5H0qSMsr5zu7Y9PWmr9SUiQwk49/XvWlb6zHoek3M7uqrChcljgcDNUEw8g24DAdCO3+eK4v44eJW0Xwq9uOTeHy3yeQO/6V34Cl7SsodzizGr7KhKp2PKfil8RLrx5rTySSlrVZCYlzkYP/AOquHvd/kMyjcoz17fhWusAupeSSxPfmva/g/wDBy2k0KK5uoklM2HO+PKkdhzX3VSvTwtNaH5nh8PWx1Zu+p8wHxLJZTlckEHAIFbGjePZ7Mr5c+Aeo3c8//qr7Es/2W/CHi5PLvNOhhLL/AKyJCCnuOfXn8K8l+OH7ATaWZbnwtqMbohJ8i54Y/Q4PSuVZrh6mktD05ZJiaPvR19Dlvhx8cdI0bUQdbQ7MDa6YLd/X8K908MftNeH309W0qKJo+m4EAn6j618I+O/COveEr17fULSeBk5O4frWZ4f8U32kXaywTyRSDqynrj1rixGX0qr5os7MNmdaiuWa2Pv3VvjdJqzFmzg4CjtiqkfxTRifkwDyDnOBXzn4H+Kd5LbQ/am844G5geee+K7238aadLpxZZgrshJV85GOK8fE5c6a5ke9g80jVkonT/Ev41vYaHLBbZWaddikHkHHX34NeN2CNDbtM/zHqDz/ADqbVLt9e1snLMnO3PTg9anlSN9StrQttjZgGIxwM818fiLupZH61gKao0OdkkXwmk8aeEb69kLRyY3QAdG+v6ivDbDSXudTaBMFlk2lufXFfoD4P8OaH4o0O1srG5RB5QiJIwR8vXp/LvmvmH4qfCm3+E3xNv8AR7a7S98iQM8iqRsLDdg+4BGcfTtX0+SYVSlZn51xZmr5eaL8jC8HeGIdKRZQgLqQwOckEV9d/sw/tU6l4tv4PDmpXJlljjPkSnA3BcYXgV8pazfvomnbtwQYBGOOa6z9jnU2uvi7bag8hWCzDByzYPK4/wAK97MaNP2T0PjspxdaVZa7n6F6fcNMFckkOcAf1q1qmtQ6Lp01xcSRxwwKSzNwMVxMXxS0rTLUO99a7V6/vR1/P/OK+ef2uP2oW19P+Ef0aZ1hPN1KjAiQdQuf518JiZcup+p5bhZV5qKOX/ar/aRufjD4lk0yxmYaBYSYjC5AuW/vn264ry2wsXmmQIpZm4AA61TiACsxIHqfevpf9hf4NaLrl6viXxDcW/2e2YrawSyKFkYZ+ZhxlRzxXlxi6kj7ipVpYOhpsj1/9hz9kpfCGn2virxBbBdTk+ezhkXJhTOVc8/eOAQCOK+oS42Dnp+Nc9F8QdISJNl/ZkKAoCyqeOn9KVvHumFc/b7YIeeZAK9KlQ5VZHwWNxk683OZuzyYiHbIwWz1qPJJJ5B7571hx+O9KnBK31qR6ecpx+vrTv8AhPtKiRWe+tlPYGQc11RicNzcPzDP3T602R8oSc4HbrWHL8RNIVcm/tAG7GVQfyqA/FHRQrhdSs2C8H96Mj9a1SMzcZ94JwfX61EX2k8Zxz9axB8T9C2s/wDalmB6mUfNjt/n+lMm+JGigMTqdmMHaT5oxnp1qrMhmrqkwjtyRwR04r5t+OepfbPGE4Jyy8H0/X0r23U/iXorRHGo2OMdPNXn6c186+PNV/tjxLczpIrIXbBU9v8AP8qaQjj9WYtIVDAdutecePpgJG3L7A16FqTjc+XG7JyN3Xn/APVXn/jTTJLwvswRnse2f8/lW0CZHyD+1fdGWa3UkjknGeg/z/OvBJwSfr719N/tFfBjxF4n1oy2mm3VzGiHJjXIxn/P+ea8qb9l/wAYiUKNDv8AcDjaYjke2OtdlM5qm5H+z1ZNN4pR1PzIfz6V738NiNc+PdhaMfm+0RKTwcjcpHt3/wD11wvwN/Z+8T+HvEXm3ek3UMYA5ZCBnIr274JfCe/0r40aZqdzCIIEugWkdgOPX8Dg1b2MuXU/SvwlFs0+2AJIEag847DmvCP+ChENv8XviD8FfgtI7fY/iD4kbVdZj3kRXWmaXEbqe2k2MHHnN5e1hwGQnORXs+mfEPRbOAFtRsUVBkkzKAvTvmvCvgL8RdG+LH/BQf4q+ObvULNtK8FaXZ+BdBukuF8idyfteo5BP+sjnaKMtjBGACea4IK0nLsb1NUo9z69tpcqCOo5qwjArkkjHpXKj4o+Hwcf2tp4LdP3q8/5/wAKlT4naFEhb+19PKg4ObhRg5x69c8VjymyNnVNMTUoiGAYD37f5xWWnhS1tZMrHyDk56mmj4paEp/5ClgQuckSqf1zjrUZ+J/h+Zd66vYn02zrzzj196OUEZHjWB7LT22Kq8de2a8e8UXM1xMfMJ3c4HXNeweJ/iX4flsZEGpWLsyngSgnPv6V4j4r8U2F7qTm3u7dgOQVlUjjr+tNIu5mzJxyckDp0NRDI25HYk88DGaZLr9qrFDcRhuMqH5NX5tDmawiuQv7uQ7gd2MClIVkZsi5lK/LgDJaoY5MjJIKk88dO/8AhU8sex9oPTGM96rHcHO3hQTkev5f54ppDCYYdSeg9hVO9czRZX72OPY9v1qeTG44I44P6VGsClP7p5bkDH6UyLMw7jcqkFeo59qrFS+/JPvk8H6VtvAjkknrmqstgo3EdCeuaBGLNa8nPfv0xWZqenqYnPDHP4V1H2ALA+FBHc4NY99ZEscAMucex/GgDmMvDMPl+UEYPr/nmrdpMoVV5YDjHXj8ak1WwaWInocVkQ3T2tztk3ALgfjQBv8A2sgYQhccj3rX0nVfNiGW245IbjIrl47/AM1htDEscDHftmrsVyrSBWI55HPU1DKR1Yl84DnIHPB4FNdjCd64z+HH+eKx7LVShwWIUY5Jz/n/AOtWjFdC5jBGePWriwe5MusSQkEtjPVSKyfHPgix+LmhvYXkMRkC5Qkcq2KuSKCxIyD+o9qZod61rqYDAtg7PxrZTsS0fImu/s5va+L7m0MZW1hcgPtPzDp/nNaFv+zbpenX8U6SsdnPIxkfn9a+rPHHguHxAhuYQPN9AuS3+eteX+IfB2oR3DRi2YFTjPv05/z61XtBWOf0TS0gEVjbISFwgzzXq/hXwhB4atQcq05zkkenb1rG8BeAm0dlubw7Cq4APHPHOa2L/VCbxjHkpk7cHr19KnmFymqzqpOHye3fFRyWSyITvBR+vzd+OayEmmlc8kt355FT28V08BRQzFiNpJORxRzDexBPppgnkZWBU8nviltZ2mZlwdwbqelbGm+C9Q1CDeymNSQMn0Iro9B+G4u5YonZWmY4GDjP4UmyVsUfBnhNtavkVIzK44bgnvzX0r8Hv2WotTeK41U+XGB/qwevpXLeBfh9f+HrGEQWx2/eDbc5Irc1nx34j8PQRjz5okPUbQBjH+fyqWy+h9LaF4e0nwraLDYwQwR7Qvy4zgf/AK61dWuEm0htrhjt+or5Z8H/ABi1jUNWEN3dFgzDHynjI6+/5969+8K6g1z4fG5yxdcj0xTJ20KN1hpMg85Pr9P8/hVK5fLsOBz0xnNXbtxLIwCqv4fzqhKxdzk4IHPrUtWLTseCtGtzL129+tTQReWMbAGJAzTYSQA3BAH58VYVSn+0v5HmuFG1g4ikJHKnkYGP881ma7CqQPtOOwPXGTWu6AqrAjk9Bk1l62+YiMKcdv8AP+eK0JtZnn/iS0K3BY4YjkAnjpWQIiYSRtOfU8H3/KtTxTdyGZ9g4JwST1H+FZUTGSLOduMnvxyaCyRLZZ15IXaM4OOR/hSwWx3n/dCnJ/SiM46enVjTlbevQg5xxxSTFYXycAZPzEDjGM+tPGC4YjnOMetNWfdgnaCeDz9KGkwxBHU4GRjHv9aYNEjHLk9Qcj0waUyhkwOo/DpTGJAHp0HuKblkccHb6461LYJE0YUkhS2ByCOD7Uu/YgKjJPQZPGOo/WoVkKkgkjggZP8A9anpJlyuCcnHIxTuMcsIZDk4UY//AF/59adFEWbBwT+o4oQKinjk8/T/ADxT44jHLj+HryeSeP8A61DQrCtCUBztGTwc81JChKhSPmJ9O3Smq7q5ySTUgcMykY6Z44/ShaDGug28DJOOnT61UkQxk5wGz/k1cGMHlh/Fn0xUVzaB2DKTt478DPNSnYGd18Lvg5J4/snnNysCqxAyu7JFdgf2TXxxqsZxknMJB/zmtj9mVS3gtmAyTKc8Y46V6pBAxT51PPQ0+YVkeJr+yXNG2BqVuQcElkIwf8/ypX/ZSubdONRtTnJ4Dc/pXtkzi3iZmIQKMk+leS/Ez9q7RPh3qL2U5Msq90IAH4n6U1NgkZY/ZVvtrbdQtOT8p2npzXF/E79gPWviBJG0OradCIVO0OrZzkc8dscV6x8Mf2pvDPjl47U3Bt7hslRJjDe2c/zr1m3iLRBgdwI4rfD4qdKanHdHPicNCvTdOpsz4lj/AOCX+vROu3WdKZAScMHBP5DHP17/AIV6/p/7K2qadYRwR3NmUiTaN2egHWvflhJcqMnPA60t0n2