VOICI MA CREATION DE PISCINE BOIS ENTERREE SUR 60 CM AVEC
_PLAGE EN BOIS ET LOCAL TECHNIQUE DEPORTE
_PLAGE BOIS SUR DALLE BETON SUR PILOTIS
_BARRIERE SECURITE BOIS ET ALU
_AUTOMATISATION AVEC POMPE A CHALEUR ,ELECTROLYSE AU SEL,
_POMPE MICRODOSEUSE PH ET ECLAIRAGE LED MULTICOLOR
CREATION D UN ABRIS PLAT ESCAMOTABLE
Ordre d'affichage :
Avril 2012
AU COMMENCEMENT !!!!!!!!!!!
Mai 2012
HEUREUSEMENT LA MINIPELLE ETAIT LA
ET VOILA...IL FALLAIT BIEN UNE GALERE
GALERE...GALERE CA TOMBE EN PLEIN MILIEU DU TROU ET A CE STADE IL ...
ON DEVIT DE 3 METRES LE TUYAU TROUVE
Juillet 2012
8M3 DE MELANGE SABLE GRAVIER ET 50 SAC DE 35KGS DE CIMENT ET UNE ...
ELLE EST BELLE MA RAMPE POUR DEVERSER LE BETON A -1METRE DE LA TERRASSE ...
APRES UN VIOLENT ORAGE !!!!!!!!
Aout 2012
DEVIATION DU TUYAU QUI PASSE COMME PAR HAZARD EN PLEIN MILIEU DE L ...
CREATION DU LOCAL TECHNIQUE DEPORTE DE 4 METRES ....4M2 AU SOL FAUT ...
MONTAGE ELEMENT DE PISCINE TOUT SEUL 1 JOURNEE
DEBUT MISE EN PLACE DES ELEMENTS .....POUR S AIDER ON TRACE AU MUR ...
Septembre 2012
CONSTRUCTION DE L ABRIS BAS AMOVIBLE....PANNEAU PAR PANNEAU BOIS ET ...
MISE EN PLACE DES PILOTIS EN PARPAINGS POUR SUPPORTER LA FUTUR DALLE ...
ETALAGE DE LA TERRE AUTOUR DE LA PISCINE MERCI LA MINIPELLE
Octobre 2012
FAIRE LES FONDATIONS DU MURET DE SOUTENEMENT DANS LE FROID SOUS LA ...
DE LA BOUE ENCORE DE LA BOUE
MONTAGE MURET ET BETON ......BETON D HIVER BETON DE FER
Novembre 2012
MISE EN PLACE DES BASTAINGS POUR SOUTENIR LA DALLE BETON
MERCI MA CHERIE.....HEUREUSEMENT QUE TU ETAIS LA
CREATION DE TOUT LE BOISAGE SOUS DALLAGE
CA AVANCE PAS MAL
SUR LE BOISAGE IL Y AURA DU PLANCHER COLLABORANT SUR LEQUEL ON COULERA ...
CA COMMENCE A FAIRE ENVIE ....SAUF QUE LA ...CA VEUT DIRE COULAGE ...
FERRAILLAGE
Mars 2013
ETANCHER LA DALLE BETON CONTRE LE RUISSELEMENT DE L EAU
ETANCHEITE COMPLETE
DEBUT DE L ETANCHEITE 2 POTS DE 40 KILOS ET UN ROULEAU
DALLE COULEE ET ETANCHEE
Avril 2013
DEBUT DE LA POSE DE LA TERRASSE
COOL
YEAH!!!!!!!!!!
OUFFF DU SOLEIL
MAIS OUI TU AS BEAUCOUP PARTICIPE
YEAH
MONTAGE DE LA PERGOLA......
Mai 2013
DEMONTAGE ET REMONTAGE DU PONTON BOIS DEVANT LA PLAGE DE LA PISCINE
Juin 2013
1 AN APRES
FINI A 90% RESTE PLUS QU A TROUVER QUELQUE CHOSE POUR CACHER LES PARPAINGS ...
BONJOUR
PLAQUE EN POLYCARBONATE DE 16MM SUR 4ML DE LONG ET 1.06 DE LARGE
CHEVRON 6X4 ET VISSERIE EN INOX RONDELLE INOX
POIGNEES EN PLASTIQUE POUR LA MANUTENTION
COMME JE L AI DIT MOINS DE 100 EUROS PAR PANNEAU MOI J EN AI 6
Bsr merci pouvez vous me donner quelques précisions svp,chaque panneau est indépendant ou vous avez réussi à les assembler?pour les mettre en place avez vous fait un système avec rails,ou roulettes ou vous les poser manuellement l'un à côté de l'autre? y a t'il un système d'accroche au sol? désolé de toutes ces questions mais vu le prix des abris l'idéal est effectivement d'en fabriquer un. merci et félicitation votre réalisation est très bien réalisée.
BONJOUR
DESOLE DU RETARD POUR LA REPONSE
CHAQUE PANNEAU EST INDEPENDANT
MISE EN PLACE MANUEL ..TRES LEGER CAR JE LE FAIT AVEC MA FILLE DE 9 ANS
PAS DE SYSTEME D ACCROCHE ET MEME PAR GRAND VENT CA NE BOUGE PAS
AUCUN DEGAT AVEC LES GRELONS
PRIX DE REVIENT TRES BON MARCHE
desole du retard pour la reponse
chaque panneau est independant
mise en place tres falice car je le fait avec ma fille de 9 ans
pas de systeme d accroche et meme par grand vent ca ne bouge pas
aucun degat avec les grelons
prix de revient tres bon marche