FyJCwJ5PHH6114jMq1e3tGceEynD4Vt0la55Dpn7PWq2UGPOt2YcZyap6j+zZrN8CPtNrhhgncT1/DtxXudsPOjDfwnPU80rw4GOxFciqtdTv9mmfI/jH9gHVfF5P2u40uZZO7Z4555x9Pyryzxf/AMEdb68cS6bqthbyk5KSMSgOO3GfX9K+3/iB8VNH+G1k9xqdysCoMkEZJrz/AEH9srwb4l1KOJbqSDcflZx8p+v+P/666qeY1YK0Wc1fLaFX40fJ+j/8EiPHOnzHGuaGkQOFw77jg46BT9a2If8AglZ42fh9Y0JsL/fcHP8A3zX31pV5b69pcN1ayxzQTAMrrggj61eSED268YqqmZ1px5ZMxo5Ph6UlON7n5+6n/wAEzvFfhHw9cXqXem38lsu4wxOd7/7uQPbv615vqf7EXxYj1ZZbTwlqE0TgNuUDHsOT1/8ArV92fH74hz+E/FHh+2LFLW51S0hbDbcmSVVHuevTvXtbSFQcYIA6ADivJ9lHm5j6mrmdadH2T2PzO8MfstfFbSGjjfwrqls54VgwyDjP972P5Vhar+xP8TtW8QzXtx4Y1N3uZSzOwDHB9ic8DtX6li8iMq5dA6kkBjinGRXbIIYHj1xXq4THuhrFI+YxmWQxMeWbZ+UvxR/YZ+JNzDBBaeFNUuUIG9oot2w8cHH+eldB8CP2LPH/AIUsNQSfwrqlvJPD8nmQYVvYH19vev09Qc559xSNeBV5YZ7itcRmc6qtIzwmTUqElKLZ+Jaf8E+f2i9S+Jd0txonitNHe8kZZVuSUCZO0L82emAMcflx6pb/ALCnxRTAn8K6u7gbixjJJx75PNfq3bX6h2AkGS3IPY1ciJKDoccHvXjV6SnufU5fmE8LflVz8qbj/gnJ8VfHPgm5l0LSoIb1WMOy5nSFonGM7gxB6Hjg547V53D/AMEd/wBp6KLy49TaKHOVjTXgqjOT0D4HTp+Ffsh4TZpbzW9wwY74ouD28qM/1q5qWr2+ko0lxKsSZ+8x4ooU1T0RWOzGriWufofjbD/wSC/adR1267cAFQcjxA236HL9eBTpf+CQn7Tscj41+5dQPnK+IWx9PvgHv+Qr9h7DxTp+qvi2vIJW6YD85+lX4owCSSefU11qp5HmNX1PxqX/AII8/tMEAJrsql/vE682AMY7P6dqcP8Agjv+0yzgf8JC4Zjk515iT+O76/nX7LNnYVxuXHB9qyrjxJYwXW1rqAPyArNjFP2vkRyn49yf8Eav2k3mUvrLZICFjrpPy8jB+fOBn9a4vxh/wTA/aV8LeIjpSQ65qUwtxOXttUMsZXcVwCHPOR09CK/cqynW4hDKcg89etYNrPt+LMqbiQdMDYzkf60801Wa6C5T8QoP+CYn7TMrqP7G8To7HaT9tb+e4VZ/4dSftLujSnSddbjDA6iAcdOhkHGM9fSv3Te6EOBwF9cYqNNat5ZSvnxbm7Bh7CmsQ+wuQ/Cyf/gk3+0xLJzpGssSSfm1IHr/AMD74/Skg/4JE/tL3EnOi6oA3HOpoB0z/wA9PQ/mfev3dimLgYCkdORS5wSACNvtR7d9g9mfhMv/AARw/aOkAzpt185wc6kvHHf56S5/4IwftGoxJ0uZlI4I1NRnHbl6/cu91eC0K+ZKkWD/ABMBmrUGoLcqpWVWXtg54pquw9mfz2fGn/gnH8c/gVZ2V1rGi6y39oymKEWs5nLEDOCIycdDjPpXAj9mz4vOyY8O+L28rDDbFMSn5cjpX9HviBh/wk2hZClGuJB1HI8p/wDCtx40Dbti8cnI4FWsTboQ6J/NlY/sj/Ge+Zlh8L+L2IxuXyZsjnjisbVfgL8VfD3jjSPDt7ofia0vvECSyaZbyrKrXzwqHlVF/iKoQxx0H1r+l25kiQZ/dr78V89f8FHP2cL79oH9naa58Lh4fiF8Pr2Lxh4PuI4llk/tOz3SRxbWIVhKN0e1srudGIO0CqhibuzMqlBpXifiL4k/Zb+M3hLwrqWsaj4e8WW2naTZy311NKsqJFFGpd2bPQAAnmnfDH9iT40eIvBdhq2keFfE8tnrsSX8U8UUipcpMoYSAjqGRhyOoNfpv+2l+1do37bv7D/wY0nQb210aw/aA8QWsGuQ3Mxin0vR7BnuNalWVzGu20e2VXkOFePdgEOCO78U/wDBRnX/AI++Irvwl+zP4Mh8bDT3ezvfHGsvJY+ENHlQou1HVd96w3Y2Q44KOvmISRd5KO39IzvBzun00+Z+Wsn/AAT5/aEXBbwj4vIxuGBKR6+vX/PWrOnf8E8v2g73UI7Y+GfFUDzMFVpZHVM/7xOB/wDWr91fgL4f8WeDvhHo+meOfFFv408WwRP/AGjrMWnx2Ed27SMwCwxjaqopVARgts3EAkit/wASxB7RQFACTRHPc/OK53W1sdSp6XPw6tv+CTP7SMyZbSdVTI6HUMEHHpvq9Yf8Ehf2jNQZ1a2vIQnGJNSClu3GX/n71+40i/KCCcVn3eu2lldGGW5hSUjOxmAYj6VPtR8h+KLf8Ea/2iGc4jkLk9Tqi8gdOr1N/wAOcf2hgA/mOrKPlxqvJHXj5h3r9roLqO9jyjqw9VwaJI2A5zgCj2zFyI/Gnwb/AMEgv2gvDmv2moXEyiGGQO+/VcnGfTdz619zeFP2XvGsPgyxtL9Lea4t4wGKzgqxHYdO1fT+uatb6ZZSvcSxRKqkku2AOP8A61ZWg+O9N1aRYYLuCZxgbVcHNRKpcqMT5r8Q/s0+INA06e8nSIRWylnKODx3PvXmN8vkthlztyOlfcnjy3a48GauI8bmtJR69VNeL+FPhdouraLA9xYo8sq5dycHPPNRzFNWPnSJ2a4I+bHPQf59KmniIBK8kDgEda9O+JfwTvbbxNL/AGdYubUY2BRkEcZ/z71w3iXwvd+HJFF1HJAWHAbGDVJkmJJF+6GBySenrioLlMrhjknseP8APevV/gp4E03x1p93JMpmeIMse05+bbn8a5PX/hhrFteShbGbZvwOBx+XQVVxNHFtAM7uSSOTk1UurHzlfJAHJAwTnHPNb11oUmnXey42xnocjvXpGofBi0f4bDULdZZrssvC9CCCf8P88UCseCXunGPIZdvt0zWPe6ZHOckZYZxXomseE7u2jeSa3lRYxg7h+FU/Cfgu38QeI7eCZwiSsFJU888cUEs8vMb6bJsfI7qcfeqaG9DsFJJJ+XJ5r2b41/ABPCSwCyR7mKWEOX6lTn/9XfvXkV74H1CxIcQONx4Xng0mhotRzedCuXBcZyegA/lWjb3LR4IOPXPrXW/Bb4Jr42MkVxP5TKoIQLuzxz6f5Ndn8Rv2aIPBvg+XUFuTJsZVI24JycUKyH5nkRvmA7dgSO3v1/ziq8chaVmz9MdqsNpu+QhchV4Hv+XFA0jzOQfcfzqlqJ7luwu5CwUSEggg59KvtqSRW7kqryEY+p6UaB4J1PWYw9vBJIqryfTP/wCv9a1o/hlrAbBtnDDk4BOPb0p7COP1BbnVLjAUhP4qtaX4GkvAHmkRUOBgn+f4V0qfDfWB920lPOD8p4/zmnP4J1uzTaYJkx065/zzQmA2w+H1lGN0jLuPfPX2/wA+1bmnaBZacQ4KDH6/n/niuK1ux1HTZtreZG/YZIzmsLUNU1CyhkZJZAVOWA4Hbn/P9aLgeu309rDAzhl2ovQdKyfCXiYSeLbcdUMo9Tjnr/n3rx9/EmpTXAMk0m0Dn3+ldx8Mt6avavKZGG9ST9f09qOYVj9I/hf4Wsr7RLORoImDRgnIyeneuE/ap8F2OnRKsEMaeYMkKMf5/wDr16Z8D4WuvDFhkZygGfw//VXln7Wf2+6+IDWqI7QRIuNo6MR/+qjmBM8P8PaWI9VQt94MBx3Oc19B+CJduhImdysAc5yCegrj/h58Hnu4Yru+jaFfvAcENxxg4r0i3sI7KERquwfdGPpikrjKE567Txj8veqc7Ek4JwDyOuKuXLgTOBx6e1Uy2889uKGgPBEhEaMMgbTxyf8AOanFw8MxPA288DH+eKY7bAWBIK9cmsvVdbFpb8hmJHrXEjpsX73Wo7MNvkxnoPU/5NcxrfihZJCibdpPToxrF1PxPJdyMu4lRyDjAHbH6frWVc6g0kIDAnJHX6//AFq0JaJtVu2ldsAFW43f5+tUIlIALDnntwP8mpQ32iTOVHGcmnCJXXDEL1PHegYqqGCkKCe49aeUCoGBGfccVHF8uSQSc44/zihv9bn7o9e/0pCbHW6FlwzDJPpj/wDX/n0pWXC4Bzkf5/P/ADmpUIVQC2Mio8qZWwN3Oc56ilZjHCPco4bJOQex/CpOV+UjkYPT3p8eQqkKD/snp16+lLnz2BK4ZcA88U7ARPCC4wRz749utSwx/J0HDYweeMZqOYkkYClh7479acke1gT0HYZoYCs4jcHC4PPA/wA/5xUnn73QjIyOnXk9f5U3aTuI4fr0/Kkj5ccY59elRcCaORVdt/OOM4z3pwRZSCAcAYGP8/Wlh05rhsAFtxx7jmtOw8OXVw67YiO3FFwKKwbFBUjPYZ7VOqncdvYYz1PrXS6f8Pri7kAYDcBgHqBW7pfwmDBS7ADOMf1oA739mKJV8GuuDxKcEe//AOs16mttggHpgYHrXJfCXw/FoOhGFFG0NnjiuzETPjaAT3z1oA4j9ovxWnwx+EOrazKW8u1hdyR7A1+Nvxds/F3xu1/UvEOpX91YWjF7i3syxUCMEkY564+tfsf+114Cl+If7Pms6bCX81VErAdWRSCw/wC+Qa/NL/goxo8nwU8TaXoOjWv2+w1nRbfUIr0ZYRCUOrxggFSwZSDzx0x3ppjSOY+EWg31p4Nils9Vlt57dFKM3zFW7fUDHAr9N/2HfiRrHxO+A2lXGuuDq9nutbmQg/6Rs4WTHH3lwfrmvyD+Fn/CVfD+BJ7e1lvZbiQMbWRWOew4BzX7HfsZeGtR0f4E6LcaraCw1LUYFup7fkCIsM4pslnppf7LcRSYDbGBIFXNUki1OJNhBDfpSfZAexI6dadFZpFIPlx2yKSYtWR2tqIogFzjtnPFJcho7WWTtEpY8dhVtIPlOQeT3+tEtt9p0+5hJ2GeFkBwCFJHBxTuET8kv2/vjX4j+MPxR1Wy0a6ng0PR5WtpZk4aaQDDgHPRenGD+VeNfDaLzoGWbV5oruFh1uCrBex59OfpXqvxMtpfhn8P9ck1RGXUtKvbmK8jKnzTIZ3BJU4OeRz6c18m6bo8viUX15LM9ig+ZVdz8wPVRxzgelXFXKP1j/4Jk/GO81mO68PTalFrFlEv+izK2WiZPvIe3fPrX2QIjHnjAJzk18Hf8EbvgHH4W8Iv4giWfyrnnzHY7XcgjC9MYBOfw7Yr78ePy8YHIpNAfMX7c1lNHqPhZ4izStrmmqAvPzfbI8fzHtXu3xh8fW3wo+Hl5rV0CohU7AQWy2M847cdq8N/b9RLM+FJ2JKpr2mFjxwReRfN+Fdf/wAFJXaL9ka/vEJQWkgVyDjbvIXn/PXFNIpM+MfGP7d3iHxD4jubk3rQQFz5cbEYXk44xxXsH7I37bD+J9dt9Nv7k3Dzj/VlwwOBzg+uOfzr8k/i98Yry816a1tnbCyHCqxxWz+zV438daT8V9Ak0e1urm4fUIgkUZOWJYZGO4/Cr5A0P6KrUi6jR1BKuoYH1zivlH9vv9s6T4N3zaBoM0ceohd13OTgQgjpyMZ/Wvqfw2WtNEsBOrb0t4w4J5yFGRX4o/8ABYTx5qcH7VviDwzBNLCJLgTXEwJH7t1BRc46BSPypcqFY9F8H/8ABQzxBY+LNreJxIFcEK8/BYsOOuO2a/RH9jv9pFPjx4WlW4UR6np4VZwWB3jj5h+OePavwBvfDml2vlpErXjlcuxPf2xX6Wf8EKo9ZX4ga1DNdTXWlR6cJY2f5zESwGzd+P4UnHsUj9NvCKLjXnYnybe9Z2Y9QBBESSfz/Kvzf/bG/bJ1fxx8TtRsNN1Caw0fTZTCkavjzGVuWIzg9B/9av0g8JoZ9O8WQKC73E8qKoJBLG2jwAfxr+eD9qX4oX+nfEzVtKMcq3VncyRyo2VKuGIIPvnNEVdg2faPwY/bF1HTL2Jrm/EqhthlR2L5BAznPXj+dfpT8D/Hp+I/ge21AyCQtj5wQdw6jpx+VfzheDPi1rei6vEUR2bfwEzkk+g9a/fD/gmwNSf9k/w9earDPb3F/H5yRzLtbYSdpx2yCDV8tib3ND9vD9pxP2avhUk9vJENX1TelvvbHkKoG6Q+gGe/f8cfl1rf7fl3deLpUk8TSzyXBxI6tuTOegPTAOf8a+hf+C+WheIfEd98P7W0EkWkak1xb3FwjYVGTa4Rvcgsffbjtz+ZuqaJa+H9YW0ECS+UwWVyhLA5560KIXP16/YG/a61LXfENlo1/c/abG+wsUjZYhjjHJPQivsizk834rqp3Yk0vIG3/prg/wAx+Vfjn/wSk1m81/8Aaf0PwxYGe4tLnN0Bg7bYxruJz2yoP6elfsrp4MPxjslbbsGlscepEqd/y/WhobXU+SP+ChP7bl18PPFt34Q8Ozi2uLJU+23GQNrNzsX6DGfxr5w+G37ZniBdQge71KR3Vss5kY8c+p+lfN//AAVT+I+u+E/21/iLpFzFNE0OrzMu7KgxuxeNge4KMv514b4A+MGo6PqcLOzqMjJDdfrSUBM/oI/ZY+MTfFbwksksomkjUHcTknrwfyrc/aP+O+mfs8/CnUvEepYb7OpS3h3BTPK2dqjP4k+wNfOn/BIDVLnxJ8LL3VJEY2sriKNv4SdoJwe/emf8FuPhf4i+JX7K9jH4dlli+w6tHNfBCQ3kGN1JyP8AaZR6fN9KLFWR8cfEH/goNrHxC8dXU8/i5Y2mdlEMUvliNSflXjjgcZ9ua95/ZQ/bC1vQ/EdnBfXU15ZTsEbdIWGD3578D9a/KG6+Hllp2qSW87uSDwwbj+VfRf7DOtaxpnj/AEnw/cvLdabqsm7Tn6ncJMMoPUj+RFNwstB2P3Hv76LVJ/DNzEDtuLskZPIBt5W/wrzX9tr9ra1/Zl8JwQQKlxr2oxs1tCT8sagYDtyOM8cV6HZ2b6RZ+DLeddksVwI3A5wfssuf5V+Tn/Ber4keIPDP7aFxaN50envptq9m27ClPL+bHtv35981KVwsevaP+3/4g8UaiJr6+dZGPCxN8oyeOmOmfrX1t+zF8eW+JFnFDPOs24EI/BZmHXJHfj65r8Lvhz8eLiLVY47h3wSFw5yMV+o//BMLWrnxJe27ruaCBssw55YA80+WwWNHxN/wRs8Ap+1R4p+KHjrXBrPwsgnu/E1l4Nu1lWz0rU5zbyXdy7ebteJ3gZjFsVGDIrArHhvJfiP/AMFGHXWodC8GW+k+HPB+kYg07TbGGO3VIVPyAIoxGMY+VQAK+1v+Cjug6vr/AOxD8QLPQ3mF/Lp45iPzmMSKZQOCfuBq/n7k0JtK1iZbiSTzUflt5OfXJrSUpTtzPYyhRhC/Ktz9VfgN+3V4l0/XoTfXBubeaQbkY5UA5yAfx/DjHv8Aedl4lj8W+BLXUISdly0LjPbLrxX4p/steK7jVFhsLt97gK8EpP31J9fYjH41+wfwHsZ9M+A+krdrIJHELjd3HmLg/Qj9DWDunY1sjhv+Chv7X/8Awyx8PrSz08xDxHriM9sz/dgjUgM+OMnPA+hr887T9qLXPEOqG51DVpruaR95LSNg859fU16Z/wAHEvhDX4vFvgbxRYwSNpI05rBpADhJFkdtp4x0bP8A+qvz0+F/j65GpIksjBtw3ITnv2z3p2drmctGfsD+xd+0le6jcW9hcyzTWsjKgUjIXJ4xn/OBX19rOtW3h/w/eajeyCK1sbd7iVycBURSSenoK/N3/gnPpd14t8VQ+UGZLadNzY+6uBjP41+g/wAZPCEvxA+DvifQrdsTatpc9rCwbadzRkLz25xU6rQasflZ+0T/AMFF9W+N3xJvYYNZ/s/So5mjtLONtqBASAWPUkjGece1S/Bv40az4Y1mO5W9ndHYFm8zkY75r44+KHg678FeK9Q0vUbOWy1GwneGVX4MbBsEV6/+yf4jn1a2bT7wiVLVxtbuVx0/z6U2gVj9d/hr8Q2+IvwcvLl3fzFspAWPBOEPPFV/hupn0OzJALeWpPHQ8VX/AGcvB8mkfAWZ5YjbyXljMypjGFKHHHb/AD0q98Nov+KdtGBB+Tr6UiZHUatEEjX0I4r5t/aluPN1ZIg3l4jL9O/evoT4meMdM8BeF21LVbuC0tIlGS7hS+ew9Tk4/KvGpfCdh+0paR62lxNZwOCkIVQxZR/jTTIaK37CsbS2V6H371nYADoflHPT65/CvcPENgLYFyuByCOPSuS+Bfwzt/gvHMkFy94szb8su3Ht15/Su413V4daOBCF4x170XYWPi3463DzeKLkgHa0x46LxngV9NfAOwA+F2ntnzMQKCSOvHWuH8b/ALLq+KtUe4/tIRK0m/Hl8+uCK9R8D6YPCfhmLTt4lMUYj3hSN2OM9T9a0buCRy/xcCQeG7sBIx8nUgHvXzJ4Nupl+Kunr/AZwucevH9f1r6v8d+GH8U6WYUkWNmPVunuPevLtD/ZhudE8ZWupC/tWW2kDkBWBYen+fakNRPTfFviLRfCXhyO61i4sraKNB805Uc47Z+hr5/+N/xp8J+MbVI9Ku7O4mizny0xnHA/r1r27xt8LLHxhrlrqt5aRanNpyBba3uGJhiPOX25wX6ckcY4r58+MX7CWuePPiZJ4h0m80vS45juktUUrGnYBce2euKIy1CUTV/ZDv8A7drt8WbdgLx1xnP+f88ezfHFA3wtvM7hhl5Hb/63JrkvgF+z5f8Awnmea9nhnkmVRmMng9xz2r0D4meG7vxX4NnsbbyxJMVILtgAA5NVfUz8j5KeziZm+X5h3AHy/jSxW6nGUHbaOlen3X7M+sxRZD2zkt1Vs55+lRD9nbXgo+SE85yX6dP/AK9UmDJvgT4ytdDvltbrYqu3yk4Cg+lfT+haPYajbxusEUqMAc49QK+U5/gxrPhuF7yWDEVv8xdW4HOPTPUivVv2a/jErSHTLty7pjaWBFNjSPboPBdl0FtDk+qipp/B1hLGV+xwZ6D5R1rSsbkXADKVIYcc96szQCMFhg4H+f8APtSHY+TP2i/BkFt4ocLCiL2CjGe/5e9eKeItGjMTblB7FfXFfSn7TMTJrrNgfOo49DXgniNDhgRyx5PX8/8APagXKcF/YyDBKq6YyCvWul8DWwj1GAgZCsATurP+y53AsV+nY1veEbc/b4wTg7gQx9c8frQNRP0j/Z3iDeFdI2g7XiQDPqQM/rXWeL/AlhrvicNcW6O24KSa539m6Pb4J0t8ZXYrLkdB6fpXd67GW18Mpx84PTrQZs434q+GbXw/HFHbRBEPYLgV53qSNJjnHOeP8+1et/G9NyxYxjb3PBrya8O0txkZ6jtVJoEzJmB3MD1PPI4IqExsiNwSf89auTuNxGNpHGSaq3B+Y7fmJ96bVxnz9qZa3ty2OQCRk4LVxXiTUnjTcDwMnG3oMe1dXqqO43KRgAnpz0x/hXGeJLSSSNgQflPy7cciuJK50HPXE4kPmA8H06fWmSygqAvfPIqq1s6Sne2VDevHp/jUsUPmsGHKdyD0561Qkx/2tS4BZSQdvHb/ADxU3nmVWxhSOB7dahMKxnq2frx2qUKxjAUgnocfnQDY5F83ORkDkeh9aUrnAOV2nJPB2/8A6sn8qWOPK45/L+lLFbbmXHYY5PUdaluxNhQ3mqoJDLjrjv8A1qYhRCRzu7YHWnW9i5lTKgD0xitCDwtNeyAJG4DHk4P+fWi+haKEJEke3hcHB4yasJGEiwCSQcHn9f8APrXRWfw4lYL8pHPJ9+1bWl/DTymDuDzxjAoT7gcHDYPONypnJ5AGO/etKx8OT3mcx5B4HPQ/5/nXo+l+Dra33b06+q549q04dMt7RSqxgAcjAJobA880z4dSXB2soV85JPaug034WR253S4Ck5HqTW7Nr9tp+VwNw6gc5rK1H4jqkRVULH1GeOfapA07bwXZWydFOP73TP8A+ur8UFjYou1IgcdsZ4//AFVwr+Mry8cKGKjsFBAHP/6q6Xwp8LtX8Y6elzHdW8COeBKTlhgegNROVlcDRHiK0tx99WOc4HNMX4g26yfIBu9SR/jXJa/o0mi6jPZvMk0kLFGaPO1sHkis+KDjduOM18/U4oy+EnCVRXQ7H0h8HdUGuaCZsFSXwRnqa7e3TYm05x29q8K+E3xbsfBGhC2uYZ5nLl9y4xzjA5Ndkn7SWklSDBdJngcKf68f/XrN8W5b/wA/UPlZ6Nc24uoijj5WG0j1/CvGPi9/wT98E/GAym5W8sjKhXZA48tSQeQpHB5B4OOPrXSSftJaXGmBa3bvz/dA/PNOj/aY0+NP+QfdOCMjDKMUf635Wv8Al8vx/wAhqLOQ/Z1/4J3eC/2etRF5FLfa5qKkGO4viMxYJxtVQB0wO9e92toLePavyrjge1ct4J+M2meLr6SzRJIrpEM3l8ZMecZ9v/112tmgu7cuinHTJAr3cHjaWKpKtRleL6kO5AqFWbOD3zil8oA/1znirJtgkgO3r0yOaDb7evT+VdRPMQ7MoAOnY+9N2kcYJPc4HFTSQkKdvTNLBGSSfm7E47U2ho8h+OX7HPhf42apJqNzD9i1C5TZdTRIGW6AXALoeCcYGeuBz7eZj/glL4H1p4k1e4udQtYWVkiihWDBHAGQTx7fWvqpkwpGM/h0qWGDzLeNyPmfII/EimpDOf8AAXw50n4ZeGbXRtFsbfT9Os1CRQwjaqAADnuTxyTye5rda13LkAnAqeNASB0H51KbXMPQjPai92B8hf8ABVLxFa+DPhXo+r3kgittP1mxnmbBJVVuoiTgcnhf0rrtW/ad8B/tD/A68064h1K50DxTp5QsIVWQqw4Kg/dYdQSOoryH/gukhi/ZPnkIKkXlsAef+e0ef6V57+zDEH/Z/wDChCtj+zox75A5zWkTWEbnzN4z/wCCX08XjTU7jTdftLrTZJmktZbqJorhV7BgNwyOmc84z7V9GfsG/sreC/2fNRtfEviW9u/Eet2b+barBEi2tuSGG7lsucHvjHoetc1+134h+IWg6Mw8G2MNzbPbyteTMQr2wAHK/MMnBY9+nTtXBfsIeMLnR/2YPEGr3dxNcDTbu5l/eMSQqxIxHr1zWiTK5UnY/Sy7/bI8LxzCHbcK5X7rFA3/AKF9K+UP22Pg34M/aR8dReKraO5sNTMAtr3fCjC6jUkoSd33lJxnHIxX57x/EvSvHtvqOt+I9b8Qw+KLm6LWk0OWt7UfKQW53AZzgJ0x36V9f3/xQ/4Qn9kD+37rWIdZuV08xwX6I2LmRvljJB53Z2hs9wafKUonhnhD9inULjxDdRxTafdQiUqAQeBz14IHoR/Ov0W/Yhg8FfsjfCxdIsrTUbrVL4+bqF0yriVuoRQW+VF7evU1+Yv7GXjDVfg3+0D4fbV966d43tjCjSMcSB5CI3+vmKR9G96/RmygaWNWTIBx+PFTO6KjBNH0b8Lv2ofCmpaz4qtv7UigvrTUo3lt2yXhV7WAqTgd8HpnvXgf7YX7AHwN/a68WXHiOS/m8L+Kb3D3N/YoPKvSP4pEIxvPA3DB9c15x8PoJIv2i/iMrbiGOmOpYZ/5dQCPpxXa/FP4j6b8JfBN1r2syy2+nWJXzpFjZ2XcwUfKoJOWYD8amLsyXBMzfgJ/wSo+AXwc8SxatqWuXfime1w6RXqhLfcDkEooOcY6ZwfSvsmx+LXhDTrGO2t9StYYbdQqRqpVVGOAOK/Mv9mv9tm//aK/aH17RLW1hg8NWVmbizd42W5fayLliWwASx4x0A75qn8Zf2tvFsvxpvfBPw/0/Sb2/wBJi827ub+X90pwDsHzqMjK9T1OMDBrazZFkfol8cbH4aftBeCp9D8Ry2d/BIpKbgcxOVxuUjkMATgivg+9/wCCS3hpPEd1/ZHjSzjtLhiUivLQy7B7NvHOOmRXS/srfHLX/jB4Tvh4l0R9F1bSZRDKQjLDcjHDpu56g9z255rw/Wv+CiWqaP8AtSr4fC2D+Eo9VGnzT+UfNwCI2cNnGA+T06Z9jQlqVyo+/f2L/wBmT4XfsgaS09hq0Gpa/ND5U2ozKFKISCUQAfKCcdyeOtbfxs/bN0f4VftBeB9Jhgm1UeK7K9to5YHCpA8Rjky2euRxx615rCfNVXU5B5BB7V5B+0pZCf8AaW+CLhVdhdakCWAII8iPj1o5b7g42O9/4KA/s8eBv259Mh1Gewl0DxdbxrHHqsSLJ5yAHCypkbscAHOQPUcV8u/DD/gkboHh7xTZ3fiPxXfahZwOHltrS2WIzKOq7mJxnp0719oXVu8VqSo4xnPWvg/9pP8Aab+INz8YvDelvpOpeD9L/tcRRuzsDqqiVU3ZKjK4OdvI+bntQl0E4o/TL4SfFHwn8EPA9l4d8O+HxpmjafGIoY43AOB3JI5J9c81p+KP2g9H8X6Hc2F1pT3NpdxtFJG7qyyI3DKR7ivgX/goP+0Nq3wo0nw/oGi3w0288Qynz7zZ81rApUFlJ6Eluv8AsnpXM/sjeONUk+N/9l6V4+m8Z+HPsxkuVv2dbhXxjdGsmWIDYGQcYb6GhILLY6z44/8ABPLwN4kui3hm3utHeTcWE85mw2cjHQ47HJPX2rvv2JP2UvDv7NPjW08Sap5+t32mK/2GHAWGGR8BnAOTnAGB69a+ff8Agop8bvEL/E6w8JeFL7U7ebS7Nr+/+wTPG4JBOGK4OFQbjzj5hX0V+xv8VJPjH8BNH1W5m+0ajGhtr185YyodpJ9yMH8aUloNJPQ+oPHX7VIjk0GaHSm3xaiD804AOYZR6eprwv8Abz+CHhn9vix0W41m2k0fV9EDRxX0BEjPE3JjKnGRu5HPGT61seJbNp4tMVcYF9GffG1xgfnWrqFhM+ly+UQJnjOxicDOODz71MUNwR8PeLv+CYfw80LXNMtLvxtcabeXkm22jIijkuCDkiNSSWPtzivrz4L+J/DP7C/w2O+4sorVfmlvb9xGZG7ZOQOmBgV8LfE/wN4x8C/tpfDv/hMvEMOu3d5fxSW5jVljt0E2NgG1QM+o6966T/gpT4tv7v48eB/Dp0+41exji+0jTo3Kfbp3kKhcjOeAB07n1zWjiQfe2gft46b8ZdGuk0K80TVrZ1MNykUizptYEFWH0PQ18Iftn/Bf4Z+HNXBlubPw1e6s5a3hjiLBcHkAA8ZyOT0/SpP2OtS03wv+0xqWlan4duvBniK5sfk05Jt1oycEgLgEN0I5Ixu6V5H+1tqkXx2/aD8ZXD6ta2ll4Ss2islklAW4eIgMi+rM27p1wKm1g6H0p+yx+xfZfDK4g1W+vH1EKoNvGFAjUE7ueTu+nv8AWvtaX9oG9t/CTNdeStvYqjHYm0kKy4/wr5e/YM+LKfGH9nrS5JTm+0oGwuRuyd0eAGP1Ug/j1r1/XLc2/gvVOflaHB/Ej+VZzRfKjuPjb8UPAn7Rfw4uPDviPQLnV9KuvmAbCPC+Dh0OcqwycH6delfClz/wTV+HWmePTqMOq+IV09X3pAY41cg4yGbJH44/OvpG2tRBpqkAqSOx78VxvxgXVLb4f6xJokElxq5tytoigEmQ8A8/iahMxlFHo/wL+MHgj9nrR/7H8O6PHbSMR57PdAyytjG5u+fp/WvRb39tH7HayTvp1utug3s73OAv1OOBjFfkf8SfhZcfB7wDp3iHU9c1OHx9qV4WFqbjMiLu++e/pznBLYxXuX7TvxG1Dwz+xzo9lfK8Gt+IobeGVDkHG0O59ewH40NEJnov7Snw78Gftn+LZ9bgSytL8SbZZ9OlDCVscl8DBbPQ+mM56mX4Jfs06P8AB/UIbmK3jujGEBSTOJWQdW6Z3Hkj+lfPP7DPiG7+FPxSvPCWpAZ1SJZgoP3ZNoYY9coTke1faa27OgK9CcfQVMrotWO+b9o7XLzTZrFY7OOCWEwKixY2KV24HPuKi8eftSeGv2dfhfaXGq3cUt/Lb5trKKQGaUgenYdeTgcVwn2N4bWV8Nu2kgE7e3ODX5tfE/4g6r4n8ZX0l7e3N0yyMi+axJCgkBeew9OlXEho96+K37Wev/HrxQ9xqd5MlkjEW9mr/ubdck9B1PTJ/Kvuf9ixfM+Cenfe+TOM89STX5P+CbmW5vEBLkEjI9Oa/Wj9hi0J+AOjtxkx54GMfX8zTaE9z1ZozAFJ6E8cgVEZlhy24ADrz0/zmqnxOSRfAmqGHeJfIIUoTnOO2K8Q8TeJdR17wto+mWr3Kx2wCXrFWUOeMZI69/zpcomke8yXkZQASJnp15/CmS30KId00YJ45YCvnHUl1Oy8OR2ljNfveNI4i8sNt2Ac/gCRyadp2lXWv6gYIbrVTBa6f5hZ5X3mUAA9eM7v55FNpiW59GLco7EB1I69a474o/GfS/hZZrJdu888ufLghw0jY/kPc8V5PO2q+ErfS7pLvUZ3u7ZmlJkLNHnHHt2rz/xDqXm/G/w816zSQtmS4Er7wAMn5t3H9KiTdj2cnw1OviI06mx7J4R/a503xDqkdtdWF3pwl4Dy8qT6ZFex2Crf2SyxHKMNy89QRXyv4q8T2Wt+CtWKfZhNDfCK2EeMhAM8Y69O/rX0V8Bkuh8MdMa8Mi3BhUuHHzDjvU05Ns9biDKaGGpxnRVrnRzWBkjwpA4weOtVr1/sdixYhQASSeiitSVhsJAztyeDzXneqfGLTLyWezeK6VclMldoPrjvjPHatj45x1KWjfEa81OHVMxxvNalpIkAC5j7Z684611vha9fVdFglmVVlkTLYGBn2rh7/wAb+HNCuzHiSN3XygVQnfn+ZrofCHj7T9U2QW+8AAEbgQef8aaG0aXjxd3gzU12k7oSf1FfNWiaxJ4f1NbmA7SrBtvqPevpfx1sl8C6r90HyCAx4A5Hb86+WdTjLfd4C9M8eorTcEj7E+BnxPi8aeHom+bzEGwjdzxxXo/m748A8rzXxZ8CfiI3g7xHDvZhFKVRlJGOvX+fevsHw5q6avpazIwdSMgqcj86lsdjx39pe2/4nAkCn5l5OOnHSvn7xPax+UN3LP3xnNfQ37S3F1GRxhQc5zXgHiGElc4GF4/H3piOPkUK3Ixjkgdcf4Vr+GMG7jwSSWwVx15rLnK/aNvBJ4/GtTw2fKuEOFPz5GQeOai4H6afs2wLH8OdGXk/u175/U13mtWu7XlBxkMCD+Neffsu3H2j4Y6K7HkIB15r1HVbdX1tWP8AeFVczkjnf2jLQWUEOwYLRD27V4ldkB8Y+6MDHavff2m7Q29haEAAlBk9McZrwS+OSc8nJH1poSRlzH9/jBAPOe//ANfrUUqMzg55+6M96nuNqOMDufoKgkIYE5zj3zQxnz8YDMvB464I6H1rG1nQBcqQg24Bwc8VuwgsoOe3Oe9SGLzOCOCO/p/kmuZI2bPL9W8KtFIxy21j0Bzn8qoNo0zNtROmSePz9a9Wbw6k74Y4UZyCKb/wiUTfMq87gW57UdRWZ5aNEnyuYjlfoafaaBLKCUEmd3IJ68cV6cvhqJZNxC5Tp8v+c1esNBhU7vLT6dwRSbBHnll4FnuYiAgIbncDW9pHw42SB5iNu75uN1dpHapvUBRgdsVbih2k5x68CkkFr7GLYeCoLds7cE8cfN71owaBHaSj5UBPHy9sZrSSDKkYAx7+/wDn86l+yjOT06CkyyutokaqAFAHAFPEAXBx+P8A9an3EogXJOcdRnOP8/1rldf8ZG1hPlncetFhGtrPiWHS5FwUfgngcjpXL6v45mkYrEcDpnOcVhzalJfTYfgN68n8K19H8HTak6gpgduMHr2q7DM5Vmu5i3zyE5POcf568e3arumeFZdTlIHyge/P+f8A69dzonguOxVWZQzEemMD0rdtNLSJTt25GBn0Hp+FS7Acbpfw4IZWc4Y8f5/+tXtPw90aK00+3hAwiL0781y1rZbep4HNdno1xHplksrlVjVNzM3AA7k+lY1l7jYI+ePFF0bvxLqDv8rSXLkeuN/09KoKhkGcAhu46VufELS9P0vxJKdO1OHUYJk83KBcxEk5QkHk8DnA69Kw4sIcj0z/AJ+vP/16/mPMIzhiJxfdmqaRHcy3NlGHjgeYOScIP8f88VR/4SWSC8jje0nUSHbuJUjPHoea3rJiwckgBRlRWN4VuXvLAySclpWIGT0B/wDrVxczKubKZkAB4zk9eSfSrER2lTjb6+tQwThmG0fdGTg1m/ETVrjQvAOrX1hG019a27SQJsLhm7cDrRTjKUlFdROXY9G/Z13Xnxl8QNnItdLtUABwAXklbp+Ar6s8EW4/swFsnJ/pXzh+yj4GbSdKk1241a21TUtetLVrlYIfLW3KoW2YLtzlz6fSvprwKoOlDIyWY57cV/R3CmEdDLKdOW//AATJu5DrGnhZiEyoxjGPesyZTERggA9a2vEZKmYj0z+VfDs37eWveH/2dvi/4ie40/VfEXgvxLfadp9jIFVobZJkjjMiKQWCAsxPcKcmvpOQze59iC5IBJIPanLPleOlfA+kftbfGSz8NeL/AO0dT023XT/Dy6/puparZ2kJSbIzbmK3nk8yB1OEk4bdjIPAMPgv9vP4n/FL4X+CvEGm6n4a0vUfG3jdPDP9nGyNz/YyeU5YSjcrtJuUMBkfKR68VyMLn34XyOBjvk9qPtf2a3AJG0E9fxNfn+v7Xfxu8L+EPFOu3/iHwvqNr8PvGUXh29h/sMwvq8TyxoX3CXEZUSAgKPqTjnA/aq/bi+IMdrcXGi66s/hq78Sv4exaaM0Vv5YJUqbt3Ehm+U5CIV4PPrMqbR1YOj7arGm3a7SP0GHxW8Ppr40xte0f+0Wbatr9pj84nrjbndmursbpZoiXKADgelfBkX7O/hG5+xaQ11r/APwkGpeG11mObzIzbRSFWYowwGI4+vv6aOj/ALQ+s6V+w1q91e3dy8+iatZ2sNyzESGJ5AQu/rkYPPoQO1Qr3Pr844Up4TCvE0KnNy2umrb9Vrqeif8ABVH9m3xN+07+zhdaB4Rskv8AWBdwTLbvMkQdVlUty5C9Bnr2rh/2fP2PPGvgP4MaBpGp6StvqNhbeXOi3cLhSCeMhsHj+dfW3he+kuPCWn3Mzl5ZrWORyRjcSoJOPrXmsP7bPgwfAS8+Il3Le2GhWt5Np+yWIfaZpo52g2IisdxaRcLzyCM4raNz4yMrM8c+JH7J3i7xB4T1a1t9LDvdWkkSr5yZYspHOD6mvDv2R/8Agnn8SfAvwF8Q+F/E/hyaxn1aaXan2iGQbJIVQncjEdvWvrfT/wDgox4DXwxreqatbeJfDn/CMXNtBrNrqWmslzpiXHEM8ioWHksf41JA4yBVnUf+Ci3w6tNM0u9gm17ULbX7u6stJax0e4uTq0luMyGAIpMiZOAwG0nODwcaJsbqan5veEP2HfjV8Kvg34v8EzfCjUdVbWpH+z6lEYiuCAisQGJ4wWXuC3PrR8Qv2E/jKv7PfgvwJZ+DdfnD3El5qRjt2aO1LSHYrHpxuJP09DX6LeDP+Cmfwu8e32iW1pea7b/29f8A9kQTXWi3UEEV7/z6ySsmxZf9ncevOBg1ifF//gpRoHhn7Bp3h6w1a+1LW759L028u9Omh065nRtrKspAD4OOARnPWlzs68JRlXqRpR3eh+fXxm/4JI/Fbwv4J0/UtIn8R+J73SHjjtbD7LIGtkJ5MWWOADtOAB+lfa3wt+GPjG++HWkXuueHdS03UDaI9/HJblPJlCjfx2GQe/AxXR3/AMafjf8ACiK68QeI7DRr3R9PkUXtlG0W+FGPBBjYsM5GCdwHpX0l4V8fWfj34UReI9NctbXtg1zHvGCh2klW91IIP0pc/Noz2M0yDE5fBVZtSi3a8XdX3szhfDv7HXg611W+12H+0Fv9ditzdMLkGP8AdxhF2jbgfL19a0db/ZP8JeItLksr63mvbabh4Z9ksbYxjKlcHkZqv+0t4x1PwN+xt4w1/SLmSy1TS/C897aTxqC8Mq25ZWAIIyDz0r51+Pv7Y+q+KdK+Etl4L8X2A0TxDHKniLWtN1eztzbXcdqkiWrXEqvFC7szsQy7j5ZAxzSUTwbs9O8A/wDBLL4X/Db4q6r4u0ca5a6jq8RhmiSeJbZVZlJCIsY28oD1rk/F3/BEj4PeO/GWp63qF54xa81WRpp1j1CJI95OSQBDnHsSeleNfFz9rn4teDvgX4G1fSPF39teKJbrVYr2Kwt01SO60ePeo1R/IVVMluDjcuInYZ2nbXWfFD4rePdeX4wXHhj4q6+mjfDnwLpmv6NcWcNo39qXL20splkdoTlHMfKjA+YdNuDrZ2MXJ9D3T4S/8E1/BvwX8FXmg6Pr/i2ayuM+V9uvIpmtMjH7siJcDnODkZ7dc+T+Iv8Agi18EvDHw9urbVfEHiHT7Zr4ahJqV3qFvHKjgFQpkaMAKdxOO5I56Vz3xC/aV8efAPVbn+2PH+v6jp/iH4YW3ifzhplpNLpGoTXcNtut1AiQR/vekpIXAYk855n4W3l/8ev27v8AhCfFviHWPEnhm20hLyKC51a1vJYJHhkcgy2qrGpJVSVwSBjkjArOcnHVHs5LgYY3ERo1HZat21eiufWPwx+B3gDW9HhsdE8U/wDCQrp8Ucbyw38NxIQAAGcoPvHHNN+J/wCw94T8W+IPC2tXNxqcV94Yui1kVkUoxnZI2Djb838OMEdO9eA+KLbS/hf4C8A/E7wNY3mgXt3qU9lPZfa2uEuER2X5i394R8gYHzdsA19zeIMzeH7d2UAm4tjyeh86P+tZU6smerxJkEcuVOpSk5QndaqzTjo07X+Rwlx+zHpjRBDe3Q46hAPavJ/jl/wSr8LfHjxP4a1LUPEWr2j+GpzcQxwwxlZmLI2GJ5x8g6epr0n9sn47at8AvD/ga/0oWXl674y0zQr43KFlS2uZCjsvIwwwMH9K8O/az/ba+JXg/wDaB13wh4A01JIvC/h+HWzL/YzakNTlk8zbG7LLH5MPyAGQbjnPTFbq58q5aG5+0H/wSP8ACP7RPinQtR1fxBqkI0Ilfs0UEey5UuCVbuM4xx61HL/wR+8E2nxr0bxrpGqXOh3GkxBBZWlpGlvNhWXcwGOcNj/gIrjfF3/BQr4hab+0D8OPBaHwjpUPxNsdN1IzXgkaXw0ZEYz28qhtsjSsu2FspycEHrWdqv7YfxxntrjxBY6v4Ni0qL4pT/D2Gwm0eR28ozmGO4kkEwyynaSFCg/pRdozbN3xP/wRU0zWfijrni2H4j63aaprqPFP/wAS6GRFidAhjG5vu7QB6471c+Bn/BPjwL+xNYahZX3xLzb6q6ypFqLRW+xwMMyAvzkYz/uise//AGxfib4ZuPEHgPVPE+jS+LdH8Zx6FBqFhoEk93qVpJZi6HlWu/y1lAbDM7hAF7nBryz9nuW0+L3gX4j+NfidJreuar4Z8UnRpNkyW0kse4KN6rvVSvohIGMDgZqKk2kfScOZTRx+I9lXm4ryV23959p2n7M2g+KLO0ntdaa7t45Vnjlh2Or4GMZBwepp/iX9neOK7tbexu0aSdGJEvy8LjnjP96vJP2eJZvgJ+2bf+A9KuLy58NanAJ1gmfcIG+ziVXx0B+8pwBkEZ6CvqfXgI/HWh/d2vb3aZPX/lkcD8v0qIVL6hxDkzyzEqkpc0ZJST2dn3XfQ+Iv2h/+CVvi/wCL3x/8F+LLDWdBtLTwxMk00c7v5koEquQuEI6Kep79utH7U/8AwSt8T/GXxx4Y8VeG9Y0PTde8OyKVe8DmKQK29eFU9G/n2xX038afjfqfw4/aI+FXhW3WwGleN5dSjvpJwTLGbe282PyzuAGTkHIOeMY618+ePP2+/iOPjT40tPDPh2O+0LwPrUWkzWC6LczTX6fJ50xvFYRQth8orKcgZPUZ6FdnzrZw3hb/AIJOfEyf41at4/8AEvifwvca5Npklpp0dmJkhtnZAiMcpuwoz6k5znNUvg//AMEKLbQtEupPG15pniHXL2d5PMt5ZY4olOOOVGSTkk4r1Gz/AG4PHmoftl6v8KGufBsaaFb3OqSaischN7CIFlgskj38XKl8yZJ+VSQorn/hz+1T8dfH6/B4nxB4FsU+MNvflCmhSuNINrH5mRun/eM6gjB4UnODjlak82pT/ZP/AOCV3jL9mnx14ik/tvQrrwzqzF7a1R5PNgIb5dwKYzt4OD2Fe261+zndW+kXVpLqmlW73kTIgmk2gknr0PTHpXjB/bZ+InjvwJpthZaxY2XjK3t9Xe8tdN0Zrp7hrO5kgWVjK6xwQnYCcsWJYbRgVx/7O3gXRP2jPgpoPj7x7qviDUNX8U6z/ZTGB42CTtnaxLj5UGDwM8YwKxm2j6bIMnp5hKUZz5UvK/6o+jrb9kW+/s9UGpWL4XogYDp64rS+FvwE0LVW1Wy1axkfUNHuzbyuJSA6lFdSADjBDZGcHmuc/Y38e6n4Z+Mfin4aahez6laaK0kllLKSzxqj7CM+h3KQO3NeweEZdnxk8ZW5UZZbK4+uYSuf/HP0rNSucOd5VLL8U8PJ30TT7p7Hms3/AATe+Dtx43/t658NfbtYDGQXF3dyzkHqPlZiOO3HFXPid+wJ8Kvi3PZvr3h4Xz6eCLcG7ljEeSCeFYegrxf4iftC6z8F/wBrj40aRJN4hmu/EWk2K+EUSyuLu1W9+zSLsXapSPLtGTnC888V8rfs0S+P9L8cvD4x8TeL2hudL1GfxVYxSak95aYDvFLudRHHN5gjCiNiDnB6nOiTPDZ976P/AMEzvgr4Y1u21K18MGC+tWEkcwvptynpnJf/ADz713q/s9eD40AW2YA9xOQQfxr81fD0XxT1b4MeI4fGV18TLTxpq2o6RcaYxmmj26PvEeYthwsmCxkyNxwpOfmr0Hxn+yfrvhO8+McWk6t8QZ5PBMWn6j4TDarc3H7yXLTYBIErEgg5zjPem4XBSZ9j/FjwV8N/hP4Sl1XXV+y2oOwATszzEg/Kq55J5r5K0jwf+zh4g8UT3F58MtbS1upTuvZp5XjBODkqsnAJ54z19K8T/aytPGOq+Nb/AFu90PXNO1S3162aJLtL66upbcquWEnFtFbcYCAF898Ak/ZPj342aPreqeItDutU0dtBuPDYmtY08tUW7KAkKQNxfPOOvTisptxZ93wtlWFx1OSrU3Jrqnsvu3Ou8P8A/BPP4K+I/Cq3OkeGLOOG8h3wXUM0jkbhlWGWIPXoav8A7MPhMeFfhnFpxBBsZZIj8uAQHI6Vof8ABP621GP4B2jXwmSM3Uv2USgg+VkYIz2znFcR8RP2pNF+Ceo6tolrE13rEd9OPLK7Y4v3jYyT19gOuK0TZ8rm2DjhsZUw8XdRbR634j1Oy8P2sk97LFbwIMMZGAU+g+v+fpzPhD4k6V42nu47OL5YCOXAG/8AAdB9a+WvEvxS1b4las13qF68xzuRAcRx85IVegHQfhWpoPxMn+GK77eC7l+1yKjNEnyKeByxOB1/z1q0eckdP4//AGx7zwP4gnthommzrA5TIcqzLz+XT8qwv+G/Jlct/wAIpZBcEYWbBP1+X6dq2Nc+COk+M0TUVvtPhuLj5nV33SFiSSW6456fhWNL+z5bo7D7VatjJGyMEfyqyRD+3+HwJvDFttHAAm5+o+X/ADiuP+Jn7UOmfFCyjgm8NC0mjyY50lUtHk9MbeR0OK7Bf2dYHOPtGnKMceao5A/DrUeu/APS7C2V3uNOllQYVYovb1FS4o6cNiKlGaqQdmjybwd450/QvEUFzPpTakkTK4ikl2ocHuAOfp0P0r1NP24tctroiPT9Os7ZD8kRBYqOwzke/b8sVzd/8BU1KaKaCWOLywMKE2qw9zTH+ANzNIGkMEy4+YEsDnP0pKCRti8yr4iyqyvY9Etv2+ra/tmhl0C7eTGC8coKsPyyP1rivEXx/gur957XSmtQRkpOwPPJ4/z2rofDHwbexsyFtIgQPvbsEZqXVPgSmu2jRXcU0ucFSJuhq+U884+P9oS0gy17ZPiQ5zEMkdq3vDH7W/hnQchrG+duqlY169s85H61oyfsr2f9iWwtLW3aUsTL5khyPTqRz+Yrmdc/Zv8A7OchrO1zzt2SZOOvY+lKwHcat+3L4Z1Hw/e2n2HVGeeMop8tSCffnGK8VvPjDYTzkJFMFYkBtpBxz2HTiuwsP2fFeMSHToXAGQGkbk/j2/z3rlPGvw0h0udo47RLWeLqBJu3fqffpVRQ7lez+L9i18Qu4YXedyg5x2xzX2P+yP8AFmPxl4Otz5zyR8BWcEE/XPP5818F6f4CuBqUjsrNvBA+XBHNe4/ss/E9PhzrEemztErTOvBxx659uaUo9Quz6O/aWYK8TbS4IHGfrXz/AK4jG1cruLAZHYj3r3T426kmtaTbyL8wkXsePavDfEUIIbBLLyMjr6His7iOHuCQ5IY/KcZzyKv+H5GF3H/EA4xj+v6/lWbd5DuynCgnB68Vo+FTmVAwDEdTjk1MiWz9JP2WtQx8MdHbqqqOAPfnAr2ye6E2pK3ABIr53/ZfvQfhjpS9Cq+nQ9f617dDqwi2HOcH0rRaoTLv7Ul2smm2jJlg0SjOOnFfOt8u+RgDjn1r2z406mdT0qHJPCAfT/PFeJ35HndTggqP8P0pWYijMMjBJx7d6rO4TJYHPb2q677WIPzAnPuP8iqVwMS9xnParA8KhARcdc9Rkcf/AFqdakFnXGGP3ucZ/KkiG9VIJ47A8CrIgJGSeR1yM5rnNYjYUcITkjkZy3TtVi2KumMDjPPemwxBDhwAT1x1FSwxAL07cdQaCxYVyxwoBz1xUqWu8jIbOe3tSrCNm48Y5+n+cfpViNWXDEN8x4zjIosQkJDahsqSAT36fjUi26iTJXjg9akSUOVwCQAelSRR70GcFc8c+1KyKSEEQCjJ4Ixz6VHe3KwRckYUU27uBYpuZgqgfSuS8UeJFVmVXJU84yMdqOUYzxd4rRxsikJweSD09q5dWbUyByFJx7/5+lCo97cZAJ59eTz3/wA9q6/wb4WFwwfZ1XoR/KmkBF4S8Gs7l5AAp5bP8q7zTNNS3TciDgY44PpTtJ06Ozj8tF4wCRVtItpCgNtJ7jihoAihJfA6EfWpo7fZHk455yecfhTrbAjOM+oANM1C+FtAWPYdulTygI16bWYFiBk9Oc9e3511l9bfavCV3CsZdpLV0VU6klOAPzryi98Refq0SBhguM44B5Fexab8ttGM5yoB9KmpT54OHcV7Hg0nw21iIEf2ZesT6RMaik8BayoX/iVX+MZGIGwM9O1fRDqVUsuCT154ryZv2oF8PeJ9T07WdJeJLSRo4JbOVrhrgDkZUou0nO3ALcg9ua/Pq3h3hakub2kvwHc5a38EaxDvB0jUssPm/wBEk5z+Hv2qhbeBNV062CpoWsbCc4+xSk5JyRjbXpekftO6VrPhSXWotN1WewjnNvD5XkyPMwTe2AH2/Lgg/N1FRW37Ynhi9v2tFs9Za8jbymhNsofzN+CmN2M4+bOdvYnPFZLw0wr/AOXsvuRSkedL4c1c4P8AYeujHf8As+Ydv92rMOgaysoX+wNe45P/ABLpv57fevR7P9rfwtPBdFl1GFbSAXL74QCYyAQwUEnBJwD0J6Zrb+Dfx10v4xXl3/Y8c/2WxiV5ZJkMTBnPygKRyCOcg8YwQDwKj4aYVO/tZfchXMn9mDw3qOkar4sur+xu7GK/uoGt1uYmjdwsIViAwHGcj6ivpjwPH5emJ06k/SvPw2OM89PWvQPCB8vSogWPvmvvsuwccLh40Iu6irEthrMatK+7BHf2rzCf9mv4f23iG71ZPBfhhNSvzL9pul02IS3HmgiXewXJ3hm3Z67jnvXp+pzoXcjkA9j0rDv5OPlznsRXeiW7nhPxF+F/wN/Zy8ETXWv6N4P8LaFdXcJkZ4VhjmmVt0YOOuDkgdBjPbNY3xi8V/AD4Ca5aeKvFz+GdH1PVbqLVLacqzXFxMqbUuBGmWJVSRu28Zr4A/4Ky/EHx78RPiF4kbxX4O8ZaX4c8P3aWPhi6W1ddLcCZRJcSyFcO0ijCY4G8Dggk9rpnxT8NeOf23/h/qHxT0uLQPDdz8PFjtLPxPCscEcimdSzCT5Bu2MRnkgqepFaqHUR98aJ4f8AhT8UPhRf69YW3h3U/CfiC4/tu8u4SpgupoyHM7sDw6tGM5wQV5715BB+zJ8Av20/BGsa18OV0CfUv7Ra4Op2hl2w3gO4loyRt3ZySqjPB5xXxf4N+OWo/Cr/AIJleKfDOgC7lm+IPiy70fQYIgWkNm6qJSgPzEFBs4yd0o75x1f/AASE8eXX7NP7Wlx8P9U0nxL4c0n4gadFJaWuuWzW0z3kMe4uoKgFGbzlUj1QHkYolDRm2Hryo1I1Ybp3PpnTf2W/jKnjeK4bU9Oie3sxpiX/AJkTxi2A2hAuwtjBPJXPXnPNN/by+EVr8Cf+Ce9xo9tK1xLJq9pLcz4x50hfnC88cAAdcDrX2MHAU4JPavmf/grfKkf7HkgkJWNtZs8n0wWOT6jiuflR9DmPFGMx1L2NSyj2Ste3c+i9DtA3hSziBwv2WNP/ABwV8rT/APBNXxFq/wAG9T8A6l490698NHUX1fSov7BAmsbs3P2gGRjKRLHlpFK4UkP14r6w0AqdGtFBBxCmCOMDaK0IkBQD5eBVLQ+de58nwf8ABOfU7n4ceIdAfWfB+hw+LpIbXVB4e8NJYKdPTPmQxkuzF5M4LOWCgnaBV34X/sCax8MfEvw1E3iq21Xw/wDC+91M6RE9uUuvsl1Dsjhcj5WaM5+bjIxwCK5H/grZ+0x8X/gd4Buz4D0ZtK0G1itp9Q8V+eheFpJvLFvFEw+8Tty3zYVjwOtY37cf7bni34Ifs6/BOy0rWp9K1z4iQ2Z1HXFs1vJ7SFYYGnkSIq252Mo42ngMBg4ItXYj0Wb9gC/m+HGh6JHrtgkuk/EWTxw0wgJzG0ssnkgY+98456cV8/8Ax3/YQ+Ifw6i8F+JdbvNJ8XyeEdce/vtZie7fUrqLzN6eaJCyRoqgLhOMqvNe3/sB/tML4j+G3xD1DX/ibc+NYfCV080q6pow0rUdHt1jLYnUABw20kHHBDDP8K+HfsBf8FFviZ8Rv2u9DsviLqG/wH8Uob5vDNtJaQRpaPHK/lqHRFdsbDH87Eksp60pRZ25fi1h8RGtKPMk722v8zvL/wCPlr8QPFfxHgsNI1q4fx/BbWunwiJWkR40CDeoY9e23J9q+sPgd8Orv4U/sw2uiXYCX1rptxJOowQkj73K+nG7H4V3Wk+B9F0O+e7stJ0y0upeHmgtkjkfJycsACckZ69RS+NJxD4N1mU4UJYzFiSAAPLbvWajY+nz/iinj6EcNQp8kU03d3baVl+A7wrbQ6l4L0+OeKKa3nsow0brlGUoOMdMe1Mf4Y+GjpM1gfD+iGxncSyW5so/KkbjDMu3BIwOSOwp/wAOZftPw80SRc5fT4D+ca1sbMdTjjFUfIM8Z+MH7THwv/Z6+IXhbwxrctha694tni0bTbO3tVklKOwVUYKMpFuZRz8vPA4NZ/7QX7Uvwe/Y+lttM8Sx2dld67btt0zTdIN1Pc26k72eOJDiMZblsA/NjPNfJ3/BSj9l7wz8Jf2uvgp430q2u5PEfjL4hW82p3k9w0u5Vlt9saKeFRewxnnr2rN/bp8P32n/APBV6xvdT8fv8LdJ1nwS0Nj4gkgiaJdnmb7dWl+RSzZzzn5sDG4Z2ikZs+5tO+NPwy8b/s/S/E+GbS73wSmkTTS3sllu2WceTJGY2XeApQgxkdRjFeIeFPBHwx/bz0g+O/gp4iXQNQ0Vjo8s9pZSWOAE3eWUwjL8sn3gMEMR24+T/il+1t4v8a/8EjvDfhi6tJrvxP498Qy+HtO+wWX2ebVrG3mV2lSKNRuLNshIUc5PU5z1/wDwSo+JbfAz9vvxP4Cm8G+JPh/oHxE0uG80nSNbtXt547m2jOWCsOVfFxyOMqB1GATppxZ25dmNfBVlXw7tJfP8z62+Bv7AEvg3ULGXxX4il1uw0if7VY6XEz/Y45f+ehVjjqc4A5PUkZB+hPE9nv0gKGyVmhb8pUP9K11Gf4hjFZ3iIrb6PK5YjaV57j5xzXNypHVmueYvMaiqYuV2ttLJfJGB8Vvgz4Y+PHhL+wvFujWuu6Q0yXH2a4B2eYucNwQcjJ/OuF1v9gb4P69omj2F34D0SW08Po8VimHXyY2cyNGSGBdC7M21iRknivZFTacg5APNJcReZCwyVLAjIPTitIux5LkeFeI/BnwSl+Jlz4B1Kw8LnxT4ziivJNJk/wCPm+itRmJsZyqRhPlAwAFOB1rI+JfjP9nv9n/ULfwp4p1bwZoVzd6oviNLC+vAsgvC+5bpgzZVi65DNgEg4718naD+ze/7OP8AwWy+GsVz4m1rxZqvinQ77VL7UdTbc7zNFeLsQZO1FSNQFycfTAHkXxt0HxTeftUftX6vcXHgYHw48eozWniewS6m1KzifMMNtu+4pRY8lcEkxDIJyNOQm5+k/wAe/h78FbfwRqPirx7ZeFrbRr+8t9RudVvZAiSThBFDKJQfvFCFBB5BHWvnC0/Y1vrrwNdv8F9R0TVfh14unW/SO1nRUkKHCtuPUKcjKtzjBHavEP8Agof+1foXxe+A/wCzj4Tv9KutF0HxJFZ+Jdf0nS0Je1sox5SxRIMEqQZinpsU17B/wQS+Oq+Ivhl4t+Gsktyx8Eak11pYugY5jYXDsy5Q9CJAxI7eaKynC8bnu5JntfLKzq0Em3/Mr/8ABR9Jfsyfsva14O8aXPjLxtfw6n4nuLcWkYjwUt4wqryQAC21QMjtnk5zXsPiSNE8S6HkHezzRofTMe4/+g1tom3hsZx2rE8WpF/b/htnTe5vpERj1Qm1mJ/QH86ySsZZrm1fMMR9YxD12VtEktkkc/8AGb9mzwT+0Xa6bD4y0KHWotKd5rQSSyx+S7DDEFGU5I4rBvf2H/hbNrunak3hKx+06akCQgSyiNvJx5RkTdtlKBVAMgY4A9K9aSPtyDis/wAZaPd+IPCWp2FlfSaXeXtpLbwXka7mtXZCFkA7lSQce1bRkzyZbnkGlfDn4J3vxFvPBlnaeGZvFel3r+JbqwiuN2oQTy4DXL4bzBuDKMnjBUYrJufiN8AfhZ4/8N+DJNb8FaV4h8HyPDo2nSagizabJcDDIoLcO4bG08nPAr5Z/YV+AY/Zl/4K+fEPwudd1bxHPJ4NW8m1HUZN9zeTSS2sjux5PUnAycDHJxXzR4em8Q+A/Cvxg8e6vp3gTWh4V8f+Zqum69Yedqt/K8/lqEcnMca7iVA6kueduDetyT9Ov2g/h98BfhX4Ysr3x1a+E9As7m4uBZ3F84izNPl5dpJ+bcSWKnIPJxXhU37KXxC8G+GtO0bwILHU/B0d8mt6VcWnl4JYZRjuP3duOPun3rwL/grN8etC+Of7Q/w/8J65BrLeH9E8My6vdW2nQGaeK8u4C0ClARjYVgJz2c9jX1j/AMEVP2hp/jP+x5ZaNqTSrrfgSc6LcpLxIIlG6BiDzjyyF57xtUThdXPoMi4hrZZOUqUYy5uklc9J/Ze/Zz1bwBrms+LvFlxBceK/EGRMIcCOBCQSOABkkDIHAxXWeHz9l/aD8SR5BE2kafLtx0PmXSk5+ij8q9IuFCxtzn29K8705Iv+GitZIZhcNotoChTAKCa4IcN35YjHbbXOtzjzTNK2PxDxFfd9tklskduYlYnGPm6//XqGSziDlljX5h6cn2qz/AQDntio5GwmSMDrz1qzy3qfFHxX/wCCwWifDj4ga7Yr8P8AxfqHhfwxfLp2peII4kW2jlLbRtU4yCQ2MkEgZxiu+/bC/wCChnhj9kj4P+G/Flzp9xry+KWUafa20yxvJGYw5k3MPugFf++hXxh/wUG+PXiP49ftQv4U1Xwb46/4U34Xv83VroelnzPEM8ZOZGdgF2FiVHJwMkZJBXU/a58H/EX9sf8AaI8B2fgPwBNJoHhPw7HPHaa9B5FhA00YJSTJCl0Vo12hidyeg51UVdCP0B+DPxK8P/tdfATSdf8AsUc+keJbQTPaStuMeeqMRjDK2eR0I4rmbb/gnr8OE8RLfPY3k0Stv+zPdHys+mAMkfjXhH/BHjRPH3wX0nxd8M/Guj39gnh28NzYzvEwt3WRj5kcbkYcB/myD/HX3IJuRwefX/Gs5RVz0sFmuLwkXHD1HFPezsVrLRrbQNLgs7SGK3tbaMRxRRrtWNQMBQOwAr8vv2zr19E/ad8WRh/ma+aX5uQgY7v61+pUzAgEYzX5V/8ABR9/7K/a88QBdyifyJMtjJJhU/59qInnzm5Nylq2U/B+umeBdxAwO/QV9SeDfhFZaz8Ebea8lklikkjumBcjDyRFlAx6Ac//AKq+Pfh7BNqOlqwDMCwGcZGAe9fS1jea5J+zbqCpNOsljd2caBTtZU2TAL2/2fy5rVIlM04rnTLGy2ppLxMBsz5rAH2qC416BE2i1kx05ckVP4ru7jwx4VjumVIoxCHYtyPu5PNeUXv7TNhbMU/tCyyeM5Bwfw4qhcx6gNZgaLcLWQsevzGmGWKZQxtS2Ovznn9K8wH7TtgsPyX+nue+1lx9frRbftP2srPH9ssXZeqgZ/lSuUerW2qQwjItGGRjG7j+VSDxUYZAI7eYqTyolOP5e9eYRftFwXDYE9mWyScY5PrVuD48B3JD2TAHOMDj8aLmbPVLXx1HGMvBO2QCF35xz9K29H+JdjbEs1jdMScD94Bx9MV5bpfxRlumVBbwsOADjOfp2rZg8bSNDk26At0AHOO3etQudfrvjSz1JnPkSqWOQMD0rCn17TQXJinjC/M2SCP0rk9W+JstpOM2sSgZzuU4+lcv4s+LP9oRxoq28Owksd2N1Z3A7bxR4v0iLTdkIvJJOB0AAryHxJ4jjjumfyn3ZJDbuD7/AMv/AK1TzfEhA6IqRXA7DcOe/FZups/iNz5UREh/gTnr/n9auIEvh3WZtbuRBEDH5xC7tu4gk4GP8K6v4ofs76n8IvEWkXt5cRzm9YndGpAUAgkZ9MEf5xWH8NNBuYdUQtBLGUbO4jhSMkV7j8fNY1P4o6F4df7GN9lmJ/JQnJVU+Y47nGfxPtTC5SXxu+u6HHA7qGgUADjB+n51zuvoTBITzkcY/H0qsLWfQdda3ufNifONrDaw/D1q9qkYa1ZVZuBjr6//AF655Aefzx4uWbbnOcjrx7Vc8My4uEUA7S2Mjpjn/P8AnNVNRYNdPhTyecfwj/J/WpNIkIuVHTB78VDIbPvv9ma6K/DvT224VVxwevNexy3JcxNnjIJ9e1eI/sxT7/hzYLwDjgf5/lXtDDy4k68/rWkBC/EOTzNHU7s4A5615b
Avez vous prévue un relais pour votre pompe commandé par l'horloge? Si oui, un deuxième relais commandé aussi par l’horloge pour le régulateur et l’électrolyseur.
Si non , il faut les commander.
Relais protéger par le même fusible 2 A de l’horloge.
Cordialement.
Cordialement.
Merci pour votre réponse , je n'ai pas prévu de relais pour ma pompe, du coup, si j'ai bien compris je dois en rajouter un qui relie mon horloge et mon régulateur de pH. J'ai vu le modèle ci-dessous (qui correspond à la marque de mon compteur électrique). Je ne sais absolument pas comment le rajouter sur mon installation. Pourriez-vous m'aider s'il vous plait? (que mettre en A1 A2 1-2-3-4?) MERCI!
[img]https://m2.lmcdn.fr/media/1/5ae72825b7c5056366a77f62/.jpg?width=620&format=jpg&quality=75[/img]
Un contact d’horloge a une intensité max a l'utilisation; donc selon la puissance de votre pompe il s’abîmera plus vite.
Donc on recommande un relais dit de puissance pour l’alimenté .
Rectification de mon message précédent : un seul relais avec 4 contact ouvert; deux (une phase et un neutre) pour la pompes mono et deux pour les coagulateurs de ce type
« https://fr.aliexpress.com/item/32267498874.html?spm=a2g0o.cart.0.0.3bf23c00ZIuxwN&mp=1 »
L’horloge commande le relais, protection du relais avec le même disjoncteur que l’horloge 2A.
Je vous remercie pour ces précieux conseils
Autres discussions sur ce sujet :
« Projet avec abri (dpt 44) - vos retours et conseils ? »
Discussion lancée par Emma44260 - 15 réponses
« Renseignements sur beaver pool..et que pensez vous du devis? »
Discussion lancée par pucesamson - 49 réponses
C'est intéressant aussi !
2 personnes surveillent ce sujet |
Votez !
Votez !
